Sun Eater variant
  • Sun Eater variant
    Hello, This is my first post here because now is the time that I thought I had something to say. I have been very interested and have replicated 2 bediniwheels, several silver colloid generators, 3 AROMAZ style high voltage lights, and a crude galvanic cell is hammered into my backyard. I think there is a bright future for humanity but we have to make it and teach others to do so as well...
    Anyway, I have been tinkering with my ground rod and I saw a schematic somewhere for "free energy" from the ground with an array of about 6 capacitors, 2 sizes. I made it, and can draw 11 or so volts from the ground with just the ground rod, and this circuit ramps it up to 14 or 15. I can tell I get 11 volts from regular copper 8 ft ground rod because I had it wired to my room and I Oscoped it, and the signal was very high frequency from 4 to 11 volts. I made sure my Oscope was fine by checking the square wave test output... it was fine.
    So, voltage is there and that's my proof, so that's why I'm diving into this area.
    I thought maybe I could squeeze that 14 volts through a 2n2222 and to a homemade transformer to ramp the volts up, but after testing there was not enough wattage stored in the caps to run the 2n2222 for more then maybe 1 pulse.
    This page BEAM Robotics Tek - The SunEater Series describes plans for small solar cell powered toy cars that measure their caps voltage and runs when it gets high enough, and shut off to charge more.
    These models work well (they say) at voltages from ~2.5 to .7 and can power an inductive load. The only problem is I can not use their advanced schematics because I am dealing with a much more erratic and higher voltage, which would burn out some logic chips... but we might be able to use this as a guide...
    I am asking anyone if they can come up with a higher voltage variant of this. To be honest I am learning more about electricity on this forum and DIY then I am in school... But there is still alot that I dont know, especially with microchips.
    Thanks!
    Welcome CosmicFarmer.
    Good to see you made your first post.
    I would suggest you add the other more important pole of your energy
    supply. Run a copper wire - insulated is OK, around your house/property - not less then 2 meters up from ground. You can then use that through a series of very small .22 or so capacitors and diodes together with your earth rod - Bridge rectifiier style and dump into bigger capacitors.
    You can get quite high volt potential, but almost no current (Amp). Anyway
    enough to charge my moble phone or some small flash lights. Bodkins did a
    lot of work on this. If you go to his posting list you will be able to read
    for a very long time and watch many videos on youtube.
    Therefore we need to find NEW ways, NEW experiments and NEW lines of thoughts.
      Maybe you can utilize it better as charger, by storing it to capacitor with very high capacitance and low voltage. When the voltage reach 2 volts more than the battery rating, dump it to battery.
        @Aromaz: That air antenna sounds like a good idea. I would imagine that it is like you said all volts and microamps... But the design "SunEater" charges up a cap, monitors its voltage, and discharges when it can move a motor atleast a step. In essence its a tiny solar panel powered car. Of course they cant pull much of a load other then themselves, but if I could turn it from a car to a fan, I could ventilate spaces with "free energy"...
        Right now I am content on calling the ground waves free energy. So if I can get them to do something more then be cool on the O scope and light LED's I will imagine I am progressing atleast.
        But the real request and reason I put this on the forums is how do you tailor a specific pulse just from caps and inductors... like if you wanted to pulse 14 volts exactly when a cap fills up. That question stumped all my electronics teachers who could show me combined ohm loss or total capacitance but actually had no idea what exactly they were. I'm not saying I know everything, but when I can stump my teachers, that's a bad sign.
        You would need to sense the voltage in the cap, which would discharge it when it gets high enough, so the circuit would have to sense it periodically, ala suneater2. But the suneater circuits are calibrated for a lower voltage more current signal then the ground rods give me. I guess its time for me to shut up and make it already :-) But I just wanted to know if there was a formula for capacitors charge/discharge. (example. you need XXXnf XXvolt capacitor with XXXX for 14v discharge when voltage gets high)
        Allright I bothered you people enough, peace
          Hmm this guy seems to be able to get measurable DC voltage from a grid of diodes.
          http://greenselfreliantenergy.com/imgs/diodearray3.JPG
          Which makes sense, seeing how a diode works, right there at the middle where the 2 elements meet would be a zone of rectification for ambient fluxes... and seeing how this thing works just as well outside as undergound in a steel box... It seems this poor man is taking to himself to manually construct a electrinum crystal...
          heres his webpage for the screenies
          http://greenselfreliantenergy.com/experiments/photos/
          Instead of ground-rod power, I like diode-power better... but those look really tiny!
