Cockcroft-Walton (CW) generator / multiplier produces a constant DC.
A simple two-stage CW multiplier
The CW is basically a voltage multiplier that converts AC or pulsing DC electrical power from a low voltage level to a higher DC voltage level. It is made up of a voltage multiplier ladder network of capacitors and diodes to generate high voltages. Unlike transformers, this method eliminates the requirement for the heavy core and the bulk of insulation/potting required. Using only capacitors and diodes, these voltage multipliers can step up relatively low voltages to extremely high values, while at the same time being far lighter and cheaper than transformers. The biggest advantage of such circuits is that the voltage across each stage of the cascade is equal to only twice the peak input voltage, so it has the advantage of requiring relatively low cost components and being easy to insulate. One can also tap the output from any stage, like a multitapped transformer.
Ref Link: Cockcroft-Walton generator - Wikipedia, the free encyclopedia
Lecture - 5 Voltage Multiplier I did not watch this video, just thought it could be helpful.
300KV Cockroft Walton multiplier home made caps!
I did not find this discussed on the forum, so I
thought it should be noted here as an alternative HV option.
Randy
Randy
