kywdo free energy
  • kywdo free energy
    YouTube - FREE ENERGY (with old electronic - NEW).wmv
    this needs to be looked at and understood i beleive theres more here to be learnt.
    I have rep. this with a single diode led white and it works.YouTube - free energy LED
    dr stifflers sec will be of great importance to helping this effect
    the future will be bright!
    john_g sent me this link
    PhET Photoelectric Effect - Light, Quantum Mechanics, Photons, Electrons
      Originally posted by Bodkins View Post
      Good find Bodkins on the LED post. Thanks must go to Sebosfato for the link,- he posted it on the Stan Meyer page.
        YouTube - NEW in FREE ENERGY PN with CAPE GENERATORS with small MAGNIFYER
        another ace
          This is my first post on this forum. Seems like my prediction came true again.
          Originally posted by quantumuppercut View Post
          Well, if you have high voltage or static charge, you can make an electrostatic motor. Electromotive force is contain within the high voltage itself and constantly in oscillation. Current is always there. It is just in AC form of super high frequency that makes it useless. If you can rectify gigahertz to tetrahertz, you will have unlimited DC from any electromagnetic waves, higher than those frequency, maybe gravity wave . Current diode technology is too far behind. The magic thing about electrostatic motor is they can rectify through circulation.
            YouTube - Led giving 2.4 volt from sunlight
            over two volt with one led
              Finally something low enough tech, being a single component energy circuit,
              I think I can't screw this one up and do it wrong
              As far as using LEDs goes, this guy seems to think green LEDs are better
              for some reason than other colors.
              "Power For Free"??? - The Whistle Post - Model Railroad Forum
              Would not it be a rule that the more power hungry the LED is to light up,
              the more power it would generate?
              This could be neat stuff. How long will a LED last in UV light?
              Will the plastic turn brittle or turn yellow?
              Would a glass or ceramic diode last longer than a plastic encased LED?
                The sun is down right now, so I tried a 1N4007 1A 1000V Rectifier Diode up against a CFL.
                The diode had wires solder to both ends so I could expose only one side of
                the diode at a time to the light.
                Putting the cathode end wire against the CFL read 1.5 volts.
                Putting the anode end wire against the CFL read 0.45 volts.
                Put some foil on the anode end with the diode in the shade and
                obtained about the same reading of 1/2 a volt.
                Seems the diode itself needs not be exposed to the light, just the wires.
                Does this scale up?!
                If I don't get distracted, remember, the sun comes out and by the
                grace of my Lord, I'll try it in sunlight
                Randy
                  the diode needs to be 1n5062 white,
                  randy come on!!!! its PP time LOL
                    also i cant charge a 2mf cap up to 2 volts from a light bulb with a magnifer on the white light led
                      Is it a dream?
                      I used 4 RM2C diodes in series pulled off an old TV board,
                      bare wire wrapped around
                      the positive probe of the meter to the diodes and stuck the probe
                      into the middle, into the inside of a CFL. 2 volts.
                      Let go, do not touch the probes: 3.3 volts
                      To not touch the ground wire either.
                      Depending upon which one you touch it falsifies/effects your voltage readings.
                      Connect an earth ground and it jumps to 6.2 volts
                      Then I thought it was not good for my probe to be inside
                      that hot bulb, so I wrapped the bare wire around the CLF
                      and it started out at 6.2 and fell to 4 volts .. I don't know
                      Then I got to thinking .. that just isn't right. I must not
                      have observed it correctly. So I grab the positive probe and jammed
                      it inside the light bulb and let go (don't touch!)
                      Reading 9.9 volts.
                      Is this sounding crazy enough for you yet?
                      I ran out of same kind of diodes .. I'll look around for more.
                      I don't expect to get these kind of voltages from sunlight??
                      But but .. it would be nice......
                      Randy ..... hmmmm .......
                        I think you will get better voltage in sunlight with a magnifier. i try the transistor style cuuting the bcak off a 2n3055 but i only get .5
                        not try grounding yet but its a good idea!
                        crazy i love crazy
                        Im off next week will give you a call
                          crazy i love crazy
                          Hey, you did understand that I get voltage without the diode
                          being exposed to the light, only the wire connected to the diode is
                          exposed... Right?!
                          Would it not follow that surface area being exposed to the light
                          is a factor then, also?
                          I tried a piss-ant JT coil I have and i don't know what i'm doing
                          or the current is zip/nil. It didn't seem to do anything to the
                          voltage.
                          Yes look forward to the call.. give me a heads up so i can
                          schedule bed time .. i do not do a schedule and am up over
                          24 hours a lot.
                          • #14
                            hehe i standunder that randy. we need to work out what the diode REALLY is then.
                            heat cold diode? light to dark?
                            off we go again Randy
                            the current is nil but serial change a cap to dump to battery.
                            i will order 100x1n5062
                            1n5062 are audio diodes i think
                            • #15
                              A thought. Does a higher voltage diode make a difference?
                              Does the surface area that the light falls upon make a bigger
                              difference than the diode itself?
                              The diodes you are getting are more expensive and are an avalanche diode.
                              Is an Avalanche or a non-Avalanche a better diode for the experiments?
                              The first diode I tried tried, 1N4007 1A 1000V Rectifier Diode, created
                              1.5 volt and is very cheap compared to the 1n5062????
                              Get 100 1N4007 here for $2.00 US. International Buyer pays $2.99 for shipping. Click the Buy-Now button.
                              I purchased 100 1N4007 for $3.75 total, my shipping was only $1.75.
                              I've often pondered what word to use instead of UnderStand
                              Remember to ask, "By who's authority?"
