Avramenko's plug - Single wire power
  • #61
    1 wire with Imhotep relay
    Originally posted by AetherScientist View Post
    but can I send energy using only 1 wire with imhotep's circuit? I think no, but I would like to see you answer. Another similar circuit that I have heard about is the Brovin-Kacher.
    Yes, it works:
    YouTube - ‪One Wire Tesla Transmission‬‏
    It can charge a cap 1 wire 20-30 feet away, I've done it.
    This demo is maybe 10 feet of wire.
    The thing you hear buzzing is a single imhotep relay.
    • #62
      purpose
      The cap is used to charge a cap with a neon triggered scr to dump that
      first cap to a second cap - just to prove the point that there is something
      there and for fun.
      • #63
        Yes, it works:
        fabulous, and you know how this energy can be amplified? maybe some sort of transformer to step-up pure voltage?
        I have a video that explains something interesting about a similar one wire technique, but I don't fully understand it becausie it is in Russian.
        • #64
          Jiffycoil single wire video:
          YouTube - ‪Single Wire Transmission Test Pancake Slayer Exciter‬‏
          • #65
            1-wire to 2-wire transformer
            I have also found this on the net, a guy built a circuit to send energy through 1 wire and then he uses that single-wire as the primary of the transformer, then the secondary coil is a classic 2-wire configuration. There is NO gain of energy, simply a curious and fun test.
            The core is a toroid.
            • #66
              Greetings all, really enjoy reading all of your posts, and even some of your books, congrats all
              I have a question to ask about a single wire transmission circuit. (If it has been asked before, please accept my humblest apologies.)
              In the AFEP v1.2 by JL Naudin, How exactly does one connect the antenna to the Xenon Tube? (He clearly states that it won't work without it, so it must be necessary..)
              From his circuit diagram, it looks as though the antenna is simply a looped around the Tube. But how would that allow it to work? What am I missing?
              ‎"It's all in the MIND"
              • #67
                Induction !
                I imagine the antenna looped around the tube allows an inductive/capacitive transfer of energy. Similar to if a person were to hold the tube by the glass even if not grounded, the higher frequency allows an inductive transfer of energy between the supply and the antenna capacitance through free air, at the antenna the energy is radiated back to the environment or reversed back to the source, if the antenna was connected to one end of the tube and the supply the other it would be conduction as opposed to induction, ideally induction has no losses even though the resistance is high. I think.
                • #68
                  found a Russian vid on one wire for transmission of electricity; it even shows a circuit schematic (1:51 min, don't ask me what it is for i don't speak Russian )
                  YouTube - ‪один провод длÑ� передачи Ñ�лектричеÑ�тва‬‏
                  While I'm at it: Inertia motor Tolchin
                  YouTube - ‪инерционный двигатель Толчина‬‏
                  torsion engine Shipov
                  YouTube - ‪торÑионный двигатель Шипова‬‏
                  • #69
                    I have also replicated the circuit, but the neon tube doesn't lights. The only modification I made is to use 30 Khz pulsed DC, instead of 10KHZ as naudin recommends. I have made the antenna and something I'm missing because I don't see the same results.
                    Another question... there is any other form to "rectify" the one-wire energy?
                    I have seen in youtube some videos from people running small DC motors with longitudinal waves (before being rectified those L-Waves).
                    • #70
                      Hey AetherScientist
                      Thats strange. Hope you get it working. Did you also try it with a toroid?
                      Did you use Naudin's schematic? if so, which version?
                      A few parts I was needing to replicate this circuit arrived this week. So am hoping to do it this weekend maybe!
                      • #71
                        Hey,
                        No, I don't tried with a toroid. I used a Pulse-Width modulator at a fixed freq of 30 Khz (0 to 100 Duty cycle), 12 Volts 1 Amp power suply, and the by228 diodes and 1kv 0.22 uF cap. The cap gets charged because if you discharge it manually you can see a very good spark.
                        There are other versions that are more similar to Konstantin Meyl. But in those versions the people run small dc motors. For that you need to get polarized eleectricity.
                        In this picture, the author is using a similar circuit to make usable the energy. But I'm seeing that in the input of the rectifier (bottom right) the input are 2 wires.
                        http://www.panaceauniversity.org/Spa...20Stiffler.pdf
                        page 73, there is a similar technique made by dr. stiffler
                        • #72
                          load for single wire?
                          Hi,
                          I have replicated J Naudin's AFEP, however not all my parts have arrived yet, so I have everything except the parts for on the single wire, for powering the load (two diodes and cap etc)
                          I do have a small toroid though, and was thinking of connecting that for now (As shown in the video AetherScientist posted, http://www.youtube.com/watch?v=bhleqKFmB70). But I have no idea how much voltage and current I am going to get out of it, so have no idea what to put on the load. My meter only supports 600V. Any ideas please?
                          • #73
                            have you tried it?
                            I suposse you've received the electronic parts.
                            • #74
                              have you tried it?
                              Incredibly - no! The electronics store I ordered the parts from, has already dispatched 4 packages (one came today), but they still haven't sent the most important parts, HV diodes and cap! wow! Really hate having to wait weeks for things to happen.
                              What light bulb should I use on the toroid, and what turn ratio?
                              • #75
                                Ok, you probably wont believe this, but I went to the shop today and asked what the delay was.... they said that England would only receive the one part (0.22uF cap) in december! And then it still has to be shipped here.... wow... 6 months waiting not long enough?
