Too much vacuum will cause failure
If the device must be primed before starting, it will stop functioning upon loss of the prime.
A "must be primed to work" device will never become a run-away, (maybe?)
As a, must be primed device, rotation speed increases ... a vacuum will occur.
That vacuum will cause the device to fail at the point the water begins to vaporize (or boil) .
If the device can not re-prime itself at a lower rotation speed than the speed that cause the vaporization .. then the device fails.
If the device can re-prime itself as it slows down, lowering the vacuum, you end up with a pulsing device without the need for any values.
The device will never be a run-away due to vaporization of water under vacuum.
However, if the device is self-priming from the start, it would probably not fail after reaching the vapor point, but would just slow down some and re-prime.
A device which does not require priming would not have to be concerned about vaporization caused by too much vacuum.
I know, I know .. if we only had this kind of PROBLEM ..
Just
Just
