joule ef radiant charger/oscillator
  • joule ef radiant charger/oscillator
    last few days were really exciting for me cause i was able to recharge my 12v 7 amp hr and 3 6v 4.5 amp hr batteries with your joule thief charger design.......
    it really works great and i made it by using a torroid and it really worked great...also its very small in size.....
    Nice Work shubhamforme, this looks good.
    How long did it take, to charge this 7Ah Batterie?
    And how did you put the Layers on it, just one by one or trifilar or opposite Direction in Winding ?
    Btw i played lately a bit with a JT around too, and did put a unpoled Cap parallel to the Potentiometer, what seems to cause lesser Power consumption. I think, he pumped a bit from the Triggercoil back in Direction Source, but i am not sure, if it makes the Pot lesser usefull.
    I tried it only with a 9V Block and 2 Aircoils, and still did some other Things then.
      hi,joit....
      i've put all the 3 wires in same direction and winded them together about 100 turns on a slightely big torroid 4 cm outer diameter and in clock wise direction........
      it charges my 7.5 amp ups battery...within 16 hrz to 13.8 volts.......its really amazing...;
      all the best and do let me know if you replicate my circuit...tc
        radiant joule thief charger
        yes by putting a cap parallel to the pot , it will make the power consuption less to reasonable results but it will also reduces the voltage spikes needed to recharge the battery.....
        it might help when you want to lite led's with it ... but it will never nelp in charging battery...because there is a simple rule here...== more voltage spikes===more charging of battery.......
        the second circuit which is my hand drawn...uses just a mobile charger as a powersupply,,which is also used to recharge my motorola cell phone ..i think its a 5v 500 mili amps charger .... and my radiant joule thief charger gives more than 1000 volts of spikes when the pot is turned to minimum ...i.e to 100 ohms....
        it charges wonderfully.....
        here are the pics of my charger.....
        see its working on my cel phone charger....
          circuit unclear to me
          shubhamforme:
          Nice wrok! I looked up your circuit, but it seems not very clear -- some of the joints look ambiguous (maybe I am just not familiar with the convention).
          lanenal
          Originally posted by shubhamforme
          here is the original circuit, which i ue ..it is really very simple and chaep setup...every thing inculind will not cost more than 10 us$....and it works great....
          the coils are rotated together to make them perform better...
          the coil is made from 26 swg of wire and the ratio is 1:1...
          the torroid contains 100 turns of 26# wire ...and the inductance of both coils is 400 mili henrys......
          the 1k pot and the small 100 ohms resistor are both 1 watt each....
          do not supply more than 9v to this circuit and it will charge any 12v battery with 6v..and produces 500v spikes with just 6v... also using more more than 4.5v will slowly burn the neon so use a 10 k 1 watt resistance in series with the neon....
          the setup should work great......
            new solid state very easy overunity generator "fleet"
            look at the circuit and you will understand everything...
            kindly go through the circuits and let me know the results if you try to replicate this generator...
            thx
              other circuit details
                Posting everywhere
                You have posted an interesting circuit. But it is very annoying for you to post info about it on every other thread in the forum. Most of us look at the any new thread to see what it is about and if it interests us. We don't need someone posting about the new thread in every other thread we go to read. This is called spamming. You can be banned for doing it. I hope you only get a warning because you have posted some interesting info. Please just post in your thread or maybe one or two other appropriate threads. You have posted in threads that don't have anything to do with your subject.
                Carroll
                  Looks like a copy of A Patric O Kelly Ch 5 Pdf document
                    It is just a copy.
                    http://www.free-energy-info.co.uk/Chapter5.pdf 5-34
                    Well shub, when you are so excited about the Device, feel free to show the results.
                    But you need to compare Power goes out from the Source - Batterie, measured at Ampere Hours,
                    and Charge Amount from the Target, measured at Ampere also.
                      i am testing this circuit
                      thx for your reply...i will continew testing this circuit
                      kindly add youself to its yahoo group
                      at-- energythief : ENERGY-THIEF overunity generator
                      thx
                        Here is more about the Topic, ltseung seems do play more with it around.
                        Pulsed DC Transformer with Embedded Magnets
                        They use Aircores or more Plastic Rings, what seems work better as ferrit cores.
                        What i have seen also, that magnetic Cores makes a additional certain Frequency,
                        it is just like, as if you add another Load.
                        Another Thing he did mention at the Thread was, that ltseung worked a while with Pendulums and lesser with pulsed Systems.
                        I may will play a bit around with it, anyhow i think, there depends something on the thickness of the Wire and the lenght, but well, need to see if it works that good as they claim.
                        But at all, i did have some good results also with Bifilar Coils wound on the same Core, and pulse it with another Coils.
                        It was like, that the Impuls did interact into the Bifilar Coils,
                        and not like it is usually, just go throught.
                        The Circuit what they use so far looks pretty like the one from this Document,
                        so still a bit open, to play around with.
                          JT first try
                          I have built a JT circuit using the standard 1 transistor (2N3055) circuit.
                          The Toroid coil I ended up with used 26swg enamel wire (about 40 Turns) bifilar wound with some pvc insulated equipment wire (about 20 turns) on Two ferrite cores placed on top of one another (36mm OD x 7mm thick each).
                          I found the circuit worked quite well giving about 50V using 6VDC supply input. I tried a 9V battery and got about 70V but the current was quite large (about 450mA) and the 9v battery soon died (about 10 minutes). The transistor also became quite hot when I turned up the 1K Pot.
                          My aim is to efficiently charge 1.5 alkaline batteries to suit my earphones as I am partially deaf.
                          I am now trying to use the following circuit using two 2n3055 transistors similar to what Jetjjs has done - but he used 4 transistors to reduce the temperature and a straight inductor core.
                          However this reduces the voltage of the circuit and still uses a lot of power. Does anyone see anything wrong with this circuit. I think the third winding is influencing the switching of either the power or the trigger winding of the first transistor
                          I might not have the toroid wound correctly and am contemplating using telephone wire instead of the 26 swg enamelled wire.
