High Voltage from Thin Air?
  • I did tune up my setup. I'm using variable capacitor for fine tuning. And I observed very interesting things. I don't need 2 diodes to light up neon, neon lights up with only one leg connected. Also I can light up 12V incandescent bulb at full brightness with just one end connected.
    Did anybody try to run 2 gates simultaneously? How do they affect each other? It would be my next project.
    Mike
    • Originally posted by mlurye View Post
      @mlurye
      The two circuits included are of a SEC15-20, one is the common one with four AV Plugs, the last three each power three LED's
      The second circuit in addition powers a 12V muffin fan along with the LED's
      Enjoy....
        @mlurye
        Everyone seems so happy to think they can run similar events without the AV Plug, 'BUT' if you want a CEC>1 you will never get there with out using the AV Plugs. Untold replicators have stated that they could power large numbers of LED's and do not need the 1N4148's, fine, but CEC<1 is always going to be where you are at.
        • Sorry DrStiffler,
          But it is not what I had in mind when I was asking about 2 gates. I meant 2 independent gates. And truly speaking it wasn't brightest idea. I did configure 2 gates and independently they were working fine. But when I was trying to turn them on together one of transistors were exploding
          Mike
          • Dr. Stiffler, what do you think about this statement:
            The counter-reactive transverse electrical potentials have to be stationed opposite the strongest longitudinal magnetic potentials. Out of this normal state of opposition the harmonic transitional point is created in the golden middle. This golden middle is the organic angle. It is the only true pathway upon which there is no upwards, no downwards, no sideways and no inwards, but only a movement in and about itself
            It seems to suggest placing a scalar wave generator next to normal wave generator, and get something in the middle.
            • @DrStiffler,
              Please correct the spelling for NiKola Tesla in your paper's Abstract.
              Thanks.
              P.S. Is the paper done yet?
                Sorry DrStiffler,
                @mlurye
                No apology needed, I knew what you were asking and wanted to try.
                • Originally posted by amigo View Post
                  @DrStiffler,
                  Thanks.
                  @amigo
                  Thanks, but its being proofed and I would hope to have caught this when the references were added. As stated, no its not ready, started at 75 pages and trying to condense and still keep relevant info.
                  • @DrStiffler,
                    75 pages...pfft, I can read that in 30 mins of leisure time, bring it on!
                    @all
                    I got a batch of transistors from Digi-Key today - ordered both ON and Fairchild. ON works as expected, pretty good, yet Fairchild is acting up on me.
                    Fairchild won't light up the neon bulb when I touch one wire end to the SGate while holding onto the other wire end. But if I hold the glass of the neon bulb and touch the wire to the SGate, then it lights up one electrode, close to where I'm holding the glass.
                    Yet, Fairchild will light up the FL just fine, the same way ON does.
                    Looking at the frequency spectrum I see nothing, it appears similar to the ON one, but I guess I would need to take photos and overlay them to compare visually. Even then I wouldn't understand it...
                    By the way, I did not have the ground connected, just a length of wire I use to connect to the water pipe in the bathroom. This tells me that we can have either true Earth grounds or aerials hooked up to extract energy from.
                    • About the transistors
                      Hello Dr Stiffler,
                      There are some troubles to find the right transistors to get the 'larger' effect on your basic low power circuit (lighting a Fluorescent Tube).
                      But as you said you have bigger devices, one being of 30W, I was wondering if it means that you found higher power transistors that can produce the larger 'Stiffler effect' ?
                      Or are you just using many small MP06 transistors in parallel ?
                      Thanks in advance,
                      MDG
                      • Amigo,
                        I've got mine MPSA06 here The Electronic Goldmine.
                        I bought 100 of Motorola and 100 of Fairchild. All of them are working fine, didn't have problems with any of transistors.
                        Also for tune-ups I'm using this variable capacitor 6 to 74pF Adjustable Trimmer Cap-The Electronic Goldmine in parallel with C1.
                        I had same problem as you describing but it is easily fixed by adjusting C1.
                        P.S. C1 I'm using is ~640 pF (470pF + 100pF + 74pF (var cap) ). My Lb Adjustable Slug Tuned Coil (Pkg of 4)-The Electronic Goldmine (using it without any modifications.)
