My one wire neon bulb lighter is inconsistent. Sometimes the neon light is bright, sometimes it only dim. Sometimes the glow position is on top, sometimes at bottom, most of the time the glow move up - down or front -rear rapidly (usually when not utilized for charging or not grounded).
I try to see the connection between the brightness of the light with my sorrounding environment. But I failed to see it. It light up very bright this morning but it glow dim at noon. I first thought that it is because the Air Conditioner being fixed at the morning cause the device to absorb heat and when the room temperatur is cold at noon reduce the energies. But with no warning the glow suddenly rotate and start to light up brighter (When I am writing this post actually). Not as bright as this morning but with the same whine loudness (brighter lighting usually accompanied with loud whistling).
What weird effect that you observe on your one wire lighting?
Anyone know the relation between one wire lighting brightness with environment?
What I mean by one wire lighting is lighting up neon bulb using radiant oscillator or School Girl charger or Bedini charger or Joule thief charger, etc.
