While studying possible "passive" oscillators, I stumbled upon the Multipactor effect...more precisely the "Farnsworth Multipactor".
It then dawned on me the significance of "matching the electrode gap (in respect to the time it takes a water molecule to traverse it) to the frequency of the physical pulse applied to the electrodes" as stated by Stanley Meyer
Let me first describe the "Multipactor" effect...
It was noticed by the "Father of Television" P. Farnsworth, that at certain modes of operation there was a faint blueish glow in a region between the cathode filament and the anode plate of simple diode tube rectifiers . This observation led to the discovery of the "Multipactor" effect, which is very similar to the "Photoelectric effect" in nature. This being that high velocity electrons will slam back into the cathode under very controlled conditions, and release 2-8 more electrons per impact
With that being said let me show you now why I believe this effect is paralleled in Meyer's process
The statement "As understood in resonant cavities of an electron nature..." is a direct reference to "Multipactor" action...if that isn't enough this blatantly spells it out for us.
This explains the "Physical" aspect Meyer was talking about...it explains why he states the gap distance is critical...and it explains this image (and all waveguides shown by Meyer)
It is showing the back and fourth nature of electrons/ions in a precisely timed resonant pulse/cavity interaction
To figure this out we need to figure out how fast the water molecule/water ions (Hydrogen and Oxygen BEFORE neutralizing) move towards the electrodes (I suspect this variable depending on the electrode potential). Then we must figure out how to supliment extra energy into the system (as the atomic collisions lose some energy during their collisions). I suspect the VIC being wound around the cell and the extra photon energy does exactly this in the Meyer system (that's why the LED array is pulsed at the same resonant frequency).
Anyway, I strongly encourage all readers to research the Multipactor effect and the Farnsworth Multipactor called the "Fusor" to come to a conclusion of their own.
Two-surface multipactor on metals
This is a multipactor that occurs in the gap between metallic electrodes. Often, an RF electric field is normal to the surface. A resonance between electron flight time and rf field cycle is a mechanism for multipactor development.
The existence of multipactor is dependent on the following three conditions being met: The average number of electrons released is greater than or equal to one per incident electron (this is dependent on the secondary electron yield of the surface) and the time taken by the electron to travel from the surface from which it was released to the surface it impacts with is an integer multiple of one half of the RF period and the average secondary electron yield is greater than or equal to one.
Single-surface multipactor on dielectrics
This is a multipactor that occurs on a dielectric surface. Often, an RF electric field is parallel to the surface. The positive charge accumulated on the dielectric surface returns electrons back to the surface. A single surface multipactor event is also possible on a metallic surface in the presence of a crossed static magnetic field.
