This photo shows how the linkage rod is attached between the slider carriage and the pivoting stator control arm. The stator magnet and mount has been removed in this photo to
allow viewing of the attachment detail. Notice that the photo also shows modifications that have been made to the pivoting stator assembly method of attachment to the slider rail
bar. This new attachment method allows offsetting the stator assembly from the slider rail a distance that will allow the slider carriage to be inserted or removed from the slider rail
without interference from the pivot bolt of the pivoting stator assembly. Note also that when the slider carriage and pivoting stator assembly are mounted to the slider rail, the
linkage rod will be directly in line with the slider carriage, rather than at the angle shown in this photo.
Although not labeled in the above photo, the measurements for the drilling of the attachment hole in the slider carriage are 1.75 inches from the carriage end and 5/16 inch from
the carriage side. It is possible that in actual operation the linkage rod may need to be attached closer to the centerline of the carriage, as it may exert enough pressure at the
side of the carriage to create a binding effect in the slider rail. I am hopeful, however, that the straight line action of the linkage rod will prevent noticeable binding.
