Originally posted by Lidmotor
First a bit of info I don't think I have placed in public yet, maybe wrong, brain cell loss great lately.
Anyway the voltage developed by a SEC 15-3 (PCB) is limited by two things, the Transistor and the type of Load. When you use a Neon, the Vo (voltage out) is limited to the breakdown voltage of the Neon. Now in the SEC 15-20 the design used multiple AV Plugs which each developed their own Vo and at the end of the line was the Neon that was limiting. When using LED's the Vo is set by how many LED's you have in series or parallel and will rise for a series string to a level that will cause the reverse breakdown in the transistor to destroy it. There is in theory the possibility of developing 'infinite' voltage, except we run into many, many limitations, such as the circuit itself, ionization, humidity etc., so limits exist, yet you can get it up there.
Another thing that set the voltage and I will not go into detail, is the bandwidth of the Exciter. Next is the bandwidth and what actually responds to the output, this is where people can sometimes light FL's and Neons and sometimes only one or the other.
Looks like you are getting a better feel for this little beast
Great work indeed you are doing.............
