My idea is to try to utilize the coil collapse current that exist in the brushed DC motor. I think when the commutator get disconnected from the brush there would be coil collapse current that go through the other two coil in the direction of opposite of the way it supposed to flow in the coil and creating drag. When the the motor slows down the current build up in the coil will increase and will generate more coil collapse current.
See attachment, cross section image from Inside Story - February 2003 - RC Groups.
I plan to get around it by adding another coil on top of original that has lower resistance than both other coil to allow the coil collapse current to pass trough this coil. By utilizing the coil collapse current I hope the drag will be reduced and the power consumption will also reduce. For winding direction I plan to make both current flow at the same direction.
I do not plan to eliminate BEMF here, I just want to reduce the spark or reverse current created by coil collapse current. The spark reduce contact and reverse current make rotor go in the opposite way.
The one that I want to eliminate is coil collapse current effect not BEMF effect, since it seems BEMF can only be fixed with different motor design.
But the problem is, even if I add diode the motor still go both forward and reverse depend on the polarity. where it should only work on one direction only. I tried 1N4002 and some unknown diode type (attached). Anyone can suggest a diode that may work at around 4 Amp at 3 or 12 Volts? It need to be small because I want to put it inside a motor smaller than anyone toe thumb.
