Hendershot Replications
  • synchro
    Wesley W. Gary.
    @Morpher44
    You scored a diresct hit! Study the neutral line diagram on his first patent. You are in for real enlightenment and a huge success story. if you master the simple understanding presented here by Wesley. I have been exploring ways to improve the motor generator, and hit on the reed relays. Try and build a simple reed relay magnet motor from plans on the web, to get a feel for the switch. Just a pulse coil wired in series with a battery and the reed switch. I will scan some sketches in and post them, but I'm sure your head will begin to fill to the brim with, ring magnet spring cushions on the solenoid plunger etc. A mini linear cscillator today, that operates with a 1.6 mm throw, costs under five dollars, and runs on 3 volts. I believe Steve Mark, the TPU inventer merely matched one of his piezo speaker elements to an armature, and vibrated it over a small but powerfull horseshoe magnet. Also, powerfull neo magnets are bad for the motor for the same reason a better material armature with less inductence would be. Weaker magnets transfer their field better, and soft iron demagnatizes easily.
  • morpher44
    Wesley W. Gary
    Originally posted by synchro View Post
    Study Wesley W. Gary's analysis. It is a critical necessity for the success of your project. Beware of potentially fatel shock from this fluctator if you suceed in generating power.
    I found this:
    TRIUMPH OF ELECTRICITY.; FURNISHING LIGHT FOR NEXT TO NOTHING. WESLEY ... - Article Preview - The New York Times
    from Dec 14, 1878 - NY Times.
    Cool article.
    And this:
    Wesley Gary's Magnetic Motor
    Do you have a URL with Gary's analysis?
    This does look very interesting.
  • synchro
    Neutral zone.
    @Morpher44
    Thanks for the response. I'll try and upload a sketch. There are three tells in the description of the magnet tuning of the Hendershot device; First, the distance between the surface of the horseshoe magnet and the soft iron bar is described as an air gap. This distance might be roughly estimated as under a quater of an inch. Secondly, the bar was positioned with a wire in each hand with striped leads. Passing the neutral generates a current in the iron bar, this is detectable with a multimeter. The two wires were attached to one. Thirdly, cross wireing was used, a reverse polarity circuit for the opposite movement of the solenoid, necessary to keep the bar on station. Just cross wire one solenoid and attach it in series to a battery and the reed switch at the end of the bar, and the other straight wired to the other reed switch. Include an LED at each end. Now as you position the iron bar up to the magnet, the first LED should blink, then the second as you pass the bar through the neutral zone. Now it's ready to flutter and generate power.
    Hendershot uses induction transformers, but you can get all the same power just by winding copper wraps around the center of the soft iron bar. It is a mistake to let the bar touch the iron. The fluctuation and polarity reversal in the 20 to 200 Hertz range does what a rotating bar magnet would do at high RPM. A hairīs width is a bit trickey, but in the range of glue and popsicle stick
    hobbyist. Study Wesley W. Gary's analysis. It is a critical necessity for the success of your project. Beware of potentially fatel shock from this fluctator if
  • mlurye
    Originally posted by morpher44 View Post
    @mlurye,
    Running a quote from "Hendershot in Farbe.doc" thru Babel fish ...
    morpher,
    Here is the same document translated by Joit MEGAUPLOAD - The leading online storage and file delivery service (thank you again Joit, very nice job) check title of this document. It was built by Aho.
    And yes Hendershot did use ferromagnetic materials for the ring. My assumption, it was used as base for capacitor and nothing more.
    I just finished building 1st coil, it took me 3 days. 2nd one should be a little bit easier
  • morpher44
    latest video...
    In this video I show some results while testing
    Figure 5.13 (or half of the circuit really)
    from Barry Hilton's book.
    YouTube - "Hendershot Fuelless Generator" -Mark Hendershot 1995 Update
    After I made the video, I removed the iron bar
    and put the relay right in the horseshoe magnet.
    This dropped the supply current down to 2.5mA @ 6V
    (< 15mWatts), and the Neon lights just fine
    with nice 300 volt spikes.
    I am not yet able to light a 4Watt incandescent bulb yet, however.
    I wonder if these 300 volt spikes could do electrolysis
    to make hydrogen?
  • morpher44
    positive feedback...
    Originally posted by mlurye View Post
    To begin with, I will assume that we are dealing with air coil.
    @mlurye,
    Running a quote from "Hendershot in Farbe.doc" thru Babel fish yields:
    "Opinion of the Trafos/transducer in „“PCU links. It acts here around American 110V on 6,3V Netztrafo. The metal rings of the PCUīs used with this version are from coldly rolled soft iron and are thus magnetic. They are several times spot welded at the seam/overlap place. The inside diameter of the metal rings is 5.25 tariff, with a height of 2,75 tariff. "
    I believe this is an actual Hendershot device they are discussing .. depicted
    in the photographs.
