Reply to Stealth:
Hi Stealth,
I think what you mean in your opening sentence is the same as what I pointed out in point #4 of my previous post. Is that right? Any higher up, and there would be no rotation. In Mylow's original working setup, with the horseshoe magnet, his "sweet spot" was where the lead-in magnet of the group was positioned just past the point of equilibrium between the stator's south and north poles. This provided the startup thrust that was needed. In his new setup, the "sweet spot" for startup occurs at the point where the stator magnet's upper south pole face is ahead of the lower north face at the tip, and is close enough to the stator group to cause attraction that draws the group in toward the stator. Yes, the latest setup could run in either direction, as you say, whereas the horseshoe stator had to be reversed to change rotational direction.
Best wishes to you, Stealth. May the magnetic force be with you.
Rick
Rick
