Could earth core resonate at 2.7 kHz??
  • Could earth core resonate at 2.7 kHz??
    Hi all,
    I am currently reading "The Shift of the Ages" by David Wilcock, a remarkable alternative view to science. One of the things he mentions is the so-called Cathie-Grid, about which I have read before, but it didn't seem anything serious at the time. However, there might be some truth in it, after all.
    Supposedly, there should be some kind of electro-magnetic grid-energy field around the earth, consisting of exactly 720 horizontal grid lines as well as 720 vertical grid lines, or something like that.
    If this were true, where would that energy come from? Could it come from the earth's core? Could it be that the earth's core emits EM energy, or perhaps longitudinal electric (or magnetic) scalar waves?
    So, let's do some calculations. If we have 720 grid lines, or node(-line)s, which make up some kind of grid, most likely consisting of standing waves, we would have 720 half wave lengths around the earth, or 360 full wave lengths.
    That would mean that from the source at the centre of the earth, we would have 360 / (2*pi) wavelengths along the radius of the earth, which is on average 6371 km. Interestingly, the definition of the meter is derived from the radius at 48.5 degrees lattitude. At that lattitued, the radius of the earth equals 20000/pi (http://en.wikipedia.org/wiki/Earth_radius), which can conveniently be used to calculate the wavelength that would be have to be used to create this Cathie-grid, as (20000/pi)/(360/2*pi) = 20000/180 = 111,11 km.
    With the speed of light being 300.000 km/sec, we can calculate the frequency the earth's core would then be resonating at, as 300000*180/20000 = 2700 Hz, or 2,7 kHz.
    Is anyone aware of any indication that the earth's core might indeed emit some kind of waves at or around this frequency?
    If this actually turns out to be correct, this might be an important source for explaining excess energy, perhaps even up to the MHz range, like the systems of Konstantin Meyl.
    Interestingly, if you look at multiples of 2.7 kHz, we can find the frequencies Meyl is working with, approx 4.7 and 7 MHz to be pretty close to multiples of 144 times 2.7 kHz, namely at 12*144*2.7 = 4,6656 MHz and at 18*144*2.7 = 6,9984 MHz. Another one of those might be at 27*144*2.7 = 10,4976 MHz, pretty close to approx. 10,6 MHz I have seen mentioned by some scalar wave experimenters on this forum.
    I know, these last calculations look like some arbitrary number hocus-pocus, but they appear to have something to do with the so-called platonic solids, 3D geometric structures that might turn out to be very important in understanding 3D harmonic structures, such as atoms, etc.
    So, what do you guys think?
    Earth's Field NMR
    I was thinking more along the lines that the Earth's Field NMR
    frequency might be an important one.
    In my location, that is approx. 2082Hz. It varies around the planet
    depending upon the field strength.
    The Earth's magnetic field makes electrons SPIN with a certain
    frequency per the Larmor precession.
    This Low frequency radio wave (down in the audio part of the spectrum)
    is a very long wave, yes, but metals and magnets will likely react to it.
    Iron, for example, likely responds to the earth's magnetic field. Certainly a PIN floating on water swings around and points north.
    The gyroscopic electrons in the iron will orient based on the strongest
    magnetic field present.
    If you can create a >50uTesla field, you can make the iron spin your way.
    Take your field away, the earth pulls it back its way.
    If you oscillate this field off-on-off-on, just right, half of the work is your pulses, the other half is the earth's field pushing it back to equilibrium.
    These field lines likely traverse across geography as well since the earth is like a stator in a motor.
    Hendershot was thinking along these lines and managed to make a toy motor that powered itself from the earth's magnetic field. He then went on to make a Fuelless Generator. I think he was on to something.
    This does not violate the laws of conservation of energy because
    the energy is there ... from the earth's fields. Its a matter of figuring out how to tap into it.
    I've been reading about magnetic resonance, and there are many applications that use the Earth's field NMR, because it is convenient as a source of magnetic field PRESENT w/o having to create an artificial one. This is done today. Creating power from it is the next logical step.
      Yes, I think whatever oscillating wave create harmonics series:
      http://en.wikipedia.org/wiki/Harmonic_series_(music)
      But how can we find the original wave? Maybe we need the capture the wave lengt and this can be more important than frequency.
      Steve Jobs. Apple CEO
        the original wave
        Originally posted by patmac View Post
        But how can we find the original wave? Maybe we need the capture the wave length and this can be more important than frequency.
        Antenna theory would have you build an antenna that is full-wave length,
        half-wave length or quarter-wave length.
        A quarter-wave would be very long indeed at 2.7Khz.
        27,777 meters. This would be a bit tricky to construct I think.
        Yes harmonics are the key ... and that may point to the
        golden ratio sort of architecture for your device.
          morpher44
          Good answer I had many dobts about this topic thanks... Now I understand 100% all of this about waves.
          This topic is very intersting, that explains me some about Ark of Noah, this shipment was able float on the water pretty well if the universal cataclism created a vortex on the oceans this Sacred proportion avoid the Ark could be pulled to the ground on the deep sea.
          Back on the topic, lamare talk to us about the book "The Shift of Ages" this remember me some really important about David Icke, Icke explains to us about shift of the magnetics poles on the earth and this can occurs on 2012 based on Mayans, Sumerians text etc. The frequency of the planet can get up to 13 Hz in 2012 year. And planet can turn slower each day to stop itself and shift his rotation on CCW.
          But how can resonate the core @2.7khz?, Theres are many theories about the earth's core the classical theory suggest earth's cores is Iron & Nikel and highly magnetical seems logic because Iron used like core on coils hardly reach 1 mhz max.
