Hello,
Here is my contribution to the world.
YouTube - Yu Oscillating Generator Overunity Model
The Yu Oscillating Generator combine with Howard Johnson magnetic track used as an actuator.
The key is not to move in a full rotation but oscillate instead. Here is the video explaining the basics.
You have a counter weighted levered pendulum with a torque circumference. On top of the lever you have an actuator. I used a H.J. magnetic track as one method.
The lever cannot stop in the middle of the track, but will be forced out. Afterwards a servo will redirect the drive magnetic pole facing into the track. The lever allows for a mechanical gain driving a turbine.
@ Pendulum -- Any kinetic and potential energy lost due to any form of resistance. Will be re-entered into the Yu Oscillating Generator “YOG” through the actuator.
Lets take a look at one cycle of the YOG and actuator.
Here you have a servo that gets energized for about one second to change it’s orientation 180 degrees pointing towards the magnetic array. Once the orientation has been achieved the servo de-energize. Theirs no more input electricity into the YOG at this point.
After de-energizing, gravity then pushes the counterbalance lever’s top portion. Which is the drive magnet into the mouth of the magnetic array.
The array then sucks it in and the magnets repulsive push will travel the drive magnet out the other end.
Kinetic energy then returns the cycle at that point.
The circumference in the lower part of the YOG plays an important role as well. The circumference allows for physical transfer to the turbine. Some test I have preformed has achieved 150 RPM @ 15lbs swinging.
To sum it all up, you will achieve more electriticy out then in.
My journey of the overunity model has lead to other models with great benefits too. The device can produce renewable energy on land with wind, on top of ocean waves and even underwater.
Best Regards.
Howard G. Yu
YuEnergy-dot-comm
