Originally posted by Vortex
The Physics of the Primary State of Matter
Originally posted by Inquorate View PostHey, I just went into a trance or something writing on the self run bedini thread. Thoughts and impressions got in order.
Fluffy charge and magnetic fields make sense now.
Sweet.
Here's what I posted there:
re timing ; what if the coil's magnetic field collapses after the magnet has passed quickly enough, (to be honest I haven't done this yet - working with a pendulum so the magnet is at a standstill when I fire the coil) it will be a little like as if the core was magnetised by the coil acting like an electromagnet.
That bit is theory.
Experiment has proven that an energized coil (magnetic field) connected on one end to source negative will, if the power sustaining that magnetic field is abruptly removed (in bedini system this is removing the battery positive and there is no current, just magnetic field. In theory the same thing is happening with an abruptly collapsing core magnetic field with battery neg or ground connection and a neon. No current, rapidly collapsing magnetic field.) anyhoo, the voltage (radiant event / inrush of aether) causes a spike of pure-ish voltage.
Experiment has shown me that yes the inrushing aether will supply current from a no current state in a coil and will jump a neon to a place of lower potential.
and yes, the battery will charge if not connected to source battery but it will be fluffy and won't run a load.
This is because it is aether inrush. Like two waves meeting together that kick up a huge splash, the inrush seeking to fill the void left by the magnetic field (which was holding the aether inflow at bay? Like a high pressure system that pushes away low pressure systems in weather just disappearing, all the low pressure would rush in..
So the aether that jumps the neon into the battery is different to normal charge. Normal charge sucks electrons out of the battery positive.
Radiant charge places a condition of vacuum-ness into the actual battery.
So that won't run a load, but it will cause electrons to be sucked up from an actual ground.
Viola, the charge will be more able to bear a load.
I've lost track of myself. Hope it makes sense.
Oh yeah, I don't use a diode. Just neon and ground. Haven't yet done extensive testing; the above just came to me in last two days.
Is the spike aether pure? We maybe abil to do things with it like charge a crystal????
I like the trance thing Ben sometime I feel my mind is in the Ether alot. the wife said when i sleep sometimes she whats to wake me because i am almost panting.
I have a friend that had a crazy experince he almost die but he was woke by himself at the window, i showed him the remote viewing thing he said he already new most of the stuff in it!
I can talk to him in a way that is ...........Great........a brother with a true Understanding of Man
I'm glad we are so close to understanding radiant energy.
Look what I have written about it : http://www.energeticforum.com/renewa...html#post48056
It's obvious that Earth magnetic field is an effect on aether or aether itself !
@Vortex, I guess ancient people is not as dumb as what school teach us.
Originally posted by Bodkins View Postif you in a accident Im talking a really bad life or death one, time will slow down your body speeds up.
Interesting phenomena on metal capturing the static electricity. If you have the non insulated part longer, you can make the wind stronger. In my thin paper experiment I found out that static wind is blowing to the non insulated part surface.
I just notice that there is no shock in my current circuit, unless I gate both secodary output with my hand. Here is the video:
YouTube - Moving light, no shock when touching wire or bulb
There is no spark created when I touch the metal ball used as neon bulb antenna. My previous experiment give me 3mm spark to my finger. I can hold CFL wire and light it up as usual one wire without getting shock. I utilize the radiant output to charge battery. The battery charge so fast that I have problem discharging it LOL, the radiant is strong enough to light up 24V light, the battery still has voltage higher than source next morning. The charge can be measured and utilize as normal electricity. I think coil collapse spike I harvest is just a normal electricity with higher than source voltage.
Maybe I am closer to cold electricity ?
About fast magnet collapse, also see
Barkhausen effect - Wikipedia, the free encyclopedia
Although I still confuse what this means:
So the material magnetizes neither gradually nor all at once, but in fits and starts.
love the Grebennikov link,the static electricity needs more work interesting thing you have, sucahyo
Keep playing I need to read up and play with the setup i have too, maybe i can repeat what you have, whats you coil?
also in my last video
if you look at the diode its not letting the energy go from the white cable to the diode. so it should be coming from the diode to the white cable?
YouTube - Blowing WaterLast edited by Bodkins; 03-14-2009, 08:05 AM.
Besides the air, another medium is present
I thought you said the Electret didn't work? Also, remember that tesla pushed dimples into oil with wire end. It's aether gas free of electrons you're seeing; aether stream = gravity stream. Tesla made them into smoke rings to travel further.
