High Voltage from Thin Air?
  • Originally posted by Allcanadian View Post
    @Dr.Stiffler
    After reading my last post I can understand where you may have misunderstood my intent, I was being sarcastic in every sense of the word, which is by the way a bit of a Canadian trademark. I would agree with everything you have said, I find the notion that we cannot interact with nor extract energy we are litterally swimming in absurd. It is a little mind boggling when you think about it, I have to wonder at what point did everyone think it prudent to consider the infinite amount of energy external to our circuits as non-existent?. To make matters worse we know as fact that this energy does exist, we know where it comes from and we know that in order for this energy to have moved from one place to another that it must have occupied every space inbetween in some form thus it is everywhere. My first experience with this started many years ago when I found a crystal radio could power itself and a small load utilizing the "static" or white noise we hear "inbetween" the broadcast frequencies. I find it odd that there are literally no frequencies I know of that do not have these oscillations which represent energy in transition. I also found that a simple pulse motor could in fact be tuned to and recieve any number of radio station transmissions in a single instance when a headset was attached which is odd but still obvious. In another instance I used many parallel AV plugs with short leads to charge a capacitor from apparently nothing. Still there are people who say we cannot get something for nothing, I like to ask them a simple question---"can you tell me where this supposed nothing is?", at which point all I ever hear is silence.
    AC
    Well I would be happy to do that (off-line). My SEC Theory now has two opposing (competing) view from two very renowned Physicists and another one that has been somewhat tested and found to match a third idea. None of these are anything that is currently accepted, at least not in public.
    I think history shows that its all perception anyway and it make little difference what you call the thing so long as you can consistently work with it.
    • I wonder if other schematics of a chaos generator will work similarly to SEC?..
      They sure are hard to come by...
      ABC
      • just my 5 cents
        Originally posted by Tecstatic View Post
        Hi everyone,
        I just discovered that I can make ozone with my SEC cube.
        I have a crystal clear quartz glass "CFL" with a small mercury droplet inside.
        Just like I have lit my ordinary CFLs at the sphere, I could lit this 22mm diameter 24cm long "CFL". It has a strange light-blueish light.
        A few seconds after I lit the tube, I could smell the ozone, I don't think the production is high, but it smells ozone.
        Even though I only had it lit a few seconds, my eyes feel the effect of the UV light, normally used to sterilize water for greenhouses, to avoid plant deceases.
        Running a high power UV tube (2KW) makes much ozone.
        Have some of you seen this effect ?
        Eric
        Does not bedini talk about radiant energy like it was a gas? many believe that radiant energy have healing properties, the ozone can be a theory.
        I think the exiter and the bedini are simply different ways of capturing the same kind of energy. In the vid Energy from the Vacuum bedini shows a bulb glowing(conected to the ground and only to the plastic of one battery) just when the motor was running near to it (the same effect that can be seen in the exiter).
        Now the goal, instead of just exiting the radiant energy or just smell it a little, is to extract it to abundant excess usefull energy.
        I think that running a circuit with a load, showing the supply battery climbing the voltage for a long time, will be full proof, Maybe a supercap will be more convincing. Then we just have to put a voltage regulator or a zenier to separate the excess energy going to the supply batery.
        I believe this can be done, and that will not be long to get there.
        the party is coming!!
        • It's been awfully quiet lately. Doc, are you ok?
          ABC
          • Originally posted by ABCStore View Post
            ABC
            The good doc has stoped sharing publicly.
            • @Armagdn03, Is that a fact? Is there a reason why? I was going through the overunity forum and there some nasty people on there discrediting his work for the sake of it, some of them not even trying to replicate his work first, claiming it's been done before or its a tesla coil. If the Doc has stopped sharing, i can understand and i don't blame him. I slipped up myself by asking for a sec 18 circuit diagram without realizing it was copyright. I have had my own configuration running 20 led's for 4 days continuously from a 1.5v AA battery. I'm measuring 51v across the led's making that around 2.55v per led. They are 3.3v 13kmcd. After 4 days there is still just over 1volt in the battery. I hope others here continue to research this stuff, there is definitely something here that should not be ignored and Dr.Stiffler, if you are reading, again i apologize.
