The Watson Machine
  • The Watson Machine
    Has anyone tried to replicate John Bedini's first free energy machine or as it has been refered to "The Watson Mchine"?
    I built one a couple of years ago, but had no luck making it a self runner.
    The problem was that, at the time, I really didn't understand what his machine was doing. I didn't know about pulsed flywheels, and I didn't know how to make fairly efficient alternators. I also wasn't very good at building commutators back then either.
    I think if I built one now, I'd have a lot better chance of making it run more like Bedini did. In any case, it was a good experience and I would recommend anyone interested to give it a go.
    Ted
      Watson machine details
      I think Ash (from Panacea) has a doc with quite a few details on the Watson Machine. Maybe he wouldn't mind if they're re-posted in this thread?
        Aaron feel free to use ANYTHING you need my friend, yes there is some details in the Bedini course on the open source uni site.
        Ash
          Im working on something similar at the moment. Gonna take my time though and have everything machined properly. Based on the window motor + g field or energizer on the same shaft.
            Watson Machine
            Mark,
            Check Ash's doc here:
            http://www.panaceauniversity.org/Joh...Technology.pdf
            See pages 78-82
              Bedini's Free Energy Generator
              Yeh ive been quite curious about the Watson machine from Bedini's Free Energy Generator book.
              As i can undertand, its about using an efficient pulse like motor (maybe a bedini) to spin a large mass, build up momentum and turn an alternator.
              I guess maybe the inertia / momentum of the flywheel can store enough kinetic energy to overcome unity. Once the machine builds up enough momentum u just have to tap it along momentarily. And when ur not tapping it u can dump the generated energy back into the battery
              Check out his video, this machine works on a similar principle to the watson machine - u'll have to skip to 1:00 hour exactly to find the part im talking about:
              zero point - Google Video
              -shlodo
              "If at first the idea is not absurd, then there is no hope for it." - Albert Einstein
              http://www.youtube.com/user/dodoshlodo
                The unique free energy machine, Bedini Free Energy Generator.
                1985 Bedini Free energy Generator is the only real OU dispositive.
                An adams type pulse motor, an alternator, and a pulse width modulator or reed switch to make pulses.
                The rectification process is not simply, because you have to make pulses in order to create radiant power, the energy flow from the alternator is pure zero dot, it is not conventional power, it charges the battery very well.
                An adams motor moving the wheel with recovery and a alternator connected trough pulses. It is OU. The generator causes little drag, because you furnish zero point power, only voltage, not current, and the kinetic energy from the flywheel helps to do this.
                This is my current project. I`m very busy now. I haven't too much time for it.
                  An often overlooked aspect of the Watson device is the flywheel. The combination of the pulsed DC motor and flywheel, when in resonance, will add significant extra energy into the system.
                  Getting this combination into resonance is the key to extracting energy. At resonance, the input current to the motor will dip. This is the optimal speed for the device.
                  The flywheel should have most of its weight on the perimeter of the wheel, as the Watson device shows. This type of flywheel will produce more energy than one with the weight centered around the axle.
                  IMHO, this is where all the energy is coming from. Nothing else is particularly unusual or OU. A standard dc motor, even though pulsed, isn't particularly efficient. The alternator Bedini recommends doesn't produce unusually high amounts of power either, in fact it's pretty mediocre. The only real gain I see is in the flywheel.
                  When I built my replication I didn't know anything about flywheels. I tried all kinds of different ways of making the electrical part more efficient but couldn't get it to produce more energy than it consumed. My flywheel consisted of a cylinder of lead shot, probably the least efficient configuration for a flywheel while being pulsed.
                  I hope this helps.
                  Ted
                    the flywheel doesn't add energy, only is there because one wants to convert mechanic energy into electric energy, and the flywheel acts like a kinetic energy capacitor.
                    The "energy" or aetheric energy comes from the pulsed alternator, nobody understands this.
                    The motor switches off because one wants to recharge the primary battery, nothing else, one can do a two battery setup and observe real OU. It is Ou because the motor doesn't stop and the alternator is not generating current, only virtual particle flow,/ voltage. Therefore there is a Lenz drag bending.
                      It seems that nobody understands the principle working behind the Free Energy Generator.
                        This thread must be revised, because 1985 Bedini free energy generator is the unique free energy generator.
                        One has to pay for the rotor rotation only in pulses, but it generates great spikes from the alternator.
                          I believe it was actually 1984 DW.
                          • #14
                            Negative energy is a MASS-LESS CHARGE WITHOUT ELECTRONS (or pure voltage, little current) that cracks sharply a system full of Atoms, AND BUILDS MASSIVE CHARGES , REAL DIFERENTIAL IN POTENTIAL , STEADY STATE, POSITIVE ENERGY , IN ORDER TO DO WORK OVER MASSES.
                            This is what Bedini talks about.
                            This is what i'm doing in my Adams motor now. Now with termoelectric conversors.
                            • #15
                              "We are only bound by the limits of our own imagination."
                              We perceive what we cannot see. We feel what we cannot hear. We strive for perfection in our thought models, but we seem to forget that sometimes it is the imperfections in nature that can help to make things work. --Bill Fogal
                              Priceless words
