Hendershot Replications
  • Armature motor.
    I left a sketch of an solenoid armature motor at the bottem of page four. I agree that oscillations might occur spontaniously, and that if the operating amperage were to drop while running the solenoid fluctuator motor, it would be a good indicator, and the armature could be be freed to flutuate on it's own after power´s cut off. I think motoring into the zone to fish for self oscillation would allow for testing by a drop in amp draw to help locate it.
    • another observation re: Hendershot photo
      In the "From the Archives Of" document ... page 17,
      there is a photo of Lester titled
      "Lester J. Hendershot with Generator in his workshop",
      Circa 1950.
      One interesting thing I just noticed about this photo
      is that it appears that the load that he is
      using is an AM radio.
      I am realizing that this photo was probably created for a very
      specific reason.
      I'm again speculating that it is intended to
      convey that his device does NOT
      produce AM band frequency interference.
      If true, that is yet another clue that this device does not
      oscillate in the 500khz to 1.6Mhz range.
      Providing AC waveforms in that range to a standard
      60hz transformer would not be ideal and power would
      attenuate.
      That version of his device depicted appears to be very
      cleanly made, wires tightly organized, solenoids and
      magnet aligned along the same longitude (or is it latitude?).
      • morpher,
        I would advise you to build exact replica of Hendershot device, it would be the best way to understand how it works. Even if it doesn't pick up anything, you can feed signal in and trace it.
        I did look at other devices and I do believe that we have the best chance with Hendershot device. It has the most complete schema and good guide on how to build it.
        Mike
        • on the subject of exact replication...
          So far I have been studying a very small subset of the full
          circuit to get an understanding of how things could work ..
          and to help me make decisions about further construction.
          There are so many things I still don't know ... and I have a shoe
          string budget and not a lot of time (day job) ... so progress is slow.
          I'm hoping for others to come along and attempt replications in
          different ways so that we can compare notes.
          If I use ferromagnetic cylinders and someone doesn't, will we
          see a difference.
          Can I get results with a 5 inch diameter just like a 5 15/16 diameter?
          Do the 40/80 MFD cap value matter ... or can 30/100 MFD work too?
          How exactly is the bar - magnet - solenoid to be built cheaply?
          Yes I know progress seems slow ... but remember that
          Hendershot worked on this from 1928 to 1961 -- his
          entire adult life.
          I'm also very surprised we are not hearing from others who
          have already attempted the Hendershot device.
          There are some folks out there who have already tried it.
          Their notes would be invaluable.
          Please share if you dare!!!
          • The human ability to tune...
            One thing that made the radio so compelling a hobby in the
            early 1900s was the thrill of building something from scratch
            with oatmeal cartons, wire, crystals, home made salt water
            capacitors, antennas across the roof and yard, ground pipes.
            It was MAGIC!!!
            Another very human aspect of old time radio was the notion
            of "tuning". You felt so SMART when you could tune in some
            very hard to receive distant station ... achieving that
            very difficult resonance value which might be lost by the slightest
            mussel twitch.
            The Hendershot device is very interesting because there
            are TWO coils to tune -- a left and a right.
            I performed a pretty interesting experiment tonight.
            I have two 216uH 5 inch diameter basket weave coils
            that I made for some earlier experiments.
            I connected one up to channel 1 of the scope.
            I connected the other up to channel 2 ... and
            put the scope in X/Y mode.
            These coils w/o any other components, receive RF up
            and down the spectrum ....
            On the scope I see a nice 45 degree line because
            both coils receive exactly the same RF signals
            at exactly the same time.
            Now for the fun "human tuning" part.
            If I place these coils near each other -- say
            3 inch appart or less -- and move my hand
            near one ... or touch one ... the
            capacitance I can add will boost the amplitude.
            That boosted EMF in the first coil is easily received
            by the other coil if they are near.
            I find that I can apply different amounts of pressure
            to the wires, etc. and actually alter not only
            the signal strength .. but also the PHASE between
            the two coils.
