Perpetual Motion Holder | Edward Leedskalnin
  • Ed wrote:
    Rays: When I reduce the material from which comes out the alpha, beta and
    gamma rays, so small when it is magnified one hundred times and appearing the same size as an average salt crystal, then there is no more rays, but has
    flashes the same as when a connected wire end is tapped on the battery's
    terminal, but without the red sparks. Depending on the size sometimes, I have to wait five minutes before I can see a flash. I think the flashes are caused by North and South pole magnets which are hitting and breaking the atom orbit, while the magnets are circulating in and around the earth.
    Gravitation must be caused by the matter in the middle of the earth, and more concentrated than Uranium. When Uranium atoms burst they release the North and South pole individual magnets that held the atom together, then the magnets scatter all around, but when the atoms burst in the middle of the earth, and many burst at the same time, they can only run from the middle to the outside.
    When the North and South pole magnets are running alongside each other and in the same direction, they have no attraction for the other kind. They only attract if they are running one kind against the other kind. When the magnets are running out of the middle of the earth, as soon as they meet an object they attract it, on account of the fact that in any object there is both kinds of magnets in it. Ed. L
    • Ed wrote:
      Geologists do not know what gravitation is, and what causes earthquakes and mountains. Perpetual transformation is going on with this earth all the time. When the atoms burst in the middle of the earth, the magnets are running out from the middle, and so cause gravitation by attracting the matter that is in front of them, and when many magnets have come out, then there will be contraction that will cause earthquakes and mountains. ED.L
      And also:
      Get four pieces of wire size sixteen, six inches long, two copper and two soft iron, bend one end of each wire back so the clips can hold it better.
      Put the soft iron wire in the clips, connect with battery, have the wire ends square, now put the loose ends together, and pull them away.
      Put the ends together many times, then you will see which wire end gets red first, and which will make the bigger bubble in the end, and watch the little sparks coming out from the bubbles. Stretch the bubbles out while they are in liquid form, then you will see in the bubble that something is whirling around. Those little sparks you see coming out of the bubble, they are not the magnets, but the magnets are the ones which throw the sparks out of the bubbles. When all the magnets that are in the wire, if they cannot pass over to the other wire, they are expending the bubble and running out of it and carrying the metal sparks with them. When the bubble is cool, break it up, then you will see the space left where the magnets were in. Ed. L
      • Hello All,
        I am wanting to replicate this and was wondering where I might find some good parts to order on line. I would love to have the U shape and bar as close to spec as possible.
        And some very detailed coil specs would be great. As in wire type coil size and etc.
        Thanks!
        -Altrez
        • I would download the pdf.
          http://freeenergynews.com/Directory/...alnin_51pp.pdf
          page 28 and 33
          1018 is the most common high iron and lower carbon steel. Wrought iron might be better but its almost impossible to get and very expensive. Unlikely you can buy a U shape so you would probably need to take it to a shop for bending. Whether there is a major difference between square stock or round stock I dont know. Pmh holders have been made from both.
          Speedy Metals - 1-1/2" {A} Sq Cold Finished 1018
          Aluminium spools can be made.
          McMaster-Carr
          • Originally posted by Iotayodi View Post
            page 28 and 33
            McMaster-Carr
            Thank you so much!
            • .7129 and .6105195
              Physics Model
              Hey Van, what i meant was square the numbers by squaring one hundred times any other number ends in a nine before it goes back to one. Try this with both numbers, .7129 and .6105195. That point is the infinite point. Super conductivity and super fluidity show us that the infinite exists. Any number that you do this with with either come up ones and zeros, or nines. Pi shows us the infinite by squaring the numbers .7129 all the way back near zero you will get 98. That is the point of incidence. Square the next one, .61059195 and you will get the same thing, .99998. then it goes to one??Every other number squared to the end becomes.99999 one. EVERY ONE BUT THOSE 2....try it...pull up your windows calculator and see for your self ....see how they are a line of either 99999s or 0000000s Notice how the ones and zeros co-relate to the shape of inside a sphere. The inside of the sphere is equal to one. draw a circle....imagine 99999s with their tails sticking through with a 0 on the outside ...with a value of 1....a FULL sphere ..EVERY WHERE BUT 2 POINTS....do the calculations again .... But yet, every quarter is equal to one. now multiply .1 times .314 We know about super fluidity, super conductivity etc. This proves infinity. expansion at a ratio of one to four Leedskalin's numbers show us the angle of the infinite ray. Think about it like this, you are standing on a bubble and the floor is zero degrees and infinite. At eye level is the next boundary level. An infinite point is an infinite line, inside of a sphere is equal to a point mathematically. Pi times radius squared. Now you realize that it is a reflection of the infinite. No matter what number you put in a computer calculator etc. and square it a hundred times only two numbers end in 98 before they go to one, this proves the infinite ray mathematically. Infinite ray is unidirectional, infinite line is bidirectional. Infinite line can become infinite disc, infinite bi-directionality gives us spin which gives us attraction and repulsion which is magnetism and gravity. Why is pi only infinite at one point? Because it is a perfect mathematically correct reflection of the infinite. Phase shift problems with parabolic mirrors, the reflected ray from a parabolic mirror does not phase shift again. The main ray upon reflection shifts. This proves reflection. The Electron Phase Shift some of this theory applies also.....i need to post this but my next posts will be Leedskalnins method .....and the experimental proof that is irrefutable......pull up your windows calculator in the mean time and see......david
              • Wondering if this is the "L" in ED.L.. Maybe this is what the bottles are used for... maybe not. Just thinking through drawing.
