can you run multiple bedini motors in parallel?
pulling of diferent source batteries charging the same battery or battery bank?
thanks ww
yes you can can do that. but if you are building your own motor its is prefered that you use a multi-filar coil. each coil will have it's own transistor with paralleled outputs. you would use a common trigger wire amongst them all to syncronize them.
Matt
Reason: corrected incorrect word
the reason I asked and guess I should have explained a little more is I have 3 different small bedini motors.
just wondered if I could hook them all up to the same charge battery.
thanks ww
