  • Gedfire
    Ferrite Yolk Remix
    Originally posted by med.3012 View Post
    Hello Gedfire ,
    i just want to add something maybe useful to you, this is a proposition from a friend to me :
    One of the practical problems of Television cores is the shape is not optimum.
    If you can gain access to a lathe, for either metal, or even wood, such as used for turning bowls, you can fabricate a wooden fixture to hold the television cores, and then use diamond, or carbide tools to reshape the television cores, if they have enough surplus material in them to work with.
    If they don't suit your needs, and yet are cheap, put on protective eye wear, and carefully smash them to powder with hammers, and a very heavy bit of iron to use as an anvil, being careful to save as many of the fragments as possible. Smash them to powder and then cast them to the shape you wish. I use molds made of silicone for complex shapes because I have it. It is totally a waste for something simple like a ring.
    For a ring look in the garbage for plastic containers of two different sizes, and use hot glue to put them together in a fashion that will suit your purpose. Use child's modeling clay to eliminate leaks (or more hot glue) Mix your ferrite powder with epoxy resin which has first been mixed very thoroughly "A" and "B" parts.
    Use a slow set resin, if you are able. Cast the mixture in your prepared mold, or molds. When set, you should have the ferrite shapes you need, exactly as you want, without compromise. You may even find yourself getting creative with the process. The ferrite is usually ceramic, made in kilns like pottery, a mixture of glass, or clay along with the iron powder, because in a TV it gets hot, and epoxy would soon perish at high temperatures. Our application should not be hot, and if it is, we can always sink it in a plastic tub of mineral oil, or wax, worrying about that problem later.Rusty iron might be pulverized too.
    i hope this can Help .
    Good luck
    I hope so! Thanks.I am always open to options.Your suggestions are noted.While we are at it what do you think about this patent?
    Patent EP0932248A1 - Method of harnessing a back-emf, and apparatus used in performing the method. - Google Patents Kelly's PJK takes about the inventor of this and an invention.A mere heater then but this seem to be the MEAT of the matter folks.
    Not overunity it would seem but it contains the essence of don smith/ tesla technology.remember the secret may (and i say "may" because i have no documented proof of my own yet....just anecdotal evidence from basic experiments.I am working towards getting the best instruments later on) be hidden in plain sight....
    Patrick Kelly normally visits invisibly to check in on our research.He usually updates his very highly recommended super free energy pdf.often times we mention things many many pages back,but it takes time to gain traction and be recognised.Lorrie's Device was one such device.I built one and posted it on this forum a long time ago.It got scant regards at that time.The evidence still here.Eventually it showed up in Kelly's PDF so kudos.We all take sometime to wake up!
    More ?.... here goes: https://www.youtube.com/watch?v=jO55v3fqiO4.The Grand daddy of Tesla and Don Smith Device reborn.Self Oscillation = self resonance.No problem.THAT's what ran the Rumkorf and tesla coils.Its siblings are relays dimmers switches transistors buzzers etc.In self resonance mode you get the best and with proper configuration collect the back EMF and coil cw ccw and we will be in business.
    https://www.youtube.com/watch?v=6B79UJGoNJE
    So my idea is to scale all this up.AND iron cores can be used.Just need a bigger one.
    Last edited by Gedfire; 05-25-2016, 01:45 AM. Reason: More info to feast on.Now go forth and produce guys!
  • med.3012
    Hello Gedfire ,
    Good luck
  • Gedfire
    Back to Air Core Ferrite and Iron Core
    Originally posted by Wistiti View Post
    Hi Ged.
    you can find ferrite in on the cathode tube of television (yoke) and also some radio have ferrite stick Inside...
    hope this help...
    best luck in your research!
    Thank you for your response.I am aware of that.I am leaning towards a c or e core like don but i am tempted to think that the powers that be are deliberately making it real hard to get single cores or you guys bought them all off.cores the size don had in various devices are difficult to find.
    so because i like challenges i am going to use the yoke from the tv.i have already tried the flyback.i might renew my experiments with air core like don.
    i am also going to play with iron core transformers.if i could get my hands on a welding plant transformer.i already have MOT.Better yet I am aiming for a pole mounted transformer.
    btw, does anyone know the inductance of single phase residential pole mounted transformers?
    i theorise that iron cores can be used.just atlower frequency.its drawback is really size. the BEMF equation E=-L X amps/time can be manipulated.So if I get a large iron core transformer with HIGH inductance but at lower frequency that would be equivalent to a small metglas transformer at higher frequency.its in the math.
    there is always a work around.so i will return to converting tv flybacks and yolks MOTs welding transformer etc into a working device.I did with the flyback.jus then i did not understand what i really did.now i know better.
  • Wistiti
    Originally posted by Gedfire View Post
    Hello Guys,
    Do you know of a source for Metglas,Mumetal,ferrite, sendust of any other core Don mentioned.I had my eye on an $80 Metglas core on Ebay but it disappeared and was never seen again.
