Supposed to read "C*H*I*N*K" in the armour, like a crack in the armour. That was not intended as a racial slur, I apologize if I offended anyone.
Basically it says energy cannot be created or destroyed, but it can be converted.
Imagine 2 identical systems. Both have upper and lower resevoirs, with the same finite volume of water in the upper resevoir. In the first system we place a system of mechanics/turbine in the path of the falling water. The turbine is then hooked to a generator and finally some batteries. Then we release the water.
When the water reaches the lower resevoirs and settles, both still have the same amount of potential energy, albeit less. If the extra potential energy stored in the batteries was a result of conversion of kinetic energy in the water, then shouldn't the potential energy in the lower resevoir reflect this when compared to the potential in the system with no turbine, just falling water? The volumes of water have not changed, but we increased the total potential energy compared to the system without the turbine. You could generate 1 megawatt with a small system or 1000s of megawatts in a large system and the volume of water/potential energy will always be equal in the lower resevoirs, regardless.
The definition of convert is to transform into something else and the original form is lost.
The definition of develop is to bring forth something from something, but the primary thing remains in its original form able to bring forth something else or more of the same.
Other forms of energy use fuel that must be replaced. They go from potential to kinetic energy and their done. Thats converting energy.
Water can go from potential to kinetic and back to potential with the volume never changing. Thats developing energy.
What do you think?
What do you think?