    This lends additional support that the cylinder is to be magnetic ...
    and that permeability is to be assumed in this coils.
    In order for the tank circuit to ring when a pulse arrives to it,
    it will need
    R*R well below 4 * L / C
    R can be kept small by using thicker gauge wire.
    Hendershot used 28 AWG for this outer coil.
    Other coils too have a pretty large gauge wire.
    C can be made tiny ... L can be made large.
    There are limits though since you don't want the
    bandwidth too narrow, making tuning impossible.
    The smaller you make C within certain limits
    and the larger you make L, the better situation
    you will be in in terms of a long duration damped oscillation.
    Also, since the oscillation angular frequency is
    Wd = sqrt( 1/LC - (R/2L)^2)
    again, by making L large and R small, you approach
    the "ring forever" ideal. If R could be made zero,
    it would ring forever.
    If there is positive feedback happening in the Hendershot
    system, R can be made extremely small due to regeneration ..
    but again Large inductance helps the situation.
    Also, the more ideal transformer with iron as core implies
    also that the formula for the inductance the tank circuit sees
    becomes a bit simpler ... approaching:
    L = K * sqrt(Lp * Ls)
    where Lp is the inductance on the primary and Ls is the
    inductance on the secondary side (and all other series inductance
    you wire on that side as well), and K is near 1.
    This implies that the secondary side should also have a very
    LARGE inductance if possible to make the answer work
    out to a large inductance.
    So of the various Hendershot circuits to consider,
    are the ones that have the current path on the secondary
    side (of that larger coil) wind around through as many
    inductances as possibly to make for the situation
    whereby the tank circuits rings longer ... going into feedback
    after each pulse from the buzzer ... OR
    perhaps rings exactly at that buzzer frequency.
  • morpher44
    mechanically challanged...
    @Morph44.
    I saw your latest video running your relay and magnet around the iron bar.The Neutral line is close to the surface of the permanent horseshoe magnet. When it runs through the iron bar, the bar is depolarized, however still strongly attracted to the magnet. Inside the neutral line the poles form in opposition to the horseshoe magnet, while outside they reverse into attraction mode. Picture an iron bar with a soft iron rod attached to the center and running first from the bottem of the armature, through a heavy spring, a frame followed by two solenoids in tandem, and a wing nut attached to threads on the very end. Now, placeing the magnet on the frame sideways like Wesley Gary, the soft iron bar can be positioned so the neutral zone runs through it and is depolerized. Now, two South pole activated Reed relays must be positioned at the ends of the iron bar, wired reverse polarity to one of two batteries that drive each solenoid independently. The bar first must be jiggled out of the neutral zone, then one side polarizes south and triggers the solenoid to carry the armature down through the neutral zone to the side of reverse polarization, and a fluctuation follows. This is a tensioned self positioner of my own design I offer you to try and recreate to generate a great amount of intense power from the magnet armature. The fluctuation only needs to be a half millimeter in width. What do you think?
    synchro.
    @synchro
    I think I'm mechanically challenged.
    I admire German engineering where parts are so nicely machined
    and precision is an art form.
    I'm good with scotch tape, and cardboard and glue ... and that
    is about it.
    There is a temptation to play with these strong neodymium magnets,
    but they are so strong that they border on dangerous.
    I buy this notion of neutral zone and I observe that when
    the metal clapper SLAPs against the core of the coil, that a BURST
    of energy is released and easily received by nearby coils.
    I imagine zillions of little atoms suddenly spinning around
    as the metal makes contact.
    When the metal is pulled off, again, huge burst!!
    So yes there is the nice feature in these buzzers and relays
    and coils of back EMF to recover the other-side of your pulse energy ..
    but if you slap metal together, there is yet another untapped
    energy phenomenon in the metal itself.
    Do you have a URL you can share showing us your design ... or
    can you paste a schematic or diagram or picture?
  • synchro
    Neutral line.
    @Morph44.
    synchro.
  • morpher44
    more notes... can someone help with circuit analysis?
    Did you figure out direction of coils and how they are connected? I'm certain that direction of coils and trasformers is very important.
    I decided to wrap counter-clock-wise when facing into the coil
    from the top.
    The notes state that BOTH coils are wrapped the same.
    I think it is only important that you stick with the same
    direction for both.
    Hendershot's circuit looks like it switches the wires on one side ...
    which might imply both coils are in fact the same ... and he
    alters direction by that phase change.
    I do suspect that the left coil and the right coil are
    to do the opposite behavior ... one going negative while the other
    goes positive. If they oscillated completely in phase with each
    other, the potential different between them would be ZERO.
