Think i found some missing info from Tesla's radiant energy patent
  • #61
    Interesting.....similar writing style....interesting how it talks about a secondary frequency of the received waves paragraph 90-95. i have heard that before somewhere.
    • #62
      Something else that grabs my attention is the use of the variable capacitors in the hammond patent. I guess this is used to tune into the radiant energy. Might have to buy one to try out.
      Like an outstyle radio would tune in
      • #63
        more Tesla speculation
        He learned so much in Colorado Springs.
        He had a big budget for
        "Waldencliff Tower".
        If you were Tesla, you wouldn't build JUST a transmitter.
        No.
        You would want to mess around with receiving as well.
        I was looking at the toroidal, high pressure voltage reservoir,
        terminals, spherical metal platest, etc. at the top of his tower.
        Tesla knew that spherical shapes will ARC less ... and avoid
        dielectric breakdown ... since this shape has the most surface
        area of any other shape.
        We see a toroid composed of many spherical metal plates.
        This is a very complex geometry actually.
        The terminal arrives to it as a flat plate (circular plane) residing
        in the center of the "hollow" toroid composed of spheres.
        This is a capacitor like no other.
        It is a sort of hybrid Van De Graff / Tesla shape.
        What sort of MATH did Tesla perform to calculate this
        complex geometry?
        Why such complexity?
        Hertzian wave transmission/reception
        needs only a simple little rod.
        If this Waldencliff Tower can also be a receiver,
        power would arrive to his primary coil from his secondary,
        down from the giant toroid.
        If he were to introduce a negative charge to the toroid
        so as to ionize each of the spheres within the toroidal shape,
        each one would be a capacitor ... and they would sum ...
        to a large value of capacitance.
        His secondary is HUGE.
        Hence, the resonant frequency would be very LOW.
        Perhaps even the 11Hz he tried to do in Colorado Springs.
        So ... let me just throw this out there ...
        perhaps this was always intended to be a receiver of power
        from the earth ... the very wheel work of nature...
        Transmitting can be done as well ... if that is how
        you want to use that power ... by simply imposing
        other waves onto your HUGE - LOW FREQUENCY carrier wave.
        • #64
          the cupola
          From "Wizard: The Life and Times of Nikola Tesla", by Marc J. Seifer,
          page 290:
          "Over fifty feet in diameter, ten feet tall, and weighing fifty-five tons, the iron and steel crown, with its specially designed multitude of nodal points, would serve the purpose of storing electrical charges and distributing them either through the air or down the metal column and into the hollow. The copula was linked to four large condensers behind the laboratory, which also served the purpose of storing electrical energy, and these in turn were coupled with an elaborate apparatus which had the ability to provide every imaginable regulation in the control of energy."
          Tesla also had sixteen iron pipes, each 300 feet deep in the ground radially like spokes.
          • #65
            morpher44,
            You have got me thinking!!!
            After reviewing hammonds patent and doing some digging. It appears that Tesla did indeed spend some time with hammond. So it is most likely as you have said that this is Tesla's revised system.
            What has got me thinking is the variable capacitor in the hammond (Tesla) patent. As we know this is usually used to tune into radio stations but what if it can also be used to tune into UV and xray light waves. It appears that Tesla was using a .004 mfd capacitor at wardencliff. So perhaps that is a starting point if we assume that was also a receiving station. Anyone got any ideas about tuning a capacitor into UV & xray light waves (most likely xrays/rontgen rays)?
            So the components for this system are:
            1. negatively charged elevated plate (maybe insulated with ice or liquid air)
            2. variable capacitor to tune into xrays
            3. positively charged ground plate
            • #66
              xray wavelength
              XRays are .01 to 10 nanometers in wavelength.
              Gamma rays, I've just learned, overlap XRays in wavelength..
              but were typically thought to have a wavelength approx 10 picometers.
              For the reception of those frequencies you don't build
              giant collector plates, large inductance coils, and that capacitance
              would be way too large.
              On the other hand, capacitors with a high-voltage tolerant
              dielectric (to avoid breakdown) and huge inductors, can
              store more Joules of energy -- sloshing back and forth
              in a tank circuit.
              Tesla was trying to devise various ways to have such a tank circuit
              PUSHED at just the right time to regeneratively build the power.
              Such pushing could be done by tuning to a harmonic of one
              of those higher frequencies I suppose ... but only if there
              is sufficient power arriving at some frequency.
              Also, if some astronomical event is causing the high-energy
              gamma radiation, you would need to devise a tracking dish antenna
              that could lock in on that object in space unless you
              go wide-band and try to collect energy from a large range
              of frequencies.
              Hi frequencies are attenuated by inductance.
              Lo frequencies are attenuated by capacitance.
              If you could cancel ALL magnetic fields and have an extremely
              small inductance, perhaps the higher frequencies can arrive to your
              system -- wide band.
              If you could create a coil with large inductance and devoid
              of any capacitance (said another way, self inductance is a very
              high frequency -- Q is high), then perhaps low frequency energy can
              be received to your coil -- wide band.
              I guess the question is, which solution was doable in Tesla's time
              with his state-of-the-art.
              • #67
                @all
                Here's some further information on how I see the gray tube functioning based on the new information i found on Tesla's radiant energy patent.
                The question is now does a diode function the same way as the vacuum tube does in producing a radiant matter stream that travells in straight lines. You dont want to be using a magnet near the radiant matter stream as it will deflect it.
