Reply to Mark:
Hi Mark, and thanks for the note and kind words. Actually there is a space of about 1/16" between the outside roller and the track, but it just doesn't show in the photo because of the angle. It also can't be seen (because of the fender washers) that I cut a short slot in the polycarbonate for one of the the roller axle screws so that I could have an adjustable gap between the rollers, and this also allows me to change over to the 1/4" polyethylene track material. Today I am working on the slider bar mount, and keeping it very simple. I'm trying to keep everything maximally adjustable. You can see that the roller axles can be raised easily to allow the stator magnet to be dropped down lower,and that the the polycarbonate stator carriage can also be raised up closer to the slider bar to widen the stator/rotor gap. In the photo, the carriage is already lowered to its maximum level from the slider bar, so I need to raise the carriage up about an inch before attaching the slider bar so that I will have an adequate amount of adjustment to play with. I also plan to make the slider bar level adjustable.
Regarding your solenoid idea, of course that would certainly work. There are 2 reasons why I won't try something like that, though:
1. First of all, I'm hoping to be able to achieve the desired rotation only by mechanical and magnetic means.
2. Using any portion of the potential electrical generation that the unit can produce, for the sake of attaining stator movement, will of course substantially decrease the remaining electric power that would be available for other uses. In the end, if nothing else quite does the job then we may have to resort to this, of course. For example, if a segmented track is used then the stator could be shifted at the precise moment needed by using a very short repulsive burst from an electromagnet correctly positioned for this purpose, and that's probably close to what you are thinking about.
You could certainly try experimenting with this idea to see what your power requirements will need to be. The more people we can get involved with experimenting on different aspects, the faster we will achieve success.
Best wishes to you,
Rick
Best wishes to you,
Rick