              • I recently stumbled across a wireless effect while playing around with the basic SEC 15-3 Exciter. Im short on LEDs right now but it does pretty good for what I have. Transistor stays cool, some fiddling with the variable inductor and I can get the LEDs pretty bright. The receiving towers seem to work well within a set range from the transmitter, its not always closest is best. Had lots of fun with this. Also had to knock the tops off the towers to get the effect easily, Im not sure how this changes the parameters...
                • Hi Ren,
                  How do you have your transmitting tower connected to the SEC 15-3?
                  • Harmonics.....
                    Hello all...I have pondered the Dr. Stiffler SEC Exciter for 5 months now including the Donald Smith Exciter both are fascinating... I have offered coments to see where they might lead and got some reaction...even built a small transmitter to see if I could get similar results and did to some extent...and hopefully the Stiffler board will still be available to me in the near future...
                    Why does the exciter have multiple bands on the spectrum analyser?
                    Also...Does the Avremenko Plug react to differences in phase and channel that voltage potential because the av lights up on virtualy any transmitter as I have tested this. I am not in opposition to any proposed theories about this just currious and hope for an insiteful response Thanks from Indy
                    • Originally posted by Zooty View Post
                      Hi Ren,
                      Hi Zooty,
                      Using the SEC 15 circuit. 22uH off the collector of the transistor has a 3 inch "aerial" of sorts which I just play around with and it snaps into sync with another tower nearby.
                      The + of the battery enters the circuit at the tap near the bottom of the coil.
                      • Question "operating frequency"
                        Hello;
                        I present a question to those that have a SEC Exciter, what is the minimum parts count (configuration) of an Exciter that is required to obtain HV in excess of 300V from an input of 18V.
                        No! you do not use a step up transformer and you do not use voltage multipliers. What you do is to ping the 'Energy Lattice' and capture the return.
                        Sounds and is simple. What is required is a 'Spatial Gate'.
                        See a new section I am starting at www.drstiffler.com/sgate.htm
                        Willing to participate here if you are a worker and not a talker like on another forum I left because it was full of dysfunctional people. I want to provide as much information to working researchers as possible, but will not accept ignorance.
                        BTW
                        I do not believe in OU, what it should be called is CEC for 'Cohered Energy Coefficient', which is a far more accurate way of looking at things. A conversion of one energy form to another with a 'mathematical' gain. No creation of energy, just a cleaner conversion between forms.
                        Hi Dr. Stiffler
                        I work on similar project like you and Davor Jadrijevic, and my setup work on 500kHz-1MHz.
                        http://events.ccc.de/congress/2009/F...6_wireless.pdf
                        DAVOR JADRIJEVIĆ – EMARD: USPJEÅ*NO IZVEDEN TESLIN BEŽIÄŒNI PRIJENOS ENERGIJE
                        I use 12-24V for driving coil, and I can start neon lamp near the coil. I dont have MPSA06 transistor and my try to replicate you work are not succesfull(hFE on used transistor is 40 and dont start to oscilate).
                        Can you tell me on wich frequency work your coil, because my setup have relation ships with parasitic capacity in coil, and wire lenght is in relation with electrical propagation speed and some in relation Lambda/4 for maximal potential on coil end ?
                        Your excitor circuit and emiting coil looks like more stable in work, and from schematics and my calculation from replicated emiting coil "63 turn 24 AVG on diam 16mm" seems to work on higer frequency "10-40MHz" if I'm correct.
                        Aston121506
                        • Originally posted by Aston121506 View Post
                          the link ?
                          • Dear Aston121506,
                            Dr. Stiffler's work is not really same as Tesla. And he does not like if you mention Tesla to him.
                            He might be tired of telling people over the years his system's difference to Tesla's...
                            He is not around about a month. I wish he is okay and release his replicable version of self running system..
