Hendershot Replications
  • Originally posted by NOMDI View Post
    I tried many "door bells", "PHONE BELLS" "fire bells", etc... with many different voltages (AC/DC, with or without included magnet...).
    I've noticed that high voltage bells always have high resistance (it seems obvious I know).
    The only bell made for 110V I found has unfortunately a single coil... I measured 1370 Ohms and 1.15 H and the wire is very very thin... Too thin I guess. I heard that "antique" 110V railway station bells are made with two coils and I try to find one on EBAY...
    Concerning the 7.8 nF capacitor, i made some experiments with home made, using garbage bag polyethylene film (not easy to make, too). I had some results but I wonder if the only important thing would be the difference between the two tanks capacitors. This is not a new idea, I know... but I can't find out what action the coils could have on capacitors. This is beyond my knowledge and imagination. If somebody knows....
    Here is good one 2 VTG DOORBELL YARD BELL #641 - eBay (item 390106534943 end time Oct-25-09 18:05:33 PDT). I would get it myself, but I'm going on vacation for 2 weeks.
    I'll give you my imagination about coil/capacitor. It was tuned to the local AM (~520KHz) radiostation. And it was building potential difference on a cap ...
    The rest is not clear yet, but I'm thinking about it
    Mike
    • morpher,
      what did you use as a base cylinder for your capacitor?
      Mike
      • Lenz's Law
        @NOMDI
        Lenz's Law!!!
        Take a neodymium cylinder magnet and drop it down a copper pipe
        with a diameter slightly larger than the neo.
        Notice that it doesn't fall at 9.8 meters/sec*sec
        Rather it slowly floats down and arrives out the other side
        -- as if traveling in slow motion.
        The eddy currents established in the copper due to induction
        hold the magnet and resist its decent.
        So, now lets instead wrap a COIL of wire around a copper cylinder
        and pump AC currents through the coil at high voltage.
        What do you imagine will happen INSIDE that copper pipe?
        I tried it ... and to my surprise, when I switched everything
        off, waited several minutes and then attempted to handle
        the copper pipe, I got a BIG ZAP on my fingers. Ouch!
        The cylinder retained a very large charge.
        I think this can be explained by Lenz's law ... and may be
        the reason that Hendershot placed his capacitor INSIDE
        his coil.
        • cylinder
          Originally posted by mlurye View Post
          morpher,
          I am using a *pristine-empty* paint-can cylinder which measures:
          height: 4.75 in
          diameter: 4.25 in
          and is a magnetic stainless steel
          *unknown permeability*
          and purchased at Ace Hardware.
          My Hendershot-like coil has a 5 inch diameter ... not 5 15/16ths.
          I am not *yet* going for an exact replication of Hendershot's
          circuit ... but rather I'm studying various properties of this
          device to try to get a feel for what can be changed ... how
          its put together ... how to reverse engineer it.
          The 5 15/16ths diameter *may* be important ... I don't know.
          If Hendershot selected that dimension only because it was
          convenient relative to coffee cans he original built the thing
          from, then that dimension is not crucial.
          If, on the other hand, he selected that dimension due
          to some sort of standing wave geometry ... and *special* frequency,
          then that diameter becomes very important.
          I'm thinking that you can vary this diameter .. because
          from what little I know about coils and radio design, etc.
          what matters more is the inductance ... and not so much
          your coil dimensions -- within limits.
          You don't want a coil that is TOO large a diameter and
          TOO narrow a height ... unless your trying to build a loop antenna.
          You don't want a coil with a very narrow diameter and
          a long height ... as the magnetic fields will be very
          week. So I imagine this geometry doesn't exactly have
          to match ... given you can achieve inductances and resistances
          similar to Hendershot.
          So I think if you vary the dimensions a bit, like I have done,
          you still should observe some effects ... and then as
          we understand what is going on, we can optimize
          those effects.
          • Handmade Capacitor
            @MORPHER 44
            Congrats ! I think you're really on something !! Nobody thought about Lenz before you...
            But why did Hendershot not use Copper for his tanks ?
            Or maybe he used a copper foil for the capacitors ?
            Sorry for the electric shock but i hope I'll see your experiment on YouTube !
            • am band?
              @mlurye
              I've been thinking about this quite a bit ... and here are some thoughts
              regarding this topic...
              The tank circuit composed of the 7.8nF cap and the 50uH (or so)
              would resonate at about 255hz -- very ball park.
              This is BELOW the AM band.
              Yet, the inductance the cap sees is not exactly 50uH ... and
              is rather MUCH MUCH large due to the very odd circuit
              on the other side of the 50uH coil. Under it is a 64-turn coil ...
              so the two become a transformer -- essentially.
              There is a formula -- in circuit analysis -- that provides
              a way to calculate at sort of *equivalent* inductance
              of a transformer ... given the inductances on either side.
              What is interesting about the Henershot circuit is that he
              wires things all around through as many inducances in series
              as he can .. including the 120/24VAC 5:1 transformers ..
              both primary and secondary.
              So in terms of an *equivalent* inductance, that 7.8nF
              cap sees an inductance -- due to the transformer over
              to a weird highly inductive circuit on the other side.
              Hence, its resonant frequency is much lower now ...
              perhaps in the audio range.
              Now comes the debatable part.
              Is the capacitor wrapped around a magnetic cylinder or not?
              It is probable that when Hendershot originally used coffee cans,
              that his cylinder was magnetic.
              He may have switched to a non-magnetic stainless steel.
              That choice becomes important here in that a cylinder
              with permeability will bring the tuned circuit even LOWER
              in frequency ... approaching the 100 Hz buzzer frequency.
              The reason that resonant frequency is important is that
              it allows for certain frequencies to travel through the circuit
              w/o attenuation.
              However, his circuit is so odd that something else might be
              occurring related to polarity change.
              His circuit seems to take up spikes ... that dampen ...
              and down spikes that dampen ... and turn them
              into more of a square wave due to the LRC timing constants
              of his big 40MFD, 80MFD caps ... and inductances.
              So it is possibly that this tank circuit, while ringing ..
              holds the magnet-bar-solenoid in a state whereby
              the bar can't commit which direction to go ... towards
              the magnet ... or towards the solenoid ... until it
              finally SNAPs ... producing a pulse.
              I don't really know ... but something is definitely interesting
              here ..
              and I'm very impressed that there are no DIODES in this
              circuit ... just passive components ... coils, caps, transformers....
              • nobody before me? -- lol
                I'm a reverse engineer only ... speculating like crazy.
                It would be good to have more observations, more
                replications, etc.
                Lenz's law will work with aluminum as well ... and ... yup... capacitors
                have aluminum foil ... don't they?
                Be aware, however, that with diamagnetic material in your coil,
                your inductance actually DROPS -- the opposite of permeability.
                • @morpher44
                  I confirm, modern capacitors use aluminium.
                  My mistake about a copper tank : you re right, the permeability would fall dramatically. It was just thoughts...
                  The relative permeability is 10 000 for pure iron, 40 000 to 50 000 for steel with 3% of silicon (very high) and 70 000 to 130 000 (huge !) for Mumetal/Permalloy C.
                  I have no data about aluminium or about amagnetic stainless steel but I just notice that steel with 3% of silicon is well known to be used in the best transformers and inductances and is ...magnetic.
                  So I dont think amagnetic material has ever been used by Hendershot.
                  The best compromise between efficiency and availability at his time is probably regular steel...
                  • the earth's field
                    Another part of the Hendershot myth is that the Earth's magnetic field
                    somehow plays a role...
                    Regarding the statement I just made:
                    "...ringing holds the magnet-bar-solenoid in a state whereby
                    here .."
                    The ringing in the tank circuit ... is a damped oscillation.
