Hi All,
Go here: Maurice Hately, Fathi Kabbary, X-Field Antenna,US Patent 5,155,495
Scroll down page to US Patent # 5,155,495 by Hately.
I think this patent is important. It is about a new antenna design, but I think it should be looked at from the point of view of generating energy.
"The basic premise of this radical design is that a magnetic field can be produced without current flow in a wire. Hately and Kabbary claim that using the reversed (negative solution) form of Maxwell's fourth equation, they were able to prove that a magnetic field does exist between two capacitor plates to which a Radio Frequency voltage has been applied.
From this beginning Hately and Kabbary report they were able to produce direct synthesis of the electromagnetic field using two large capacitor plates and two large cylinders of short length. The capacitor plates, called "D plates" for the term "D" in the Poynting theorem, were positioned parallel to one another to form a capacitor. The cylinders, called "E plates" were positioned one above and one below the D plates. When the cylinders were driven by a radio frequency power source, they produced high-frequency E-fields, thus the designation "E plates".
Crossing effect
To synthesize the electromagnetic wave, radio frequency power is fed through a power divider / phasing network to the D and E plates. The resulting electric and magnetic fields are cross-stressed in phase to synthesize the Poynting vector and produce radiated power within the small area surrounding the antenna. This effect is what gives the Crossed-Field Antenna (CFA) its name. "
This might explain how some Don Smith and the Kapanadze devices work? According to Don Smith moving magnetic fields do not create BEMF like moving conductors do. The number of stations listening does not affect the output of the transmitting station. Here is a way for creating moving magnetic fields with little or no input power required?
Go here where this antenna is homemade called an EH antenna:
Robert hart -- EH Antenna
If we take a natural source of AC energy, either from the atmosphere or from an earth battery. We feed the source into a tunable tank circuit just like a radio. This gives us a gain of voltage equal to the Q of the circuit. We feed one leg of the tank circuit to one plate of the EH system. The other is phase shifted and fed into the other plate of the EH system.
The two phase shifted signals are mixed in the EH assembly creating (synthesizing) a magnetic wave radiating outward. Nearby is an inductor. The rising and falling magnetic field induces power into the inductor which we collect. If Don Smith is right, the power collected will not reflect back to drain the source at the tank circuit? The higher the frequency the higher the power and the smaller the components.
Could this be the secret of Moray and others? By simply using an extra inductor somewhere to correct a phase shift would create a magnetic field by just using voltage and no or little current. Maybe also the secret also of the Testatika which has the high voltage front end?
These links and the basic idea was originally posted on OU Forum by user iflewmyown. His post and my response seemed to have fallen into a black hole.
I think it deserves some discussion.
Tishatang
Crossing effect
Tishatang
