when did i talk of PD? I dont understand the question
PD is used over and over again in the book about PP
and is not in the list of definitions. The book can not be search for words.
To define something else I didn't know what it was:
* viz. (videlicet) means "namely, to wit, precisely, that is to say".[1] In contradistinction to i.e. and e.g., viz. is used to indicate a detailed description of something stated before, and when it precedes a list of group members, it implies (near) completeness. Example: "The noble gases, viz. helium, neon, argon, xenon, krypton and radon, show a non-expected behaviour when exposed to this new element."
Trying to pour water upon the blazing fire of my Ignorance
Randy
Ref. LinkAlong right hand side of web page, many ref. links.
... Do not use ‘electrical teaching’ to presuppose ... ... This is a recycling of a stabilized magnetic/electro energy not electro/magnetic
because the field of force is not a case of electrical input, an input that created
the magnetic, but rather a build-up of magnetic energy which caused an energy thrust. ... ... This power source is not predicated on a continuous flow of energy but
predicated on the consistency of the transmutation process of the magnetic
molecular structures within the Earth’s pressure flow.
Sounds like PP (Primary Physics) to me.
Strange how I wasn't even looking for this and I found it.
Image of interest, makes ya go: ", that's different."
Nice I like it ! It pops out at you sometimes ......THATS PP!!!!!
Im still on Algae
http://books.google.co.uk/books?id=xI_500ggNagC&pg=PA428&lpg=PA428&dq=algae+ earth's+magnetic+field&source=bl&ots=eQb62njQwl&si g=5dRy2EFXrsQuQJlxilNXQvt1iyQ&hl=en&ei=goqlSeb6CdS zjAf4vO3OBQ&sa=X&oi=book_result&resnum=4&ct=result #PPA428,M1
karlsoen - NEXT PAGE 3
Electrical fields are incompatible with the entire earth system, causing numerous problems. We must and we will stop using electricity in the near future. There will be a shift in the earth's magnetic field that will prevent the generation of electricity. The earth's new polarity will not allow present generators to gather magnetic molecular structures from the ionosphere to form them into electrons.
Maybe it's time to error on the side of caution.
Unsure if cold electricity qualifies as a replacement.
Magnetic Water Purifier
Magnetic Water Purifier Drawings
Magnetic Water Pump
Magnetic Water Pump Drawings
Magnogen Motor
Magnogen Motor Drawings
Magnetic Current Generator
Magnetic Current Generator Drawings
Magnetic Light Box
Magnetic Light Box Drawings
Romag Generator
Romag Generator Drawings
Mini-Romag Generator
Mini-Romag Generator Drawings
Pyramid Unit
Pyramid Unit Drawings
Magnetic Piston
Magnetic Piston Drawings
Cold Fusion Motor
Cold Fusion Motor Drawings
TiAlCo-B Metal
Celestial Particle Transmuter
Celestial Particle Transmuter Drawings
Magnetic Motor
Magnetic Motor Drawings
Magnetic Heating Unit
Magnetic Heating Unit Drawings
Space Craft
Space Craft Drawings
I just obtained the book. I've yet to begin reading.
I've been reading other stuff than PP as it seems to be rounding off
the edges of understanding of PP .. as then I might better absorb
PP than I was during my initial readings.
Word of the Day: Diamagnetic
Web page above Commemorates
Mr. Howard R. Johnson (or Rory Johnson)
June 1st, 1919, – January 2nd, 2008.
an unsung magnet pioneer and visionary
Commentary:
Before Mr. Howard R. Johnson no one knew that a magnet can fire a momentary burst of energy a thousand times greater than its static field strength, repeatedly..... for the life of the magnet; potentially forever. Few people understand that today.
Mr. Johnson discovered that similar magnetic poles can be made to attract, not repel; and that standard texts teaching the patterns of iron filings around a magnet have mislead us about the larger nature of magnetic force fields, which are double helix vortexes of energy.
Mr. Johnson demonstrated that magnets meet all the requirements to be considered an example of room temperature super conductivity.
It is especially important to appreciate that Mr. Johnson did not utilize simple or ordinary concepts of magnetic repulsion and attraction in the design of his magnetic engines.
Johnson designed circuits to evoke exchange forces via sudden spin flipping, or reversals of magnetic forces, which can momentarily produce a reaction with hundreds or thousand times more force than the normal static field strength of the magnet.
When the "spin flipping" reaction is evoked, substantial macroscopic (clearly visible) exchange forces are generated.
Mr. Johnson discovered that through the assembly of magnetic materials in geometric patterns which he called "spin units" or "spin flipping units" such that when exposed to the magnetic field of another magnet in motion, would induce sudden spin flipping, or reversal of magnetic attraction into a magnetic release force such that a momentary and substantial release force would come into existence in the magnet circuit.
By controlling where this occurs in a rotor / stator relationship, this sudden energy impulse could be timed to produce remarkably strong linear or rotational propulsion force(s).
Sunlight causes vortex motion
We've been told light moves in a straight line, therefore this isn't light, is it.
Connect the DOTS.
Quote Link
Ehrenhaft and his colleague, Ernst Reeger, have proved that there is more than a little truth in the suspicion that tiny particles of dust tend to rotate when exposed to the rays of the sun. For they have not only reproduced this phenomenon in the laboratory, but they have succeeded in photographing it as well. In order to do this, Ehrenhaft placed tiny graphite particles into a glass flask, from which the air was completely evacuated. Then the flask was exposed to focused beams of sunlight. Instantly a large number of particles were seen to rise from the bottom of the flask and start to weave elliptical, circular and spiral-shaped paths, which were quite visible to the naked eye. The phenomenon ceased as soon as the light was weakened or cut off completely. Photographs taken at one-fifth and one-tenth of a second proved that not only were the particles orbiting, but more significantly, they were spinning on their own axis.
It is of interest to note that Ehrenhaft would like to relate the phenomenon to his own theory of a new type of physical force. He suggests that it is a purely ‘magnetic’ force which permeates throughout the known universe.
