Think i found some missing info from Tesla's radiant energy patent
  • As i was trying to trigger this phenomenon when the environment wasnt the ideal i stumble by accident on a different result.Very interesting and fun.
    YouTube - Radiant Energy
    • amazing video!!! thanks for posting
      • Originally posted by Tomata View Post
        How are you doing that?
        That light looks like an incandescent bulb, yes?
        Obviously, if I take a light bulb and put it to my friend's head, nothing will happen. What are you and your friend touching that allows for the flow of (cold/negative) energy?
        Are you and your friend touching the elevated copper plate and ground while connecting the light to each other?
        That reminds me of the picture on the front of Eric Dollard's book "Condensed Intro To Tesla Transformers".
        • Originally posted by Web000x View Post
          Doesnt need to touch a human or to a "ground" .Even if something is hanging on air it could light the bulb.Even if i touch my left with my right hand it can light the bulb.
          I will give more info later.
          • Re. negatively charging the antenna
            Hi all,
            New to the forum and this is my first post.
            The best way to negatively charge the antenna is to put a battery in series with the antenna, doesn't need to be high voltage 4.5v will work.
            Next in series is an accumulator/detector, this component must be insulated from earth.
            The earth side of the detector will then run into the antenna coil of a TRF radio circuit before being well grounded.
            If this sounds familiar, check out Chauncey Britten.
            What you have done Tomata is the first step, by adding a resonant circuit to pull the charge in, you can then power your house.
            Tesla, Moray, Britten, Markovich, even that Tesla's secret website, they were all saying the same.
            Excited to be here guys, hope to share experiments with you soon.
            • Did I say something wrong? My very first post too.
              i didn't mean to offend anyone if I did, i found this thread by searching for "Moray", as "Britten" didn't come up in the forum at all.
              I have spent years over at 4HV and only found this forum by looking for Eric Dollard material, i liked what I read and joined.
              I replied to this thread because it is one of the things I am currently building. Almost finished the TRF, then will raise a capacity (antenna). Accumulator was the first thing built after a few wines one night. Have not decided how to achieve the vacuum.
              If all this is sounding foreign, then rexresearch.com has all the info you need to know. it really is remarkably simple.
              Goldsphere
              • @goldsphere
                Thank you for the contribution.I will look forward for any indications or details you may find so to proceed with this apparatus.
                What is the accumulator/detector ? Is a electromagnetic coil or a vacuum tube ?
                Iam in a middle on some more experiments on this and iam hoping to get more close to a solution.
                YouTube - Radiant energy 2
                • Chauncey Britten
                  Thanks for the reply Tomata.
                  Here is the link to Chauncey Britten information.
                  Chauncy Britten: Free Energy Generator
                  I believe it has been missed by many people probably because of its simplicity.
                  He was originally just trying to get a better radio signal and ended up powering his house with it.
                  It will be the same cold electricity or diaelectricity that Moray and Dollard respectively spoke of.
                  Look forward to what you have to show next.
                  Concerning your video, is this all from your antenna and ground setup?
                  Do you have some video of the setup?
                  • Originally posted by goldsphere View Post
                    Thanks, i knew about Britten's story.The video it was a partial answer to webooox .I use the antenna as a capacitance source.Nothing new or special.Just a lot of fun.
                    • Tesla Generator
                      Hi Everyone, I'm new here and trying to play catch-up with all the posts here. Has anyone here successfully stored the energy generated from the plates? I'd love to get involved and maybe help in furthering the development of this harnessing of radiant energy. Look forward to your replies!
                      • I have been applying some of the info in this thread to my work on replicating edwin grays patent in the following link. I still believe the secret lies in creating a standing wave (stationary wave)! And i believe edwin gray had access to information from Tesla. He appears to know much more than we are lead to believe.
                        Nat197a
                        http://www.energeticforum.com/renewa...cation-81.html
                        • Originally posted by morpher44 View Post
                          WOW!
                          I found this article:
                          Nikola Tesla Page, Tesla's power receiver
                          The "more musings" particularly got my attention
                          because it proposes to use a "vibrating magnet" to
                          create a sort of super-conducting antenna for low frequencies.
                          This is exactly the sort of information that might help
                          one re-create Tesla's radiant energy patent
                          an approach that can be room temperature.
                          thanks for that!
                          ‎"It's all in the MIND"
                          • Originally posted by nat1971a View Post
                            Nat197a
                            you are correct
                            http://www.energeticforum.com/renewa...netism-19.html
                            ps: StweenyA , you are right, thanks for the link
                            • Thanks. I believe Tesla was creating standing waves using his zinc box. see attached picture
                              The waves from the two equal and opposite coils collide and create a standing wave. If the waves are strong enough they will reflect back off the zinc and amplify!!!
                              I have incorporated this into edwin grays circuit! Enjoy!!
                                this experiment shows that water collects energy and acts as a carrier
                                YouTube - Static Electricity and Bubbles!
                                when water or humidity is present in the air it absorbs static electricity when there is no humidity we build up static charges so water must absorb or at least be a carrier of electricity.
                                If I could say my own thoughts, the humidity or water consists of hydrogen and oxygen. These are basic molecules that creates stability on this planet. Hydrogen is positively charged and in its most available form, is missing neutrinos. That means, as positive and negative attracts each other, hydrogen atoms bound themselves to negative charge thus stabilizing (or better say sucking) the built up charge from its surrounding vicinity.
                                One can think of a problem as being part of that problem. Or he can solve it.
