Originally posted by Inquorate
You'd have make a cut through the ring on the washers. Then pry the washer ends apart to your screw angle. Weld, glue or screw the washers together around a center rod and you have a screw. Find a pipe that fits around the outside and you got it made. I'll try to build one in the next day or two and post some pictures.
I tried the centrifugal "cone pump" today without much luck. It would pump for about a second then quit. It would probably work except it won't draw up more water. I glued a couple of "ears" on the shaft to try and force some water in. When the glue dries tomorrow I'll give it a try.
I was also thinking of a cone shaped coil of tubing leading up to the the arms. It would work much like the screw, only as it rises, the diameter of the coil increases, which would cause centrifugal force to play a larger part in forcing the water up. The hard part with one of these would be shaping the coil.
Cheers,
Ted