                Not many people have made his "best" electro magnet... core, wrapped with coil, wrapped in a tube, with the tube capped touching the core but not the coil. He noted that this was his best "lifting" device.
                rw
                My Calloway V Gate Motor Video
                • Could you explain the "L" a little better to me? Thank you
                  • Originally posted by redrichie View Post
                    Take a look at this video from LS: YouTube - LaserSaber Air Battery Update!
                    He's driving the wheel with a vert coil. I'm wondering if the same could be done with the upside down L and the flywheel... and the ED is the generator to power the L. But the L also has the arm that cuts through the vortex of the spinning field and may cause a sine wave through the steel arm. This could be converted with a coil to drive the inner tube coil... just thinking out loud.
                    The pipe that is in the back left side of the flywheel could be the upside down "L". It has an angle iron extending up and then a horizontal bar going over the back side of the flywheel, about 2 feet above the magnets. In the photo of Ed turning the wheel there is something sitting on top of the pipe, but it's hard to see due to the rez of the photo and the tackle in front of it.
                    Take another look at Cody's post regarding flywheel sine waves here: http://www.energeticforum.com/renewa...tml#post120265 I'm wondering if this could be going on with the L.
                    "To make magnets from a dynamo and then to a wire you must start from the middle of the wire..." EDL
                    "Magnetic currents are made by concentrating, then dividing and then shifting..." EDL
                    What if the top bar and angle iron do the concentrating, the bottle coil does the dividing of the magnets and the inner coil and tube shift the magnets and form a vertical electromagnet that can do work. Ed's strongest electro magnet is a core, wrapped with a coil, surrounded by a tube, with the tube in contact with the core.
                    Or, could it be working the other way around...
                    rw
                    • YouTube - Atmospheric Ionization Research Coral Castle round Magnet
                      • ...........EDIT: Wrong thread to post this in... sorry
                        moved here:
                        http://www.energeticforum.com/renewa...ead.php?t=7388
                        Last edited by SuperCaviTationIstic; 02-10-2011, 04:43 AM. Reason: Wrong thread to post this in... sorry
                        • Hi guys, I just came across this thread, the experiments that have been discussed here are interesting. I'm glad to see that so many others are intrigued by Ed's accomplishments, and theories about magnetic current.
                          My Grandfather sparked my interest in Ed, and the Coral Castle in the mid 90's when he told me about the classic In Search Of episode that chronicled what is known about Ed's life. We visited Coral Castle in 1998 and It was amazing to explore Ed's domain.
                          About the PMH, the magnetic current effect that Ed discovered has found practical use in industrial automation electronics. Latching, or Bi-Stable non-permanent magnet relay switches are essentially small PMH's. Check out the info below from Omron about how this type of relay functions.
                          • joukle thief with cop?>1
                            hi
                            i've been working on this design of joule thief,and i am able to get a cop of >>>1..
                            here the circuit--
                            Free File Hosting & Video Downloads, Free File Sharing, Online Friends Network - Ziddu
                            coule anyone verify it??
                            thanks
                            • PMH design
                              Good morning
                              This sounds like a very interesting concept and I would like to replicate it. However this is a very long thread. Does anyone have a schemtaic and design for a working working?
                              Bizzy
                              Smile it doesn't hurt!
                              Jesus said,"...all things are possible through God." Mk10:27
                              • Here is a video that is an application ( I think) of what Ed did. Hope it is of some use.
                                YouTube - 11Turion's Channel
                                David Bowling
