Pk Wheel Physics
  • Pk Wheel Physics
    Though this topic would seem more appropritate for the psychic forum i am posting it here as I am interested in the phenomon of it and would like to discuss it.
    For those who havnt heard of the pk wheel i will give a brief intro. Put simply it is just a very light weight wheel balanced on top of a fine point so as to present the least friction. The goal is to rotate the wheel using your mind. For most it is relativly easy. Some have to put there hand close to it others can sit on the other side of the room while others can rotate many wheels at once.
    I have been trying for a while off and on to get the wheel to rotate when covered in this case by a plastic container with little success. I would have the odd ocasion of success but it was short lived and very minor. Last night i noticed that the wheel was actually moving while covered by it was vibrational. It would not rotate as such but just sit there moving back and forth a little bit. My first attempt at solving the balance was to simply place one hand on one side of the square container and see if any effect and there was none. My second attempt was to move the container such that the wheel was instead of being in the center was now either on the left or right side. This did work the wheel would rotate and as long as you were positive and followed its rotation it would continue to do so. If you were negative it would stop. What was interesting about this was that there was a recoil. Unlike when uncovered if negative the wheel would just stop the wheel now recoils in the opposite direction. As well there is a limit to the amount of rotation the wheel can carry when moved to one side. It will reach that limit of rotation and like a wound up spring rotate in the opposite direction. It wouldnt return all the energy but does return some it seems.
    Another very interesting aspect is that when the wheel is placed on the left hand side of the container it rotates clockwise and when on the right hand side it rotates anti clockwise. If the wheel is on the left side and having reached its total rotation capacity you simply move the container so that the wheel is on the right hand side of the container.
    The effect appears to be due to a polarization which causes a seperation of the normally joined counter clockwise and clockwise components of aether which are one when the wheel is uncovered.
    I think thats it. I was playing with this all last night and then put it away and could not reproduce the effect that night. Today i feel well disjointed to say the least, spacy and tired. I dont know if it has anything to do with it but worth a note.
    For the sake of completeness I include a few stats which may have an effect on the results. I am male, right handed and live in australia. Whether or not any of this data effected which way around the polarization occured i dont know.
    Damian
    Experimental Investigation of Biologically Induced Energy Transport Anomalies
    Damian,
    These docs are fundamental to understanding what has been done with this concept specifically in one time frame.
    Experimental Investigation of Biologically Induced Energy Transport Anomalies, (file 1) Hungarian Academy of Sciences, Central Research Institute of Physics, Egely, Zip file 8.33mb
    Experimental Investigation of Biologically Induced Energy Transport Anomalies, (file 2) Hungarian Academy of Sciences, Central Research Institute of Physics, Egely, Zip file 2.19mb
    RPX & MWO http://vril.io
      Hi Damian,
      Your wheel description reminds me to a Hungarian inventor, György (George) Egely who created and has been selling such a wheel. He named it Vitality Wheel.
      His wheel was criticised by some persons by saying the wheel rotates by ambient air movement (in spite of versions with plastic enclosure) or by the person's body heat or/and breath etc.
      Well, I hope the wheel turns by human body's so called 'bioenergy' and as such it could be a useful indicator for one's present state, though I think a person can feel how she or he feels when getting up in the mornings...
      What you mentioned: I was playing with this all last night and then put it away and could not reproduce the effect that night. Today i feel well disjointed to say the least, spacy and tired. I dont know if it has anything to do with it but worth a note. Well I think your experiments and your disjointed feelings are surely interrelated, so this is warning sign you should keep some intervals in such concentrations!
      Here are some links on the Egely Wheel:
      Egely Research Co. Ltd. - Egely Wheel Products
      Egely Wheel Vitality Meter
      Altered States *
      rgds, Gyula
      EDIT Just noticed Aaron links to Egely papers. Egely is also a free energy / overunity researcher.
        Readings
        Hi Aaron. Thanks for the links. They are very good and read them when i first got my wheel.
        Damian
        Damian,
          Hi Gyula
          Yeah you hit it dead on. The wheel i use is an Egely wheel however you dont need to and anything that freely moves will work. A while ago i made up 5 wheels and had them all rotating at once which is very neat. What i have found is that if you just relax the wheels will rotate without you even focusing. The better you are at relaxing the better they rotate. This correlates nicely with Reich mentioning that orgone is absorbed in relaxed muscles and when tightened is not. I can confirm this as well. If you tighten your muscles it kind of condences above the skin in a steam like nature very cool.
          I just tried the experiment i tried last night tonight and it still works admitingly not as much as i didnt get time to relax but still noticable.
          Some people seem to feel that we have all the answers on this topic and to just leave it alone however i am far from convinced. I would love to see technology directly based upon it.
          Damian
          Originally posted by gyula View Post
          Hi Damian,
          Altered States *
          rgds, Gyula
            That is awesome, today was a second day practising and it was much better that yesterday. Is hard to say at this time but it helps to do it, instead of trying to do it.
            I may get flamed for this (people before got offended by not giving references to a joke I posted and they lost precious time to google and find it was a joke LOL). So skeptics and "accountant" type mentality people you may google or not, it works.
            Thanks for this thread!
              Great Stuff
              Your welcome Barbosi. Its quite neat seeing it spin around getting faster and faster. Other things you can practice are spinning from afar. Spinning when covered. Spinning many wheels at once. Your imagination is you limit. We need more people like you to experiment with the phenomenon. Great work. Dont let they nay sayers or grumpies stop you from experimenting. Some people seem to get very annoyed and anti when it comes to this topic which is highly unusual given the nature of this forum.
              Good Luck
                Egely
                Hi all,
                Egely Wheel can change your caracter and the way of thinking!
                http://www.egelywheels.com/how-to-create-a-spi-ball