            So by watching the scope ... in a sort of biofeedback sense,
            I can manipulate the situation to increase the voltage
            to both coils and the also get the phase to be exactly
            90 degrees different, producing a CIRCLE!!!
            See the attached image for Lissajous patterns.
            So in the Hendershot design, I would not underestimate the
            human ability to TUNE in the exact relationships ...
            between phase and voltage needed to achieve
            resonant oscillations.
            • gravity sucks...
              Yes... interesting.
              Find the sweet spot with this magnetic stuff might
              be very difficult indeed.
              One thought about going up-down instead of left-right is that
              when you have to go up, you have to expend quite
              a lot of power to fight gravity. Down ... no problem .. let it fall.
              So there is an asymmetry in that orientation which might
              not lend itself nicely to a sine-wave.
              Left-right, on the other hand, might be easier to acheive
              a sort of symmetry and balance.
              I think we are still very much earth bound and always
              have to consider gravity ..
              The Wesley Gary thing is kinda cool in that it does go left-right
              and up-down. Like a see-saw.
              If the bar, in the Hendershot device, is to be held between
              the magnet and the solenoid, without touching either
              (and I'm not sure that is the way yet), then
              ideally the bar would float in some very low friction medium.
              Doorbell manufactures use a sort of rubber washer to hold
              the bar -- not unlike a xylephone.
              • I was playing with coil, and found that it resonates at multiple spots and one of them ~5MHz. I'm having hard time to tune it at 5MHz.
                Mike
                • which coil?
                  Which of the 4 coils on the Hendershot cylinder are you referring too?
                  5Mhz does seem a tad high.
                  The self resonance of these 4 different coils will be
                  lower than that probably.
                  • Actually all coils are connected according to schema, only I replaced load and buzzer with LEDs. Interesting part is that sweet spot at exact 5000000Hz.
                    Mike
                    • impedance...
                      @mlurye
                      Certainly the solenoids would bring that down a bit.
                      Also, do you have the 5:1 transformers in circuit?
                      They don't like high frequency.
                      • Yes transformers are in. I don't have solenoid, so can not try with it.
                        Mike
                        • 7.8nF hand-made caps
                          I just realized WHY there are 3 plates:
                          Foil A : 91.25 inch x 2.75 inch
                          Foil B : 40 inch x 2.75 inch
                          Foil C : 40.375 inch x 2.75 inch
                          The capacitance between foil B and A will be one
                          capacitor .. the capacitance between foil C and A
                          will be a second one. They are essentially
                          connected in series via foil A.
                          Notice that the width of B and C + a gap of 3/4 inch
                          still fall short of the length of foil A.
                          I suppose there is suppose to be some overhang there
                          to be conservative ... about 5 inches either side.
                          Hendershot appears to have been using a
                          "double-layer capacitor" approach:
                          Electric double-layer capacitor - Wikipedia, the free encyclopedia
                          • Dan A. Davidson
                            In reading the Don Smith thread, I saw a mention of
                            Dan Davidson's patent.
                            Wow! This looks similar to stuff Hendershot had done.
                            Acoustic-magnetic power generator - Google Patent Search
                            Dan's patent mentions these:
                            Magnetic motion electrical generator - Google Patent Search
                            Electromagnetic convertor with ... - Google Patent Search
                            • double layer capacitor
                              I've read somewhere that nowadays double layer capacitors are used to reach very high value capability. Hendershot claims a 7.8 nF which is very low. If he used the handmade capacitor with this technology, using the foils (that we can't see on any picture, of course) in the serial way, we can speculate he did it only to get a very high voltage capacitor. It seems to be logical because the LC cell is made to be tuned a the resonance point, which means high voltage pikes. Can we suspect that every replication made with a single layer capacitor (made of paper which is not as good as actual plastic films for insulation) has "dead born" capacitors ?
                              I also guess that this could explain the value of 1.3 mF (we've seen in his son document), which could be in fact 13 nf, almost twice the value of the 7.8 nF he could have first experiment with a parallel double layer capacitor...
                              • I can tell you one thing, test it with standard capacitor and build one and you definitely will see the difference.
                                Mike
