Lets take the experiment one step further in an effort to prove the The Law of Energy Conservation and the context in which it uses convert, is factually incorrect.
Lets say the distance the water falls in both systems is 1100' and the elevation of the lower resevoirs is where water reaches its terminal velocity in 100' free fall.
The first system, the water exits the penstock and accelerates until it reaches terminal velocity, at which point the KE in the water is at its Highest, and maintains that speed or maximum KE until it impacts the resevoir below. The water settles and has x amount PE.
The second system we place 10 turbines at 100' intervals. The water exits the penstock, begins accelerating, reaches terminal velocity/maximum KE, then impacts the first tubine, slowing it down and lowering its KE. The water then exits the first turbine and begins to accelerate again, reaches terminal velocity/maximum KE, then impacts the second turbine, the cycle continues 8 more times. When it exits the last turbine it begins to accelerate again, reaches terminal velocity/maximum KE, and impacts the resevoir. When it settles it has the same x amount of PE as the first system.
When the water impacts the lower resevoir, both systems have the same amount of KE and when the water settles they have the same PE in the water. But the system with the turbines ends up with an excess mechanical energy the can be coverted and stored in the battries, therefore increasing the overall PE of the system.
In order to convert the KE, it would have to expend some of the PE, but the KE at the bottom remains the same as well as the PE. The correct term for the mechanical energy in a dam is free developed mechanical energy using water as its fuel. The water takes advantage of the fact that gravity is a constant and no matter how much work it does its PE is always x. Gravity cannot be converted, it is a constant force that requires a type of matter to show itself. The water is not converted, at the bottom its the KE and PE of the two systems are equal.
As a side note, this also goes against the theory that says "in a closed system, energy cannot be increased or decreased in a streamline"(no pun intented). I am not as confident of this due to not understanding all the perameters that define a closed system in the context of the system used in this experiment.
What do you think?
What do you think?
