I wanted to see magnetic field around charged capacitor during discharge
Inductive Circuits - The "Classical" Approach
Originally posted by MileHigh View PostJoit:
> I dont think, that Caps do replace Coils.
With Caps you only rumbel the Current/Energy around, and with a Coil you have a EM Field what is more 'elastic' and has inductive Current still.
The capacitor stores the electrical energy in the electric EM field that exists in the space between the two plates of the capacitor.
The coil stores the electrical energy in the magnetic EM field that exists around the coil.
The "elasticity" of the capacitor's electrical EM field will try to sustain voltage, and changing voltage results in changing current.
The "elasticity" of the coils's magnetic EM field will try to sustain current, and changing current results in changing voltage.
Once more the Yin-Yang complimentary relationships between capacitors and coils are revealed.
Time to eat more Spice....
MileHigh
Mike
To whom are you directing this to MJN, myself or MH?
Capacitors and Inductors are precisely and inversely complementary in nature.
Strictly speaking, inductors do not "oscillate" as you say.
You can also find a capacitor modeled as a spring, and the compliance of the spring is analogous to the capacitance.
The bottom line is there are all sorts of analogies/models for capacitors and inductors.
In the purest sense, they are completely inversely compelmentary, and pure inductors don't oscillate any more than capacitors do.
.99Last edited by poynt99; 08-11-2009, 09:18 PM.
Are You Two One Of The Same
Originally posted by poynt99 View PostTo whom are you directing this to MJN, myself or MH?
.99
You did not read what I said, I specifically said read carefully what I said. but you have not.
You are right, the bottom line is as you say, but we are not talking pure inductors and capacitors or are we into supper conductors on this thread.
I don't think I said that inductors and capacitors are not complimentary, of course they are, and when together in an appropriate circuit, they will oscillate, of course they will.
ELASTIC BAND- CAPACITOR
SPRING- COIL
Think very hard about this
Mike
I have read it several times and I still fail to see the point you are trying to make. You have stated nothing new, obscure or thought-provoking to anyone that is familiar with these components and how they work.
So what was your point?
btw, in specifiying "pure" inductors, I wasn't necessarily making reference to superconductors or resistance. Resistance has little to no bearing on whether an inductor will oscillate or not.
.99
Originally posted by poynt99 View PostI have read it several times and I still fail to see the point you are trying to make. You have stated nothing new, obscure or thought-provoking to anyone that is familiar with these components and how they work.
.99
Stretch an elastic band and you have charged it with energy, let it go and it returns to its original form, charge a cap "stretch the charge between two plates" discharge and it will go to zero, its original form.
Now put the two together and they will oscillate, not because of the cap but because of the inductor. The cap catches all that is thrown at it and throws it out to a resistance that it sees "the inductor" and returns to zero, and off we go again, but nothing is perfect, there are losses, and so in time all goes to zero.
THE INDUCTOR OSCILLATES THE CAP DOES NOT; THE CAP IS A TANK FULL OR EMPTY, THE SPRING OR COIL OSCILLATES DOWN TO ZERO
Now have you got it or do we have to go about it in a different way
Mike
P:S: Oh the point of all this! well, the longer you can keep the coil oscillating the more you are going to get for your money
Coil has resonance frequency, capacitor do not. I would analog coil with the resonant box of the guitar which the box will make the string sound louder, where string which has the box resonant frequency will sound the loudest. Maybe capacitor in a guitar is the string tension by pressing the fret, higher frequency can be achieved by lower capacitance value, such as higher freq by shorter string. The guitar will sound loudest only at certain frequency. Just like coil only give max output at certain frequency.
Originally posted by Michael John Nunnerley View PostCompress a spring it has resistance, charge a coil "only if it has resistance" or it will not charge.
Mike
describing a resonant tank circuit. i.e. an LCR tank. Only thing is, I don't understand why you say the cap doesn't oscillate. It's an energy exchange between the cap and inductor is it not? The cap and inductor (pure) need each other in order to oscillate.
.99
Originally posted by poynt99 View PostI think I understand what you're saying, but if I understand correctly, you are
.99
New world thinking that has been shown to be right.
Mike
