Hendershot Replications
  • Comment
    • Some thoughts on hand-made capacitor
      I looked up Kraft paper, and there are several
      thicknesses and weights:
      thick (inches) weight (lbs)
      .003 30
      .004 40
      .005 50
      .006 60
      .007 70
      .009 90
      The formula for a capacitor is C=eA / d
      were C is capacitance in Farads, e is permitivity, A is
      area in square meters, d is distance between plates.
      You can re-arange this formula to compute for d.
      d = eA / C
      e is 8.854187817E-12 F/m * 3.85 (constant for paper).
      Plug in the 7.8nF desired capacitance, and
      2.75 in by 91.125 in for the size of the capacitor (roughly),
      you end up with a d equal to
      distance = 0.027818 in (0.706566 mm)
      To achieve that distance between plates with say 30lb
      Kraft paper, you would need about 9 sheets
      -- RATHER THAN ONLY 1 SHEET --
      This may explain why some have not been able to get the 7.8nf value
      with 1 sheet of kraft paper.
      The plates were too close together for this smaller capacitance goal.
      The instructions in various stuff written about Hendershot's
      Fuelless Generator don't mention putting MORE sheets between
      the plates to create that thickness ... but the math works
      out that way.
      Wax paper, on the other hand, has a thickness of about 1mm --
      .03937 in. and dielectric constant of about 2.7.
      Plug in those numbers an you need this thickness:
      distance = 0.019508 in (0.495514 mm)
      which works out to be "thinner", actually than the wax paper itself.
      You can succeed with one sheet of wax paper if you perhaps
      lengthen the foil to 93 inch or so with this thickness and
      this dieletric constant. Hence, it appears that
      - Wax Paper -- 1 sheet
      - 30lb Kraft paper -- 9 sheets between plates.
      The paper has a better dielectric constant, so you need to adjust
      the plates so that they are more distant from each other to
      compensate -- according to the math.
      • rolled Capacitor formula
        Actually, there is another formula for capacitance that might
        apply even better.
        See this URL: Welcome to the Laushaus
        • Graphite Pencils....
          Hi Guys/Gals,
          I've performed another interesting experiment today that might
          be of use to some of you. I have this basket weave style coil
          I'm working on in the Bashar Thread that uses "pencils" for one
          of the diameters in the lower coil. I went around my house and
          collected all sorts of pencils for this purpose. I also thought
          it would be interesting to have graphite in that "eddy current"
          area of the basket weave "dowel" locations.
          Today I hooked up an audio amplifier directly to the basket weave
          coil and cranked the volume. You can hear white-noise, static.
          Ok. Now I took a very powerful magnet and moved it around the
          circumference of the coil, wiggling it a bit, and moving it up
          and down, and turning its orientation, etc.
          When hovering over certain pencils, there is a distinct "swishing"
          sound. You can even approach with the magnet over these
          pencils, and here a definite sustained "swishing".
          Other pencils, specifically #2 pencils I bought @ Target, are
          DEAD quite.
          Hendershot's Fuelles Generator was reported to have used
          graphite for the dowels or carbon with wax,
          and this was always a mystery as to
          whether or not this matters. I'm starting to think it might.
          They are similar to a "graphite" microphone and have
          pzioelectric effects and magnetic effects probably.
          Under the pressure of magnetic fields, they appear to be
          "reactive" and create swishy noises on the wire.
          If you google search for "parametric oscillator", we are looking
          for ways to "tweak" the resonant frequency and/or the damping,
          as a way of getting positive feedback.
          quote: "It may be that Hendershot did not use just paraffin
          between the capacitor energy accumulator and the outer
          coils, but instead, used a carbon compound which was sealed
          at either end by paraffin wax."
          • Fluxgate Magnetometer thoughts
            I have also been reading up on Fluxgate Magnetometers,
            and the cylinders Hendershot has in his fuelless generator are
            likely a Fluxgate Magnetometer. If that is so, many of the equations
            needed have already been worked out. These device became
            popular right around the 1930s.
            You need a sensing coil...
            You need a ferromagnetic material (with some B-H curve), in the coil.
            You need a excitation coil.
            The frequencies can be LOW and will be limited by this
            B-H curve of the material selected. The higher the frequency
            you can go within these limits, the more voltage will be induced.
            The Earth's field can be the field being sensed ... or another field
            (such as one from a magnet).
            The following ways, via the equation, can be exploited to increase
            voltage in the sensing:
            1) Increase excitation frequency (within the cut-off limits of BH curve)
            2) Increase the number of turns in the sensing coil
            (or have a novel way of winding that is not strictly "solenoidish"
            3) Increase the cross-section of the ferromagnetic material
            (but, a larger cross-section will require larger current while sensing)
            The modern trend in these devices is to go smaller and smaller
            and use CMOS, etc.
            But for power generation, it seems that scaling the other way,
            with larger magnetic fields, larger number of turns, larger cross-sectional
            area, may yield LARGER effects.
            I'm reading also that "even today", the complexities of this
            phenomenon are not fully understood.
            I think the Hendershot device does appear to have some
            "fluxgate" properties.
            Fluxgate Magnetometers - YouTube
            Flux Gate Magnetomethttp://www.youtube.com/watch?v=Y3_vr8VIdpEer or Solid state Generator? - YouTube
            • Watch the new Movie "Atlas Shrugged" at all about what's happening on earth right now and they found a free energy device
              • I got this message from serbenuk on Youtube
                много було эксперементов но генератор незапускается мы растроенны! но наш ведущий обещял разобраться и всеравно этот генератор запустим!!!