Love and light.
oh, ps try putting ferrite powder into Electret mix and putting strong magnet perpendicular to Electret field. Dmonarch posted that it increases output. Also, try cooking it for longer, gradually decreasing temp over a day, with hv caps in parallel to smooth out the dc.
Ion wind?
Put cling wrap over surface of water, and see if it (water) still moves. Maybe Sucahyo could tried it also. Sorry but I butchered my hv circuit for the pendulum.Atoms move for free. It's all about resonance and phase. Make the circuit open and build a generator.
Inquorate and all
got a video uploading of A PURPLE NEON!!!!!!
2 alike in a unlike condition and a very powerful pop sparks thats kick off matter and it looks sometimes green.
Im hoping its the grays tube using PP to get the effect?
I will update this post with the video when uploaded.
Thank You Ben for being.
Caduceus Coil - Another look
Not to derail or side track, Maybe this needs it's own thread.
Caduceus Coil Short summary:
Zero Inductance (and for those like me: opposing magnetic fields cancel)
Boyd Bushman tells of opposing magnets decreasing gravity.
Wilbert Smith coil, different kind of Caduceus Coil?
RF in, no RF out.
Floyd Sweet device
JLN lab states "Soliton pulses is produced by an avalanche effect of the domains walls in the ferrite core."
I'm thinking Stress fields, potentials, gradients are here.
How to make use of them, i don't have a clue ..
Like water hammer, easy to make, hard to use for energy?
No data yet on torroid Caduceus Coil.
Spherical 3D Lissajous 18-Loop Caduceus Coil
Spherical 3D Lissajous 18-Loop Caduceus Coil and dual-monopoled magnet array
12 Loop Caduceus Toroid Red/Blue
Food for thought Images
Smith coil (different kinds of Caduceus Coil)
http://www.geocities.com/phoenix_ris.../section2.html
"So the coil was intended to remove all magnetic and electric components from radiating and leave only a shell of altered tensor energy, or altered time flow rate emitting from it. The true Caduceus coil does not have wires crossing over one another, as you can see from inspecting the symbol denoted as two snakes coiled around one another."
Wilbert Smith worked on a project that showed you can extract
energy from the Earth's magnetic field, called it a "magnetic sink"
which energy would "flow into".
http://www.checktheevidence.com/WBSm...mith%20Web.swf
Coil is on Page 26 of SWF
Worth READING: Logic and Logical Fallacies
Logic and Fallacies
Caduceus Coil over view of Properties.
Caduceus Coil
Caduceus Coil at JLN Labs
http://jnaudin.free.fr/spgen/index.htm
Tom Bearden comments about Caduceus Coil at JLN Labs
http://jnaudin.free.fr/spgen/tom_comments.htm
Highlights:
"This coil is further said to have zero impedance. Further, two or more coils cannot be coupled together."
"There are certain frequencies at which it is impossible to balance the RF bridge, and that is a direct contradiction to what any electrical engineer will tell you should happen with a coil wound on a ferrite core."
Note: source:Wilbert B. Smith: Gravity Control ~ Binding Force ~ Caduceus Coil ~ Letters ~ Circuit Diagrams
"Apparently the hole down the center of the core is necessary for its proper
functioning, as is an adequate power input. It will take a kilowatt comfortably,
without heating at all, and we know that it will work on 100 watts, but it
won’t work for us on 30 watts. It just gets hot on the lower power!"
Quest for zero point energy ... - Google Book Search
CADUCEUS COIL- Cetin BAL - GSM:+90 05366063183 -Turkiye/Denizli
Scalar Wave Detector
Floyd Sweet
What I was thinking of before I found this:
Wild & crazy Caduceus Coil interpretation
I did not read what they did or said at overunity... I didn't think I'd understand it.
Keely Net Mail List: Re: Energy/Field Questions
Internet Archive Wayback Machine
caduceous coil experimental handbook and my experiments with it.
A visual, Not saying it is correct, just a visual for thought
Earth's Magnetosphere
YouTube - Earth's Magnetosphere
Another visual Magnetosphere device
YouTube - Magnetosphere device
YouTube - Boyd Bushman Part 1
YouTube - Boyd Bushman Part 2
YouTube - Boyd Bushman Part 3
Just
