Philo T Farnsworth and Ed Gray tubes
  • Philo T Farnsworth and Ed Gray tubes
    Hey just started to look at the patents of Philo T farnsworth in the attempt to understand what might be going on in the 'gray'tube, anyone with ideas lets start a discussion .
    quoted from wiki
    "Philo Taylor Farnsworth (August 19, 1906 – March 11, 1971) was an American inventor. He is best known for inventing the first fully electronic television system, including the first working electronic image pickup device (video camera tube), and for being the first to demonstrate fully electronic television to the public.
    In his later life, Farnsworth also invented a small nuclear fusion device known as a fusor."
    U.S. Patent 2,184,910: Cold cathode electron discharge tube (filed 4 November 1936, issued 26 December 1939)
    # U.S. Patent 2,204,479: Means and method for producing electronic multiplication (filed 16 May 1936, issued 11 June 1940)
    # U.S. Patent 2,140,832: Means and method of controlling electron multipliers (filed 16 May 1936, issued 20 December 1938)
    # U.S. Patent 2,260,613: Electron multiplier (filed 18 May 1936, issued 28 October 1941)
    # U.S. Patent 2,141,837: Multistage multipactor (filed 1 June 1936, issued 27 December 1938)
    # U.S. Patent 2,128,580: Means and method of operating electron multipliers (filed 18 August 1936, issued 30 August 1938)
    U.S. Patent 2,071,516: Oscillation generator (filed 5 July 1934, issued 23 February 1937)
    # U.S. Patent 2,143,262: Means of electron multipaction (filed 12 March 1935, issued 10 January 1939)
    # U.S. Patent 2,174,488: Oscillator (filed 12 March 1935, issued 26 September 1939)
    # U.S. Patent 2,221,473: Amplifier (filed 12 March 1935, issued 12 November 1940)
    Ahura
    And how is it going, do you see any similaretys before i start digging true the patents?
    - Behold the truth -
      I hope it's okay if I inject this little colorful sidebar:
      ______________________________
      What did your neighbor build in his basement?
      Well, mine was Philo T. Farnsworth,
      and this is what he cooked up in his:
      Farnsworth Fusor
      The device, as originally envisioned by Farnsworth,
      could generate cheap power for the masses...
      And by the military backers, it was seen as a potential power
      supply for weapons like the ol' backpack laser canon...
      Farnsworth eventually left the project,
      before it was
      successfully completed...
      __________________________________________
      The house where the initial prototypes were built
      in the first half of the 60s, is just a couple of blocks
      from my studio, and just a few from where I grew up...
      When the efficiency of the designs started to improve,
      the decision was made to set up a proper lab a quarter
      mile away in the downtown/industrial area...
      Memories of the times from Farnsworth's son
      "Neither my mother nor I were welcome at the lab for security reasons,
      and I only visited twice, and my mother only a time or two more.
      I did go one day and I saw the fusor do its thing, and it was astounding to me.
      I watched as the voltage applied to the fusor's cathode was increased
      past the 50kv point, all the particle counters began to chatter,
      and the focus on the fusor device intensified, the room was electric.
      We had a few explosive moments as stray dust particles would bridge
      the high voltage supply and a spark would startle everyone...
      ...The deal, as I understood it: Phil was to get a controlled, nuclear
      fusion reaction in the lab in Fort Wayne, and then they (ITT) would
      build a facility for the extended work in a suitable (remote) area.
      Phil lived up to his part of that bargain."
      What is Star Mode...?
      Fusor.net
      This is a visual signature of good clean operation of
      a fusor. It heralds a major, initial success in the
      construction of the basic device.
      In the fusor, good geometrical alignment of the
      inner grid structure is important.
      A clean vacuum that is free of organic
      vapor and, hopefully, water vapor is also desired.
      If these criteria are met, then the indicative visual
      signature is referred to as "star mode".
      The appearance to the eye is of a glowing ball of
      plasma within the center of the inner grid with what
      appears to be multiple radiating, fine pencil like rays
      streaming out of it through virtually every opening in
      the inner grid. It is not only unmistakable and beautiful
      but shows that most of the basic hurdles in fusor
      operation have been conquered.
      How to ensure better defense contract funding:
      On the day of the proof of performance test,
      Gene was told to go into the next room and
      listen during the ITT testing for the high
      voltage call out and as it climbed, he was to
      play the tester spark along a massive fume
      hood intermittently and at the maximum
      usor voltage call out he was to arc the tester
      closely and at a fixed point on the hood until
      the callout of decending fusor voltage,
      when he would again walk the tester loosely
      along the large hood.
      This was the illicitly generated count that
      launched a bigger funding from ITT to create
      the more successful real future fusion efforts
      and boost the stock as well as bring
      Farnsworth into the spotlight,
      more so than had his work in television,
      at least for a while.
      The now-familiar photos of Farnsworth posing with
      the "top hat" or "bell-jar" fusor circa 1959-61 were
      taken as a result of the publicity campaign that ITT
      mounted...
      The irony, of course, if we're to believe Gene Meeks
      via Richard Hull, is that the fusor that Farnsworth
      is posing with here was obsolete even before the
      photo was taken.
      Farnsworth on Television:
      Although he was the man responsible for its technology,
      Farnsworth appeared only once on a television program.
      In 1957, he was a mystery guest on the TV quiz show
      I've Got A Secret. He fielded questions from the panel of
      celebrities as they unsuccessfully tried to guess his secret
      ("I invented electronic television.").
      For stumping the panel, he received $80
      and a carton of Winston cigarettes.
      {He later died of pneumonia...
      Video of Farnsworth on "I've Got a Secret"
      “Philo. T Farnsworth Archives” (managed by Farnsworth heirs)
        Farnsworth multipactor tubes utilized a phenomena known as the Multipactor Effect. According to Wikipedia:
        The Multipactor effect is a phenomenon in radio frequency (RF) amplifier vacuum tubes and waveguides, where, under certain conditions, secondary electron emission in resonance with an alternating electric field leads to exponential electron multiplication, possibly damaging and even destroying the RF device.
        I've always been under the impression that the Gray Tube utilized either electorstatic or aetheric energy. I recently purchased a book called "Polytubes" by Jorge Resines which I've yet to read. When I get the opportunity to read it I'll relay anything of interest to the forum.
        Borderlands has an article regarding the multipactor:
        THE FARNSWORTH MULTIPACTOR TUBE
        While we're on the subject of multipactors is anyone aware of a company that manufactured the multipactor tube and if so what was the model number?
          Multipactor tube
          Auction ended - Multipactor tub; Philo T Farnsworth invented in the 30s - eBay (item 190341675660 end time Oct-20-09 14:30:51 PDT)
          Vtech
          General D.Eisenhower
          http://www.nvtronics.org
            I sent an email to the guy who sold this item. Turns out he has several which he plans on selling individually over the next few weeks. Here's the latest one for auction:
            1936 Multipactor, invented by Philo T Farnsworth CHECK! - eBay (item 190345198645 end time Nov-04-09 06:18:45 PST)
            If anyone here ever wanted a multipactor this is probably a good opportunity to purchase one.
