Another interesting fact is that Moray was working in 5MHz range. And Hendershots coil resonates in a range of 5MHz. This 2 devices got something common.
Hendershot Replications
Another observation.
Look at this picture, do you see buzzer? Hendershot balancing the load. May be replacing buzzer with 60W bulb will be sufficient.Attached FilesMike
high voltage spikes
Originally posted by NOMDI View Postwe can speculate he did it only to get a very high voltage capacitor. It seems to be logical because the LC cell is made to be tuned a the resonance point, which means high voltage pikes. Can we suspect that every replication made with a single layer capacitor (made of paper which is not as good as actual plastic films for insulation) has "dead born" capacitors ?
I also guess that this could explain the value of 1.3 mF (we've seen in his son document), which could be in fact 13 nf, almost twice the value of the 7.8 nF he could have first experiment with a parallel double layer capacitor...
re: the 1.3 mF, it definitely looks like MFD ... but this
little note here has no context...Attached Files
Hendershot, did his calculations based on 1/16 of wave length for (0.0078uF) and 1/32 of wave length for (1.3uF). Or maybe he calculated it for 1/4, but it operated in 1/16. Played with numbers for 1.3uF it's different (not related) wave length then 0.0078uF, not even close. Correct value would be 0.1245uF or ~0.13uF (for 1/4 wave length), ~1.99uF (for 1/16 wave length). Looks like Hendershot was of on one decimal point.Last edited by mlurye; 10-29-2009, 08:57 PM.Mike
the math
Originally posted by mlurye View PostHendershot, did his calculations based on 1/16 of wave length for (0.0078uF) and 1/32 of wave length for (1.3uF). Or maybe he calculated it for 1/4, but it operated in 1/16. Played with numbers for 1.3uF it's different (not related) wave length then 0.0078uF, not even close. Correct value would be 0.1245uF or ~0.13uF (for 1/4 wave length), ~1.99uF (for 1/16 wave length). Looks like Hendershot was of on one decimal point.
Could you explain your math in a bit more detail. I'm not following how you derive this.
-morpher44
-morpher44
L=120uH , C=0.0078uF based on this I calculated wave length.
Wave length / 4 or /16 or /32 you can get resonant frequency and get C for it.Last edited by mlurye; 10-30-2009, 05:39 PM.Mike
hmmm...
I get f = 164506 hz with those values ... but you already have C = 7.8nF.
Wavelength is 1822.376 meters.
divide by 4 = 455.594116 meters, 658025.306589 hz
divide by 16 = 113.898529 meters, 2632101.226357 hz
divide by 32 = 56.949265 meters, 5264202.452715 hz
Now what?Last edited by morpher44; 10-30-2009, 06:07 PM.
Now what?
1823 * 4 =7294 m, 41126 Hz
L=120uH
C=0.1248uF (Not 1.3 as mentioned on note, 1 decimal off)
divide by 32 = 56.949265 meters, 5264202.452715 hz ~5.26MHz (Moray was using his device with 5MHz)Last edited by mlurye; 10-30-2009, 07:27 PM.Mike
wavelength
Originally posted by mlurye View Post1823 * 4 =7294 m, 41126 Hz
L=120uH
Very interesting ! I guess you've found the best theory about the mysterious 1.3 origin Do you have any idea about the meaning of this Hendershot and Moray 5 Mhz common value ?
Originally posted by NOMDI View PostVery interesting ! I guess you've found the best theory about the mysterious 1.3 origin Do you have any idea about the meaning of this Hendershot and Moray 5 Mhz common value ?
May be if we will scan in 5264197.63332369 area we can find source of energy that was used by those devices.Last edited by mlurye; 10-30-2009, 07:45 PM.Mike
the tuning...
Originally posted by mlurye View PostNOMDI based on this number I can make one assumption, they were using the same frequency to tune in to. And with info available for Hendershot device we can calculate it as close as possible.
I was thinking the inductance and capacitance of the
tank circuit was the dominant set of values for tuning as well.
But now I'm not so confident in that assumption.
The 120uH you assume is not actually what will be seen
by the tank circuit.
Inductance is a funny thing in that it is influenced
by mutual induction as well.
So since we have a 64-turn coil UNDER that "tank" coil,
it behaves like a transformer.
The other side of that transformer has several other
inductances hooked up in series.
The tank circuit, therefore sees a much larger inductance ...
upwards into the millihenries, since we
are dealing with those 5:1 transformers, etc.
Again, I'm no expert in circuit analysis ... and
all this crazy mutual inductance makes the problem
quite complex.
I have clued into the fact that if you can make
all these inductances experience the same rising and
falling magnetic field (up and down the sign wave),
you utilize the phases to create a nice
180 degree phase shift. One transformer ... gives you 90 degrees.
A 2nd transformer gives you another 90 degrees, resulting in 180.
With a 180 phase shift you can then do "regeneration"
of the waveforms ... adding their amplitudes...
So if the waveform -- arriving to the left-hand side were to be
run through essentially two transformers -- each shifting phase
90 degrees .... when that arrives to the right-hand side,
it too would produce magnetic fields that go up and down
in the same way. The left and right could be made to
synchronize in this way since their fields are moving in
unison up and down on the same plane. They
would be able to exchange mutual inductance ... producing
an even larger effect in terms of feedback.
I suspect the Hendershot device is using mutual inductance to
some advantage.
It is easily demonstrated that two coils that have their
cylinder mouths oriented UP, when placed next to each
other, can inductively couple -- just as effectively as if
their mouths were facing each other.
