Naboo brought this up in another thread, so I thought I'd repost it to get some discussion going.
Old threads:
Time to start doing the unthinkable...
http://www.energeticforum.com/renewa...ity-force.html
The basic premise is that with 2 tubes of water connected to eachother at rest, the height of the water will be the same in both tubes, even if 1 tube is larger than the other. However, if you add a piston to separate the water in one of the tubes, the water on top of the piston will put weight onto the water underneath it instead of mixing with it.
Example (the other threads probably explain it better): you've got 2 tubes connected to eachother, one is 2 inches in dimater, the other is 1 inch. If you pour in a liter of water, the water levels will be equal and you'd have 2/3 liter in the larger tube and 1/3 liter in the smaller. Now, put a watertight piston on top of the water in the large tube and add another liter of water on top of that. Now that the weight of a liter of water is pushing down on the water via the piston, the water has to all go into the smaller tube to reach equilibrium. Now there's 1 liter in each tube with the smaller tube's water level being twice as high as the larger's.
About building, I've been trying to make on of these, but trying to make a large, watertight, low-friction piston has been difficult. A way that I'd hoped would make it easier to build was replacing the piston with a bag. By that, I mean think of a square plastic bag that's kind of like an accordian. It can expand and collapse easily. Now, put that into a box so it's restricted from expanding outward, only up. Then, put a hole in the top and bottom and a valve in the top and connect to the smaller tube at the bottom. Then attach a bowl with the bottom cut out to the hole in the top, too to catch the water and keep it from going down the sides of the box. It's hard to explain so I'll make a diagram in a bit. I think this might make it easier to build, but I can't make much of anything. Hopefully, this'll help anyone who's better at actually making things.
That's all I can think of for now. I hopee we can get a good discussion going on this.
Old threads:
