@witsend
I hope you don't mind.
Original post by witsend:
Originally Posted by boguslaw :
Sorry that so late, but do you have a picture of arrangement of magnets ? I found it extremely interesting.
Reply:
Hi Bogus, at last someone's expressed interest. I've even tried to alert a 'magnet enthusiast' at Ou.com - to look at this. It's definitely off topic and no I do not have a diagram. But here's the thing. Buy your magnets first - ferrite is fine - but make sure that the n/s axes are at the top and bottom of the 'cylinder'. Not along it's length. You'll need about 12 - 16. Then cut the aluminium to fit so that the radial axes are are near the centre as possible. BY THE WAY - a small overlap of the magnets needed at either side of the alumunium to ensure that you can 'tie' it easily. So check that the outside and the inside diameters are slightly less than the length of the magnets. From memory I allowed a gap in the centre of about 1/2 inch. Then tie them with cotton thread. Glue won't cut it. Then hang them from cotton thread from the centre. The repulsive forces get very strong as you add to the build. It's great fun and quite an extraordinary result. It also retains a single justification which is quite unusual.
Actually I hope Harvey also reads this because I've realised, latterly, from youtube postings that he's also interested in magnets. It's an easy test to set up. I have other interfaces that I'd like to explore. But this one is indeed strange - simply because of that 'retained' spin justification. Not sure if it's typical but suspect not.
![Embarrassment](http://www.energeticforum.com/core/images/smilies/redface.png)
Reply:
