Albert Michelson and Edward Morley experiment vs relativity
  • Albert Michelson and Edward Morley experiment vs relativity
    Forgive me if this has been post before. Post that have similar topic are:
    http://www.energeticforum.com/energe...indle-1-a.html
    http://www.energeticforum.com/renewa...html#post25003
    attachment content
    THE-MATHEMATICS-OF-THE-VORTEX-THEORY
    It all began towards the end of the last century, when two prominent American physicists, Albert Michelson, a Nobel Prize winner, and Edward Morley, his colleague, devised an experiment using mirrors and light to detect the presence of the "Aether wind".
    To detect the presence of the "Aether wind," Michelson and Morley first built a relatively simple apparatus. This consisted of two sets of mirrors set at equal lengths, and arranged perpendicular to each other. Between them was a lightly silvered mirror that allowed the light beams to penetrate through it as well as be reflected off of it. The basic idea was to turn on a light source, allow a beam of light to first shine on the silvered mirror where it then split - reflected off both sets of the other mirrors, and was then reassembled at a target.
    Because the earth is orbiting the sun at an average speed of approximately sixty-six thousand miles an hour, when mirrors three and four (see FIGURE 10-1) were parallel to the Earth's direction of motion and one and two were perpendicular to it, the mathematics indicated that the travel times between mirrors one and two should be shorter than the travel times between mirrors three and four. And the interference pattern created by the different arrival times of these two beams of light at the target should indicate this result, but it was never seen! To Michelson and Morley's surprise, the pattern they saw at the target indicated that there was no difference in the travel times whatsoever!
    However, even though Einstein's vision of matter, space, and time has been extremely successful in some areas, it has utterly failed in others. The most important of these failures is its inability to unite the four forces of nature into one "grand unification theory", or adequately explain why they cannot be united: a seemingly trivial technical observation that acquires a status of great philosophical importance. Even those who are uninitiated into the workings of science can easily understand that the true vision of the universe must be able to explain not just some of the phenomenon of nature, but all of it! Every last bit of it!
    A deduction Einstein himself must have been acutely aware of because he spent most of the remaining years of his life trying to unite the forces of nature into his own personal vision of matter, space, and time. Sadly failing in the attempt because there was no chance of succeeding! No chance of succeeding because Einstein's failure was not due to a lack of ability or effort, but rather due to his erroneous vision of one of the basic building blocks with which he used to construct his vision of the universe – “time!”
    Because if time is not a fundamental principle of the universe; if time is a function of motion and cannot exist apart from motion, then time is NOT a building block of the universe, and cannot be used as one. If time is a function of motion, it is a phenomenon created by motion. Hence, it cannot be used as the fundamental cause to explain time dilation. If it cannot, then the length shrinkage and time dilation effects proposed by Lorentz in response to the results of the Michelson Morley Experiment, are being created by the increased velocity of the atoms themselves as they move through space!
    Consequently, there must exist a hidden ...