    If they oscillate with a phase difference, a potential difference
    can be established between them. A 180 phase difference
    would yield LARGEST potential difference .. with currents
    flowing to the left, to the right, and so on.
    One challenge here would be to make both the left and right
    sides exactly match to achieve that. They won't exactly match,
    I realize, because that would be too perfect. The will
    therefore BEAT just a bit. You can establish a potential different
    between beating frequencies as well ... but for efficiency you
    probably want to bring these two coils into synchronization or
    as close as possible to it. -- speculation on my part --
    The phase relationships in the circuit are complex. You have
    currents going through these 40MFD and 80MFD caps which
    will alter phase ... and you have it going though the 5:1 transformer
    coils and the Hendershot coils.
    In figure 5.3 of the Barry Hilton book we see Hendershot's drawing
    of his layout ... with 1 & 2 being his coil and so called
    "Resonance Tuner" ... aka C-Clamp on his capacitor.
    Similar to Radio, this is the place were the feedback path
    is re-entering the circuit to cause regeneration -- I believe.
    As such this coil-capacitor tank circuit is the STARTING
    point of the entire circuit.
    In terms of circuit analysis, if you can simplify EVERYTHING
    in his circuit down to just this tank circuit, we have
    the 7.8nF cap (variable in that by squeezing it physically
    the capacitance increases from that 7.8nF baseline value)
    and the coil proper.
    The combination of the outer coil (14-turn one) and
    the one under (64-turn one) create a transfomer --
    with inductive coupling.
    NOTE: With an iron core we can assume a PERFECT inductive
    coupling and use normal transformer analysis here.
    If, on the other hand, we have a air coil, the coupling will
    not be ideal .. and hence K (the mutual inductance constant)
    will be less than 1 (at some value more appropriate for air transformers
    closely wound -- whatever that is).
    Certainly air transformers work as they are used in radio designs ...
    but there are losses to account for since mutual inductance
    is not ideal.
    Anyway, whatever the load is on the other side of that transformer
    is being impedance matched via the transformer.
    Since its a step up with a turn ratio of 64/14 (or 4.57:1),
    we can assume current is reduced on the other side,
    but voltage increased.
    Normally what someone might do is just hook up
    the 1:5 transformer again on the other side of this 64 turn coil
    to bring the voltage 5x even higher, and the current 5x even lower.
    But instead we see things wired all around using the other
    coils and transformers in a non-conventional way.
    The other coils look similar to the "tickler" coils found
    in regenerative radio designs.
    So yes circuit analysis might shed some light here IF
    you can properly account for all the mutual inductance
    -- and possibly some non-conservative field effects.
    Those really good at electronic circuit analysis might
    be able to model this using spice or something better.
    A simulation might need to model these mutual inductive
    effects in a special way.
    If we could get the help of someone really good
    with this sort of circuit analysis, they might be
    able to shed some important insights into what
    the circuit should actually be -- out of the
    many choices presented in the Barry Hilton book.
  • mlurye
  • morpher44
    L1 is L4?
    I noticed 1 more thing,
    Everybody saying that cap should be wrapped around stainless steel tube. Check comment on fig1 The Inventions of Lester Hendershot. It says: stainless or Aluminum tube.
    And the coil I was talking about is L4, see schema on the link above.
    Yeah ... in the schematic you are referring to L4 is what I'm calling L1.
    Other schematics have that outside coil as L1. Yes its confusing.
    Yes the tube the cap is wrapped around is puzzling.
    If its aluminum, its paramagnetic .. which would actually
    REDUCE the inductance ... so placing it in the coils like
    that would influence their inductance the other way ... bring
    the resonant frequency higher.
    Stainless steel is problematic because there are several
    varieties of it... each with different permeability characteristics.
    These would be below iron ... but approaching iron in
    permeability
    Some stainless steels are non-magnetic, however ...
    but that is a bit more exotic to find.
    But again, IF the tube is paramagnetic or non-magnetic,
    making the coils essentially air coils ...
    the oscillations would be well up in the VLF frequency
    range ... approaching the AM band.
    I can actually see on my scope the following effect.
    If I ping with pulses of say 1Khz .... I can see on this outer
    coil (my L1, your L4), a dampened oscillation which corresponds
    to that AIR-Coil assumed frequency. Its dampened, however,
    and fades away FAR before the next pulse.
    If I then slowly lower the cylinder into the coil,
    as I do, that oscillation doesn't change in frequency, but
    does get more and more dampened.
    When the capacitor is completely inside the coil,
    that oscillation is almost completely gone ... negligible.