                            I beleive he has very good understanding of lattice bending or aether twisting or elasticity of free space..
                            Please study on parametric resonance. I have been working on it for a while.
                            Also there are some effects in nature that you can tweak its feedback. I mean you make oscillation on first stage, and it has a net effect on the second stage. But no feedback is reflected to first stage..
                            With proper setup with an one wire electric transmission, load may not be reflected to primary part of the circuit..
                            We need to dig into it! Wireless power transmission is not important if you understand how to extract power from free space right?
                            Nuri
                            • Link
                              For tagor
                              For samedsoft
                              Hi,
                              Hi,
                              I really respect Dr.Stifler of work, and hard work from every body.
                              Interesting is the manner in which Dr. Stifler solve driver for "magnifying coil, but I think that the chosen way will not be able to continue to progress due to technical problems with high voltage and high frequency.
                              Magnifying coil can be driven and in many other ways and at lower frequencies while respecting the geometry of the coils of the desired frequency.
                              To start a magnifying coil is not needed "radio transmitter" and "great power.
                              I do not want to make the doctrine of the simple things, and I will explain the essence.
                              Requires a static electrical oscillator with a sharp ascending and descending edges between two different potentials which will be delivered in coils. Coil which has a higher Q-factor and the wire length is a function of wavelength. The coil creates "potential Standing Wave". If the account with Lambda / 4 at the end of the coil gets the maximum. So this is the "Electrostatic Oscillator" and not "the gates of nothing" :-)))
                              The magnetic field is min 5%, and electric field max 95%. All intelligence is in the wavelength and the choice part of the wave, or wave nodes.
                              With regard to Stifler hard to work with 300V potential difference, it should be put in a coil around 35-40W of power, but because of "bad" driver is not able to do so. Power is a function of square of voltage, and its pulse shape is not a quality and duration.
                              I will try in one of the following posts to explain more and preferably with the help of pictures.
                              Aston121506
                              • State of Stiffler Scientific
                                *Followers of Dr. Stiffler*
                                At last I have access to this forum. I have tried for months to gain access so that I can post for Dr. Stiffler. I only experienced a lack of response from the "admins". Every time I tried to gain access and moved through the sign-up process, I was told by return email that I would receive an email when my account was activated by the "admins". This never happened and just by chance I tried the account today and lo and behold it works, even when no one told me it was working. I think this is a bit of ball dropping here!!!!
                                Gentleman I will for the near future represent for Dr. Stiffler. I am a PhD. in Bio-Physics and have worked with Dr. Stiffler off and on for many years, only recently have I become involved in the current direction of Stiffler Scientific.
                                Dr. Stiffler and I and a few other associates have directed our total focus towards the pending disaster pending mankind. We have brought forth many of the water projects from which Dr. Stiffler perfected and we have in addition integrated the SEC Technology into my area of expertise.
                                All of this information will and is being placed on Stiffler Scientific web site so that people can begin to construct components to aid in their chance of survival when the breaking point of world order is reached.
                                Some area's of interest are "Water Purification", "Pathogen Control and Elimination", "Lesion Control" and of course SEC and the creation of "Cohered Energy". We felt it necessary to focus on "Water, Pathogens and Lesions" before we released the full SEC Documents as you need water and food long before you will need to worry about light. Although we are working on "Heat" sources that will apply to cooking and sterilization.
                                We "HOPE" to get all of this information on the web before the web is placed under controls that will prevent the distribution. "PLEASE" check the "SS" site often and copy every new item added, even if it seems of no interest to you or maybe stupid in nature. I can assure you it will all be of value in the coming months. Certain material we can not just place in open forum and as such we have created a number of papers covering many subject on "Survival".
                                Dr. Stiffler is no longer available for direct response in a public way, so please allow me to present the current direction and research that we all will need and require.
                                If someone has ZERO idea of what I am talking about, then please ignore all of our posts and our web site as it will not help or change your prospective or understanding of coming events and issues affecting each and every human being on plant earth.
