Hendershot Replications
  • Originally posted by clarence View Post
    hello Gazzasore,
    clarence,
    I found this system on some of the posts on the russian threads(I went through them all, whew!) There didnt seem to be a schematic or name attached to it, and I dont believe its a russin build. but could be by the eu type of terminal connectors used. only shows two capacitors but a hell-of-a large magnet and keeper. By the way in all of the schematics I have studied the majority if not all of the capacitors are series connected which I believe overcomes the polar problem in obtaining the needed caps and at the same time increases the voltage handling but reduces the net uf value in the branch circuits feeding off of the capacitor network entity. you can look and draw your own thoughts. notice this attached build doesnt have the restructured caps with cores inside the baskets either!
    just passing on my observations,
    mike, onward!
    hi all
    mark m hendershot the son 1994_Extraordinary_Science and hyiq
    some more links and References
    PowerPedia:Lester Hendershot
    The Hendershot Motor Mystery
    • Hi Guys these two sites were on the Sister Russian site
      need translate going on your browser
      http://ut27972.narod.ru/Book_2/110_B_2_p_110.htm
      http://ut27972.narod.ru/Book_2/00_Book_2_head.htm
      • Guys this site has a lot of Downloadable files on Lester Hendershot
        "hendershot" : 91 files were found for free download - General Files
        Just beware some files are full versions and some are not check the size before downloading
        • [QUOTE=Gazzasore;220624]Hi Guys
          Hello Gazzasore,
          clarence,
          just curious, how did your E-mail to Mark Hendershot go? supposedly he was compiling a plans and reasearch packet back in 1994 for about $64.00 and I was wondering if he still offered these packets. I would love to have one. as I say , just curious.
          mike, onward!
          • [QUOTE=clarence;220683]
            Originally posted by Gazzasore View Post
            Hi Guys
            Hello Gazzasore,
            clarence,
            just curious, how did your E-mail to Mark Hendershot go? supposedly he was compiling a plans and research packet back in 1994 for about $64.00 and I was wondering if he still offered these packets. I would love to have one. as I say , just curious.
            mike, onward!
            No reply yet Still waiting
            Are you sure it was Mark selling the package ?
            I saw the same thing
            But it may not have actually been Mark selling them
            I would say almost everything you could get would be here and Mark gives instructions in "The Hendershot Mystery"
            • https://www.youtube.com/watch?v=B_kB6GQK9BE
              • morpher44
                Hey have you tried playing around with Magnets inside the Baskets around inside and out etc
                I watched a Video tonight on YouTube a guy playing about with Magnets and coils
                Flux Gate Magnetometer or Solid state Generator? https://www.youtube.com/watch?v=B_kB6GQK9BE
                Also Ive read the Lester Hendershot squeezed his Capacitors and touching various wires to get his device going 10Mins and longer
                and sometimes not getting the device to start at all
                Its out there energy that is
                Watched this too Witts device https://www.youtube.com/watch?v=UOH8_hpAtEA
                All very inspiring really
                Gaz
                • megnetometer
                  morpher44
                  Gaz
                  Hi Gaz,
                  Yes I agree that the Magnetometer should be looked at and understood, as well as the Induction Compass. These are devices that Hendershot was trying to improve upon. He was making circuits of this nature.
                  Some thoughts re: the Magnetometer video:
                  1. Hendershot was not using magnets in a static way -- with static fields. Rather, what I think Hendershot was doing was wiggling the static fields with his solenoid device, such that they would spray the field LEFT then RIGHT. Generation of power can occur if the fields are moving and the coils are stationary -- opposite to what occurs in an induction compass. The trick would be to move these fields with a small amount of power, and establish an equilibrium that is oscillating.
                  2. Light bulbs are low-resistance loads. They can be in series with your circuit, and will not dampen the oscillation too much -- depending upon the values you have in your LRC circuit.
                  3. Large coils and capacitors - tank circuits -- can store and smooth out the energy as long as you are TUNED to the oscillation. If you are off-tune, if your impedence calculations are wrong, the signal will dampen to rapidly. Hendershot was known to tweak his capacitors with clips (a crude variable capacitor) and to chop off, or lengthen the loops in his coils until he achieved the correct tuning.
                  4. The Earth's field, depending upon location, is an implicit magnetic field to also consider. Hence your N-S vs E-W orientation, may add to, or subtract from, whatever you are trying to make oscillate with low-frequency oscillations. The FOOT-PRINT of your fields change as you change this orientation. Its subtle -- 50 microteslas say. You need much stronger magnets to overpower the Earth field effects.
                  5. If you can create a sort of VORTEX with your magnetic fields, and if that VORTEX is a spinning torsion field that is strong than the Earth's field, you possibly can SUCK particles down into a smaller are for impact on to metal plates, or cylinders. This makes it so that you don't need a GIGANTIC plate for energy capture. Your vortext is guiding the incoming radiant energy down INTO your target area. Again, this effect would only happen when the magnetic field strength here starts to be large enough to overpower the Earth's field. If the magnetic field was parallel, the NMR would be a constant circumference SPIN. If the magnetic field is a vortext, the particles SPIN in a spiral with reducing diameter down to your target.
                  6. One thing no one has discussed is whether or not Hendershot wired up his solenoid in the magnetomer fasion. I wonder...
                  --morpher44
                  • Originally posted by morpher44 View Post
                    Hi Gaz,
                    --morpher44
                    Yes
                    Hey I had more of a thought on the Tweaking Lester did
                    Maybe we should more along the lines of Priming like a Diesel Engine
                    Once its Primed it can flow with no blockages and start
                    That may Had been what he was doing Priming his device to allow the flow process to happen
                    • subtle energy
                      Yes
                      Part of the myth is that the machine would only work for Lester. Not exactly true because his kids could start it up, or so I read.
                      Anyway, I don't think his machine RELIED on Lester's CHI (Qi) energy to keep running. If that were the case it would be this horrible "Matrix" like device sucking human energy to power some light-bulb or motor. It would certainly be depressing.
                      I wouldn't rule out, that Lester's CHI might have STARTED the machine. Certainly in playing around with air coils, and inductance, and Theramins, etc. the human body can influence coils and impedance, etc.
                      There are very subtle energies not well understood.
                      --morpher44
                      • https://www.youtube.com/watch?v=S0wbEl7caTY
                        • https://www.youtube.com/watch?v=NpNEJl1lmUY
                          Hendershot Generator Nachbau Teil2 - Öffentliches Projekt
                          • Lots more Info here
                            Free Energy - Freie Energie - OverUnity.de - Hendershot Generator
                            In German though
                            • UNLIMITED FREE ENERGY IDENTIFIED Part 2 - YouTube
                              • Many More files here too
                                Çàãðóçêà ôàéëà
                                Password zaryad