                Translated on Google
                Bulo much experimentation but the generator does not start we rastroyennykh! but our lead obeschyal vseravno understand and run the generator!
                Im not sure if anyone understands Russian
                Hendershot пояснение Романов - YouTube
                Gaz
                • I did a search on the site they had posted below their Youtube Vid
                  and cam up with this
                  Форум
                  • I read this today
                    I dont know if it helps at all
                    The Hendershot Motor Mystery by Tom Brown. There are also other devices in use that involve some of Hendershot's ideas, such as the Swiss M/L Converter
                    • These guys here are talking about using Carbon Rods
                      123people result forhttp://open-source-energy.org/forum/showthread.php?tid=153
                      • Its magnitude at the Earth's surface ranges from 25 to 65 T (0.25 to 0.65 G). It is approximately the field of a magnetic dipole tilted at an angle of 11
                        Earth's magnetic field - Wikipedia, the free encyclopedia
                        • Originally posted by Gazzasore View Post
                          Hendershot пояснение *оманов - YouTube
                          Gaz
                          Good day to you, collegues! Excuse me for my bad English, please.
                          "This message from serbenuk on Youtube " says in bad Russian: "It was much experimentation performed but the generator did not start. We are in a bad humor. But our leader promises to understand Hendershot principles and to make this generator working (some time later...)"
                          That Mr Romanoff (the leader) only speaks well, but not have any working devices, alas...
                          Oleksii
                            Форум
                            Thanks for Grate information!!! In Russian!!! (I`m Russian-speaking, from Ukraine)
                            It begins: Бестопливный генератор Хендершота
                            It deals with treating Hendershot handmade Condensors as EH-antennas and calkulations of their parameters with specific software: ehmanager12.zip (http://realstrannik.ru/media/kunena/...hmanager12.zip)
                            program description: -
                            All about EH-antennas (DIY - recommendations): -
                            ehant.qrz.ru/index.html
                            In English see: Ted Hart CEO
                            EH Antenna Systems, LLC
                            EH Antenna Systems
                            Happy New Year - of the Black Snake!
                            Oleksii
                            • EH-antenna
                              Oleksii
                              Yeah I went to the site and just clicked on the translate button to
                              read it in English, and saw the bit about EH-antenna. I had never
                              come across this style of antenna before and so this was interesting.
                              It is another group concluding that we are dealing with Ghz reception
                              using a loop of wire, and this hand-made capacitor "resonator" thing
                              with a geometry that matches Ghz wave lengths.
                              In the presence of strong Ghz radio towers, it probably works great.
                              When not near them, however, the trick would be to boost the
                              gain "somehow". So I could see that this is a way of giving a little
                              power -- perhaps to start the machine going -- similar to how running
                              a long wire up a pole could do that too. Yet, these cylinders are
                              more compact .. for a nice little antenna unit.
                              The other aspects of the fuelless generator are more mysteries.
                              Barry Hilton's book has a good discussion about magnetometers
                              in an appendix, and I'm thinking this is a promising area of research.
                              I'm wondering WHY we haven't had public-domain research into
                              power generating using "magnetometer-like" circuits.
                              Stephen Mark's TPU comes to mind as a device that looks very
                              much like a classic fluxgate magnetometer. I wonder if Mr. Mark
                              was just intersted in magnetometers and got this "crazzy" idea
                              of scaling one up to a really LARGE size .. to see what would happen.
                              I made a crude magnetometer from some Hendershot-like solenoids
                              I had made. My solenoid used STEEL bolts as the core. That turns
                              out to be DUMB. Steel is "horrible" in that the permeability constant
                              is 100 (iron is 200), and also steel has "memory" of the field.
                              You want Iron cores or "Electric Steel -- i.e. Laminated Steel found
                              in transformers"). This solenoid had two bolts, with the coils wound
                              such that one would produce a North, one would produce a South.
                              Around this I wrapped 160 feet of 20 AWG magnetic wire.
                              This would be the sensing coil.
                              The thing worked ... although not very good .. as a magnetometer.
                              It is exciting so see the ECHO pulse in between your "excitation" pulses.
                              This ECHO pulse just APPEARS and changes SIGN and MAGNITUDE
                              depending upon the magnet you bring nearby and its polarity, etc.
                              The magnitude can exceed the pulse you put in ...
                              This is a crazy non-linear thing... Wild.
                              Further, as you hold the magnet NEAR the solenoid, it vibrates in your
                              hand with a pretty intense power .. for such low power input.
                              At 30Hz, I can hear the table vibrations just a bit.
                              I'm using a 9Volt battery to power the thing ... and pretty WEAK magnets.
                              So ... I think I've worked out that the bar-solenoid-magnet are
                              an element of a magnetometer ... and it is these ECHO pulses that
                              we want to create from low power input.
                              The "antenna" can be the source of low power with a low-frequency
                              oscillation (converted from these high-frequency Ghz reception).
                              This low-frequency oscillation is need ONLY to "excite" the magnetometer
                              solenoids. Another coil can PICK-UP the echo pulse ... which can be
                              higher in magnitude.
                              This can open the door to many different approaches for doing the same
                              sort of thing. What we are really after, I think, is device that
                              is like a magnetometer, that harvests power from a magnet, after
                              setting it into a wild oscillation. This is not free energy ... the magnet
                              will be "consumed" as a fuel and will be demagnetized ... over time.
                              You would then need another magnet to fuel it. In this sense, this
                              sort of device would not be "fuelless" ... and it does take POWER
                              to make magnets. No laws of physics violated here.
                              • Hi guys regarding this schematic how much capacitance and voltage are the big caps?
                                and what's coil D? baskets have three coils no?