                    The Earth is rotating in a huge magnetic field and
                    Hendershot thought of the Earth like a stator in an electric
                    motor.
                    Is it possible that as the Earth rotates
                    and you pass over a certain field line,
                    that it can create a TWANG or PLUCKING of the
                    neutral line (ala Wesley Gary) or Bloch Wall?
                    So like the string of an electric guitar being PLUCKED,
                    the solenoids may pick up the pluck and pass it along.
                    Wouldn't that be cool!!! Again I speculate...
                    • pickup coil technology
                      One similarity to the sorts of coils Hendershot built for his
                      early "toy motor" circuit and modern magnetic pickup coils
                      is that they both have coils wrapped around
                      permanent magnets (such as AINico).
                      On a guitar pickup, when you pluck a string, the string
                      vibrates over the pickup for a time ... producing an
                      AC waveform that will ring for a while until the string settles down.
                      A simple experiment with an electric guitar and AMP might be
                      to put the AMP/guitar just on the very verge of feeding back.
                      Rotate the guitar to various EARTH orientations:
                      North-South ...
                      then
                      East-West...
                      Does the guitar go into feedback EASIER on one orientation
                      versus the other?
                      I don't have an electric guitar ... but if someone out
                      there does, would you mind doing this experiment?
                      Pickup (music technology) - Wikipedia, the free encyclopedia
                      • "Nuclear spins in the Earth's magnetic field"
                        This is a very interesting paper:
                        http://www.google.com/url?sa=t&sourc...TzZI_4r2TriThA
                        A couple things of note:
                        * The circuit he presents in his paper is pretty easy ... 555 timers,
                        741 op-amps, coils, transistors, etc.
                        He presents this for students who want to mess around with NMR
                        technology and measure proton spins using the Earth's field.
                        * The Larmor frequency various, depending upon your location
                        on the planet. Knowing it, you can measure the spin echo
                        and actually hear proton rephasing in the audio range ..
                        or see it on an oscilloscope.
                        * Two coils are needed ... one polarizing coil, one receiver coil.
                        The receiver coil is situated INSIDE the other and is oriented
                        90 degrees within the cylinder of the polarizing coil.
                        * The coils are NASTY. Converting to inches .. easy for me to
                        comprehend ..
                        Polarizing coil: Diameter 6.283 in, Length 6.2992 inch,
                        560 turns of 14 AWG.
                        Receiver coil: Diameter 2.938 in, Length 3.937 inch
                        2700 turns of 30 AWG
                        I'm immediately struck by the fact that these coils have
                        a huge number of turns. The receiver coil has a HUGE
                        resistance which would attenuate the received pulse
                        from the earth's field by a large margin ..
                        and the polarizing coils diameter is similar to the Hendershot
                        diameter.
                        I'm wondering if a better coil design could pick up
                        this spin echo better ... providing a larger EMF.
                        • By the way another thing about Hendershot circuit, it is in a sense symmetrical and balanced. Same parts on the left and right, and 110V 60W load is balanced by 110V buzzer.
                          Mike
                          • Originally posted by morpher44 View Post
                            morpher,
                            looks like you are going Moray's way. And may be it would be good direction to go in order to find working frequency.
                            Mike
                            • Lervitation circuitry.
                              ART TEC - Guy Marsden's home page has a levitation kit that might be adapted to work to help oscillate an armature centered on a magnetic neutral line. The electro magnet is wired to apply pulses in both directions based on Opticutter or Hall sensor trigger signals. The armature might need guide magnets to keep on station.
                              • Finally got his sketch to upload! On top is a magnet cushion of a repulsive disk and a ring neos, the disk attached to the solenoid plunger and the ring to the top of the solenoid. The solenoid plunger is attached to the soft iron bar armature, and attracted to the side of the horseshoe magnet. There are opposing tensions. A double pole double throw reed relay is triggered by the top plunger magnet and reverses the polarity of the solenoid, driving the iron bar up and down.
