if you look at the diode its not letting the energy go from the white cable to the diode. so it should be coming from the diode to the white cable? YouTube - Blowing Water
Try reversing the diode polarity and see if the water still being move. I don't have HV diode so I can't try. In my experiment wind is created from both terminal of the secondary. In car coil this make all my circuit became wind creator...............
BTW, your video url is broken because of the emoicon.
I just finish reading first chapter of occult chemistry, some important point:
- matter has 7 state: solid, liquid, gas, E4, E3, E2, E1.
- E4 to E2 is what usually occur in chemical reaction, ion of atom.
- E1 is the primary shape, where all atom would look alike. Maybe transmutation point. At E1 Anu (particle) will dissapear or created.
- Three anu in line will make positive group. Three anu in triangle will make negative group.
- magnetic or electromagnetic can not be understand using occult atom magnification.
- Anu will be alligned to current like flag blow by the wind.
- Hydrogen Atom consist of 18 Anu in 2*(3*(3)) configuration. At E2 state Hydrogen consist of 2 positive and 1 negative (Gray's split positive?)
- Atom has 7 basic 3 dimentional shape.
1. The Spike Group
2. The Dumb-bell Group
3. The Tetrahedron Group
4. The Cube Group
5. The Octahedron Group
6. The Crossed Bars Group
7. The Star Group
- There can be shape which is derivative/combination of the basic shape.
From Glebenikov reading:
- The experiment is actually CSE, not static, sorry. The water in the jar is to prevent electrostatic interference.
- insect home can emit CSE which can be detected by human but can not be detected by device.
- Insect find their way home using this CSE.
- Honeybee CSE make human comfortable less pain while wasp CSE make human feel pain or nauceus.
- plant can not grow inside wasp home because of CSE.
- plant may grow better on influence of honeybee home.
- some insect has antigravity.
- cocoon move without muscle
- antigravity can distort vision, light and time
You said it moved water drops on the underside of the plastic wrap.
I still don't believe it rules out ion type movement in the water,
does it (I'm asking not telling)?
sucahyo and bodkins, Is your experiment matching these effects High Voltage Corona Wind
Water is all wet, fire is kinda cool, but starting fires is better, use toilet paper incense sticks or cones
if no effect blowing at bottom of Electret but has effect blowing at top of Electret then you know what?
YES PURPLE!
Why is it so hard to get a purple color light in the neon to show up
on camera. I see the "echo" is purple.
sucahyo, we can make a cross reference list between PP and occult chemistry
PP extends beyond E1 in occult chemistry and there are over laps
occult chemistry has geometry details not found in PP.
More words, a x-ref relationships gives a fuller view. This is like that etc.
I think when we expose the water surface with ion wind, it will ionize. Since I see other video of HV change water shape, I think this is normal property of HV to water. I also have tried toilet paper: YouTube - HV can attract paper
It is the same as the video that you posted,. Almost same voltage as mine although mine has a lot less current. Mine do not produce such a sound.
Anions are negatively charged ions
Cations are positively charged ions
If ion, then positive or negative could be determined using your Electret ?
This part confuses me, I redo it just now with my car coil. Although my current circuit has less power than in the video (but the transistor remain cool this time too), the water can be moved with either output polarity. All the action is push. The positive output of car coil wire push the water, the common negative output of car coil wire also push the water. I don't use diode.
I would be interested in that. I will read Karl book after Occult chemistry. as first x-ref. I think what Karl mention as primary state B is E1 to E4 in Occult chemistry. Where the state above them is energy.
@Bodkins, I think you should try the electrat further from electricity too. BTW, should anyone outside UK be able to see the video too?
How about a break from the stressfields for a while and enjoy The Fifth Element ?
What I mean let the fields flow freely, if I don't offend anyone...
Bottom line,
From Occult chemistry perspective, a conversion between matter and anti matter (energy) is possible only at E1 state.
My assumption: there can be transmutation in E1 if there is to much particle created/dissapear. A change in E1 will change the resulting successive state. If there conversion is done in both way in frequency, a disharmony may cause this. From this perspective it is impossible to get something out of nothing, matter converting to energy will be empty eventually, but a gradual decrease of thousand year wouldn't be seen as a decrease in our life time. And if energy is available around us in awesome amount of number then we can make a "tiny" matter everywhere.
barbosi
sucahyo
I need to read you research so im not going to comment untill i have!
but if you use geometry with the stressfield potential different i think we all would see eye to eye!
will be trying my stuff down the allotment to power the place, I think everone can see my videos WW not just uk are you uk?
still thinking ben
anyone mind ? No you daft sod
my last video i can light up the big tube after i turn off the power because im pumping the ground like tesla(pumping up a big ball)then let it off by tapping the top to the bottom of the electrat,this is what moray did at first.
I dont what to give up what i think the purple thing is because I only have words! until i video it and talk my way around it its just words.
love and light to all
randy not read any ion wind stuff you put up YET
