Reply to Mart, plus ideas on possible rear wheel usage:
Thanks for your input, Mart. Glad to see you in here. Yes, as I pointed out in post #1, this setup can be used either horizontally or vertically, and is perfect for multiple uses, which includes SSG builds. Like you say, one could prepare two or more wheels for different uses by premounting them on plates, sliding them into position in the frame, and bolting them up. Of course each wheel has two sides, which already allows for two different uses. The framework allows for standing it in 5 different orientations, if desired. If used as an SSG stand, the SSG coil (or multiple coils) can be mounted easily to the framework in such a way as to make them easily and precisely adjustable. There are any number of ways that can be accomplished, and one such way would be to mount them on a device similar to what I will be using for the stator arm in this project. Actually, once this magnetic motor is up and running, I will be attaching some Bedini type coils to the frame to turn this motor into a generator. I don't expect to be able to run the magnetic motor at a high rpm, but consider this: If I can accellerate the motor to just one revolution per second, and if I have about 60 small neodymium magnets placed around the rim, then I will get 60 cycles per second through each of the coils. Similarly, if the motor runs at 80 rpm (1+1/3 revs per second) then 45 magnets would offer 60 cycles per second. With your extensive SSG experience, I'm sure you can see the possibilities, and I'd love to hear your thoughts as to coil size and circuitry to maximize the potential output. It seems, of course, that the generating coil or coils should be air coils so as not to adversely affect operation of the motor. What are your thoughts concerning the coils?
Thoughts on using rear wheels:
Some might suggest that a bicycle's rear wheel, with sprocket, be used instead to drive a chain that would then drive a small generator, but there are several drawbacks to that mode of operation. First of all, that type of drive mechanism would create substantial drag. Secondly, you would need substantial rpm of perhaps 2,000 at the generator, which would not be possible from a magnetic motor running at only 60 rpm. That would require a 1:30 motor:generator gear ratio, and it is doubtful that the motor could even handle the stress of a 1:1 ratio. That said, there are two advantages to be had from using a rear wheel:
1. A rear wheel has a larger diameter axle (which is stronger and longer than a front wheel axle) and larger diameter ball bearings. This equates to a stronger and more stable build. This would require drilling the mounting plate axle support holes larger, of course. To accommodate the added axle length, one or both plates could be moved to the outside of the frame's plate support members, as necessary.
2. If the sprocket is held in a fixed position, rather than being allowed to freewheel, then the ratcheting action built in to the sprocket assembly will only allow the wheel to spin in one direction, and this is quite desirable when swinging the stator arm into position to interact with the rotor magnets and begin rotation. Actually, the only reason I did not choose to mount the rear wheel of my salvaged junk bicycle is because it was way rustier than the front wheel. I may work on cleaning that up when I have time, though, and then mount it.
I will be posting construction info later today concerning frame alignment and stabilization, and leveling mechanisms, so watch for this.
Best regards,
Rick
Best regards,
Rick
