This is my effort so far on the Watson generator and it does not work as I connect all 4 coils in series and connect it to a 470uf, 400v cap which I tried to switch only when the voltage over it reached about 60v as described in numerous drawings on the web
On John Bearden website: The Tom Bearden Website
He said that Watson used series resonance!
I quote: “By adapting this mechanism, a free energy motor can be readily produced, as demonstrated by Bedini, Watson, and others with a battery-driven, series-wound DC motor unit”
Bedini on the other hand show in his generator booklet a parallel resonant circuit for each coil which makes more sense to me.
I tried it on a coil and the voltage output was significantly higher! Of cause you will have to measure the coil capacity in mH on than calculate the capacitor value
This dude on his website: Erwin's Work Shop
Bedini 1984 Radiant Energy converter
"The Watson Machine"
explains the parallel resonant effect used , but I cannot determined if he ever got this thing working.
John Bedini also give construction notes where he uses 6 coil of only 200 turns of 20awg wire. That gives me a coil of low resistance (2 ohms) ,as I suppose for parallel resonance you need low resistance, but the coil than measures only 8mH which give me a capacitor of 165uf(2x 330uf in parr) @ about 140hz which is the freq. with 6 magnets when the motor is pulsed(12v wiper motor) A big capacitor! I did not try it out with this coil and cap yet
I tested a222mH coil with a cap on a ssg motor and got a much bigger voltage at resonance. It also charged a big cap after the bridge up much faster.
Will try experimenting in the following week
