Reply to Shamus:
Hi Shamus,
No, having a shorter array in the magnet group would not be beneficial. Here's why:
The attraction accelleration at the front end of the group does provide half of the motive force, just as you suggested, while the repulsive attraction at the tail end provides the other half. In between the two ends, there is an equilibrium effect, which does not provide motive power to provide rotation, but neither does it oppose rotation, and that's what is important to remember. Having relatively long magnet groups thus allows for slower movement of the stator magnet across the wheel rim, and this equates to less effort expended. Also, a gentler curvature of the timing track results in less drag. Something has to ride the track to provide the timed movement of the stator, and the slower that we can move it (and less we have to move it) are two very important factors in making this MOSTAT design viable.
Now there is a reason why I chose groups with ten magnets, versus groups with 15, 20, or 25. While the equilibrium effect does not in itself impede rotor travel, the rotor definitely will slow down somewhat if allowed to pass through a long array of magnets, thus losing some of the accelleration that you had gained at the front end. It would be comparable to pressing in the clutch pedal of your car once you get it up to 65 miles per hour, and letting it coast. So if using long groups, the speed of rotation would waver noticeably, it would take longer to reach a certain rpm level, and your maximum rpm level would be somewhat less than with shorter rotor groups. My experience is that groups can be anywhere from 8 to 12 with fairly decent results, and so I chose the mid point of that spread, which it seems should be optimal.
I hope that helps everyone to understand better that there definitely are good reasons behind the things that I do. These were good questions, and I thank you for bringing them up.
Best wishes,
Rick
Best wishes,
Rick