    If that oscillation is WANTED, then yes I agree with
    you that these should be air coils ... tuning
    at that higher frequency ... and an attempt should
    be made to get that ringing to go longer ... and go
    regenerative if possible. The Q in that situation is
    not so great ... but the bandwidth is more reasonable
    with respect to tuning. It becomes more wide-band.
    If, on the other hand, we are trying to tune for buzzer
    frequencies, I think the coil inductance must be brought
    much higher using ferromagnetic material.
    Here the Q goes VERY VERY high ... bandwidth becomes
    extremely narrow and tuning becomes a pain-in-the-a**.
    There are a few clues that lead me to assume the latter.
    A. Hendershot's device was notoriously difficult to tune.
    B. One photo has a sticker inside the coil with the letters "Fe" -- Iron.
    C. Hendershot's early designs used coffee cans -- most are magnetic
    D. When Hendershot switched from coffee cans -- which would damage
    his caps due to ridges and left over dielectric in his hand-made caps
    (presumably some sort of ARCing damage) -- he switched to
    stainless steel (but kept his original coil geometry and turns) - I think.
    It is possibly that Hendershot realized he needed to switch
    away from a ferromagnetic material ... but this should have caused
    him to alter his coil significantly ... much greater number of turns.
    This is my line of reasoning. It may be incorrect...
    What can be done ...what I suggest ... is that you
    build various capacitors types to fit in your coil ...
    one wrapped around ferro material ... and one wrapped aluminum ..
    or a non-magnetic stainless steel ... and perhaps one
    wrapped around cardboard or plastic.
    I have more experimenting to do with respect to this issue.
  • mlurye
  • morpher44
    L1?
    morpher,
    I would say that outside coil is wound on 6" diameter. Wooden dowel + 1st coil + electrical tape ... (in regards of 5 15/16 diameter)
    @mlurye,
    The calculation for L1 is bugging me.
    If the cylinder is ferromagnetic (which I am assuming),
    then I think you use the Wheeler formula and also multiply
    by the permeability constant ... 5000 or so for Iron ...
    something less if your material is say some sort of stainless steel
    that is magnetic.
    I'm leaning towards this being the case because for
    Hendershot to achieve resonance with L1 and the 7.8nF cap he
    made, L1 has to have a large inductance ... assuming buzzer
    frequencies.
    I messed around with that little "made in china" dual-coil buzzer
    I have. I hooked it up to my pulse generator. As I dial around
    in the frequency range, providing it a narrow DC pulse, the
    buzzer hums in the audio range, but won't pull the clapper
    to the solenoid until I'm in the range of say 90Hz to 110Hz.
    Its a narrow range. Anything outside that range won't do it.
    That buzzer solenoid essentially have a self resonance in that range
    ... which makes sense.
    Placing this pulsing solenoid in proximity of the Hendershot coil
    does induce a current in the Hendershot circuit.
    It has a magnetic field that is easily picked up by the Hendershot coils,
    even at a distance of a few feet. I'm impressed by the distance of
    mutual inductance ...
    If I connect a ground wire between the buzzer's metallic case
    and the Hendershot circuit (between the two big caps),
    that signal is BOOSTED substantially ... this being the one-wire
    connection between them.
    But what I'm realizing is that since Q is so high with these values --
    high inductance ... low capacitance ... the bandwidth
    will be an extremely narrow range. It could be on the order
    of one third of a Hertz ... or less.
    The chances of tuning to that one PEAK resonant place --
    for my crudely made thing -- might be very difficult.
    Also, I don't have a precise way of measuring the inductance
    and capacitance ... so knowing this sweet spot frequency
    is ball park only.
    I might have to rethink my coil ... to provide a slightly larger
    bandwidth ... so as to make tuning less difficult -- at the cost
    of smaller Q (and possibly attenuated results).
    L1 is a challenge.
  • mlurye
    morpher,
  • jeanna
    I just bought a conical drinking cup today for use as a conical coil template. I think the shape helps match whatever is there...I read that from tesla quote maybe??
    I will give it a try.
    I guess I need to move my big camera file over to this computer so I can show a pic or 2 of my scopeshots taken at a place between 2 wires with probes stuck into the earth with stubblefield generators at each end. I have a comparison set of probes without the stubblefield gens too.
    The shape is the same but the inductance etc whatever he did increases the voltage from typically 5mV from just 2 probes to often 65-85mV with the coils at either end. It is ac on top of a 0.5v-0.7vdc. very interesting and amazing looking.
    BTW The stubblefield generator is a perfect wire replication of the ancient caduceus.
    The ancient drawings even look like wires in some versions.
    I understand that JNL has made a modern version that can produce scalar waves. HMM.
    Whatever is coming our way may be just what we need and maybe it won't hurt either. I like the idea of toroidal packets. Sounds great to me.
    thank you,
    jeanna