                        Some more links of what I'm using with schema: NE2 Lamp w/ 22K Resistor (Pkg of 5)-The Electronic Goldmine, Small Incandescent Lamps-The Electronic Goldmine,Electronic Surprise Box-The Electronic Goldmine (tons of stuff you might need realy cheap), SALE! Giant 100 Piece LED Assortment-The Electronic Goldmine (not the best LEDs, but price is good), 1N4148 Glass Diode (Pkg of 100)-The Electronic Goldmine
                        Mike
                        • Dr Stiffler put up a new video.
                          YouTube - MRH2O2's Channel
                          I've experienced those standing waves in larger tubes. Looks like he has copper tape running down the length of it. Hard to tell.
                          • &quot;Waiting for parts in the mail&quot; SEC ---A quick build
                            I have been waiting for the transistors to arrive so I threw together a modified circuit that ran on (1) AA battery and lit up LEDs using the TIP3055. The way that I changed things around it may not be doing what it is supposed to do but it ran. Doc if you have ideas on what is good and what is wrong here please let me know. I want to get this correct when the all right parts come together.
                            I got the pieces for the Sgate yesterday at Lowes but haven't started building it yet. Thanks for the tips on where to get all the parts.
                            Here is the video of my (1) AA battery SEC.
                            YouTube - Dr Stiffler SEC 1 AA battery setup
                            Cheers,
                            Lidmotor
                              Cheers,
                              Lidmotor
                              @Lidmotor
                              I think you have a good handle on what you have. Yes it is a traditional oscillator with positive feedback from L2 to L1. As you stated this is not a Coherence Exciter although you should be harmonic rich which will show some results with the AV Plug and LEDS. I think we could explain this by dV/dt.
                              The one thing I mentioned with your first video was can you run without R1 after the oscillation starts? This in a SEC Exciter insures you are near the correct mode?
                              You are accurate in the similarity to the JT circuits and Frolov did state he observed coherence from a traditional oscillator design driving a Plug, although he was using a rather strange way of explaining it. He stated that you were required to tune the circuit to a point where the plug input was at or centered in the highest spot of a voltage node for the driving frequency, and this is fully understood, in my case with wide bandwidth I traverse multiple frequencies without regard for tuning the output and the plug does (because of probability) see multiple high voltage (also additive) points where the coherence takes place.
                              This can be seen in the fun little video I put up yesterday. The 4' FL is really used to study the energy packets and effects of frequency and phasing. The picture is dim, yet it can be seen. Anyway on a SEC Exciter you want to orient the coils for minimal feed back, but you can not get all of it out, even with shielding as this is not just RF.
                              Thank you for looking at a SEC Exciter (first video) and hope you obtain satisfying information and experience should you continue on into ESEC.
                              Let me one more time try to present a description of what CEC or Cohered Energy Coefficient is. CEC is not OU or Free Energy, it is very similar to COP yet COP is not directly applied to electronics (or should not be). Think of a vast lake on which multiple speed boats are running back and forth (the lake is the Energy Lattice) and these boats are all causing waves over the lake (multiple oscillations in the lattice) and you focus on a certain spot and watch the effect of the mixing of the waves, some additive and some subtractive. Now the additive waves can be a combination of many boats and not a direct result of just one boat (although possible under certain conditions) the energy if you measure it is the sum or difference of all wave energy present in your observation and can be found to be greater than from anyone boat, this is CEC. Now if you want to average the energy over time from all boats you will still get a coherence >1 above a single boat (the only one you are concerned with (Exciter), but the CEC of the whole lattice is =1. If it were not equal to one we would have a negative energy universe.
                              Hows that for the rantings of a mad man?
                              Good luck on the next circuit(s).
                                Amigo,
                                @mlurye
                                Can I ask you a though provoking question?
                                Are all combination's of L and C to resonate at the same frequency equal? In other words does electronics say that L or C should be dominate? Does it make a difference if you use majority C over L or L over C, they both resonate the same right?
                                This is a trick question, but those little coils, I have 1K of them and wish I did not.