                • #68
                  Secret Tesla Journals...
                  part 1: YouTube - Nikola Tesla's Secret Journals 1
                  • #69
                    @morpher44,
                    My next test of edwin grays circuit is to incorporate a portion from the hammond patent you posted to drive the thyratron.
                    What was interesting was when i placed resistance in front of the thyratron as per grays schematic. It made a funny squelching noise. I plan to investigate further.
                    The blue spike phenomena
                    Tesla's introduction to the phenomena of Radiant Energy began with early observations by linesmen working for Thomas Edison, Tesla's former employer
                    Before Tesla's invention of the Poly-phase AC generator became the industry standard and overtook Thomas Edison's use of DC generators, the DC electrical system was the only system available to deliver electricity to America's homes and factories. Due to the resistance offered by long transmission lines, Edison had to produce very high DC voltages from his generators in order to deliver enough voltage and current to its final destination.
                    Nat
                    • #70
                      water inductance
                      This was copied from a russian forum
                      Here is further evidence of energy transfer through the magnetic moments of atoms.
                      Kacher
                      http://album.foto.ru:8080/photos/or/171265/141450.jpg
                      here the role of the base inductance is tap water.
                      It is known that the charge carriers are ions in fluids, ie molecules - the electric charge carriers, which are mechanically moved along the external electric field.
                      In the scheme can not be resistive feedback, because the base and collector circuits untied different sources of supply. There can be no capacitive coupling, as between the plates as a small resistance to water. There is only inductive coupling and is confirmed by the fact that generates Kacher
                      only one version of the beginnings and endings inductance (1. collector normal and 2. inductance base - tap water), when extracting inductances of the water generation is interrupted.
                      And now it turns sort of theory - in the atom vectors of electric and magnetic fields are rigidly connected. The linear displacement of the molecule is provided by an electric field bias source database, which tows a molecule in its electric field, which is responsible for the atomic nucleus.
                      In the oscillatory process to intermittently - progressive movement of water molecules added to a nod of the magnetic moments of the water and impurities caused by the collector inductance, thus providing a feedback circuit with a collector base, supporting oscillations.
                      This is a new way to study the properties of liquids.
                      Parameters: transistor CT 940A. Inductance collector 30 turns. Water between two plates of brass measuring 10 by 10 cm rasplozhennymi see photo. Ub = 0,9 In
                      Uk = 5V
                      _________________
                      Kacher - is not only a new way to control transistor (patent2265276), but also a new way to transmit information, as well as an absolute sensor (patent2075726), and transformer DC
                      Back to top
                      • #71
                        I thought i would post why i am looking at edwin grays circuit and not something else. Well it is because i have come to the conclusion after doing a HUGE amount of research into Tesla's radiant energy that it is (edwin grays patent) probably the closest thing to a complete circuit that captures all the features that Tesla refers too. Unfortunately there are details missing from his patent as well. Just need to work out the missing details.
                        • #72
                          from "Experiments with AC of High P and High F".
                          Tesla's book "Exepriments with Alternating Currents of High
                          Potential and High Frequency" has a discussion about losses
                          starting on page 106.
                          "The total energy lost per unit of time is proportionate to the product
                          of the number of impacts per second, or the frequency and the
                          energy lost in each impact. But the energy of an impact must be
                          proportionate to the square of the electric density of the sphere
                          (capacitor), since the charge imparted to the molecule is
                          proportionate to that density. I conclude from this that the total
                          energy lost must be proportionate to the product of the frequency
                          and the square of the electric density ; but this law needs
                          experimental confirmation".
                          He goes on to speculate that the losses are NOT transmitted
                          out to a considerable distance in the ether but rather produce
                          local heating.
                          To reduce this effect, he speculates that the electric density
                          must be kept to a minimum ... in relation to going to higher frequencies.
                          He then concludes that one-wire is better than two, and
                          goes on to encourage the development of one-wire devices --
                          motors, lights, appliances, etc.
                          This discussion caught my eye the other night.
                          Tesla was describing how he concluded that single wire
                          transmission of power should be deployed through-out the
                          power network to reduce losses!!!
                          • #73
                            I think you are on the right track
                            Hi Morpher44.
                            I do think you're heading in the right direction And I do think Carbon had something to do with it.I've been Thinking of maybe adding it to a earth type battery with a few other compounds.if anything useable come's out of it I'll post.I have had some luck with an earth battery and J Thief.its been running at 0.55 volts for about three day's I have a 2nd winding running thur a bridge rec in a loop type setup. lookup JJ Thomson 1856 maybe of some help. Tec
                            • #74
                              Why all of you don't just read what Tesla said about his radiant patents ?
                              Read for example this one and you should realize that it's not that simple : NIKOLA TESLA - Google Patent Search
                              These patents were simply describing receivers for his magnifying transmitter and thus cannot rapidly accumulate any other disturbances propagated thought ambient medium, just because cosmic rays disturbances are of extremely high frequency and no one capacitor can store them ! Do you remember that AC cannot be stored in capacitor ?
                              If you are lucky you can use germanium diode or any other filter to allow only unidirectional disturbances to pass to capacitor from elevated antenna - that would be better.Or use magnetic resonators.
                              • #75
                                Never said it was simple
                                Hi. I never said it was that simple.Just looking at everything.the coating's on wire now are way different then they were in Mr Tesla's day. Tec