    The ones are see now are too small for my use.If anyone knows were I can get a good size core please link me in.The big guys sell in bulk and clearly has no interest in my very small order.
    Ged
    Hi Ged.
    hope this help...
  • Gedfire
    Metglas MuMetal Nanoperm Etc Cores
    Hello Guys,
    Ged
  • Gedfire
    Hello Guys,
    Ged
  • Gedfire
    Don Smith Files Reboot THANKS
    Originally posted by deggers View Post
    This is 300+ MB if that's what you are looking for Jed.
    https://www.dropbox.com/s/p7lxo9dsym...brary.zip?dl=0
    Thank you very very much for this.I am extremely grateful.Glad you kept the faith and saved this valuable information.Felt like you gave me a sacred stone ...that must be preserved and shared.
    We will press on and continue Don's work.My status update: well I have all the probable schematics and its now for me to build.However building requires money and time.Time I have ,well money, I am accumulating some.I will always be updating whenever I get the chance.
    Gedfire.
  • a.king21
    Kapanadze free energy
  • a.king21
    This video was sent to me by a Kapanadze insider who was unhappy with the way he was doing business. Unfortunately it is in Georgian and a translation from any Georgian speaker would be welcome. I don't think it helps us much as the video is filmed entirely under Kapanadze's free energy lights. However it is yet another device to add to his collection....
    I have called it aquarium 4.
    The link is https://www.youtube.com/watch?v=3s-4...ature=youtu.be
  • jim glinski
    free energy with caps and DC electrostatic induction
    Well guys keep it simple. It's the only natural system that i know of that creates free energy .
    You take a strong POS or neg charge and bring a balloon close but no touch and give it a quick touch to ground it and you've charged it now get10 more balloons and use the charge from the first and repeat and repeat charging each by proximity . after a while the rooms full of charged balloons .and the first charge is untouched .just use caps and adjust voltages. The balloons really have a very hi charge on them but no amps .just make away to charge and discharge sequencing the discharge .I know this is brain dead simple but I'm talking woking real world principal. Been around for ever .this is making energy from energy. But for some unknown reason people didn't see that with caps or Leyden jars the conductive verses inductive percentage shifts. There's a lot going on with that series string to consider. Reduced individual uf's. Increased operating voltages . charges the same for each cap but different voltages on them due to reduced uf's by there relationships to each other and the source and ground. Conductive to inductive charge percentage shifts . so I just go by the bulbs and caps what voltages will light how many caps or blow out a bulb.how many caps can I insert and still flash off the bulbs switching configuration ? Bulb by blub cap by cap. No need to get lost in the woods. Good hunting Jim out 🍺ps if I have to start adding bulbs in series to keep from
    Burning them out that's a good thing. A good direction. Hay you know I think lead acid batteries are around 50% efficient so you have to make twice the energy to get zero .so you'll need probably need 4 caps to over come .best guestimation.? I'm gone
  • med.3012
    Originally posted by jim glinski View Post
    No closed looping open system simply discovered in the 1700 to1800's electrostatic induction by proximity . it's just several people have found creative ways to make it work. Bring a balloon near a strong POS or neg source and touch it to ground or your body and you have cloned the charge for free it will stick to your wall .the trick is to trap it and use it.don Smith showed this with a Tesla DC hand helded coil and a piece of glass the charge was pulled up from the earth on the other side.that's were the sparking comes in there needs to be a break in the charging for collection. He said that general electric has made a fleet of drones for China with this concept. So who's your real enemies.?????. You just live here they own it and you. If we default on the national debt you and your family are the surity for it. They can come and harvest you to pay it.its law. Jim out🍺
    i didn't say your idea is wrong but i am wondering to how level we could use it... ? the spark can jump where you have a difference of potential, electrostatic induction can be divided to several parts according how you use it, if you do it very good you may have free energy, in some levels you may have an economic system or a low COP over unity device, in most case calculation is a must, you have to calculate the INPUT and the OUTPUT . even when you use an inverter working on a battery only the battery consume power too when you are charging your capacitor banks .. open loop don't mean you have free energy, there's other phenomena involved in your system ...
    Good luck
  • Wistiti
    No closed looping open system simply discovered in the 1700 to1800's electrostatic induction by proximity . it's just several people have found creative ways to make it work. Bring a balloon near a strong POS or neg source and touch it to ground or your body and you have cloned the charge for free it will stick to your wall .the trick is to trap it and use it.don Smith showed this with a Tesla DC hand helded coil and a piece of glass the charge was pulled up from the earth on the other side.that's were the sparking comes in there needs to be a break in the charging for collection. He said that general electric has made a fleet of drones for China with this concept. So who's your real enemies.?????. You just live here they own it and you. If we default on the national debt you and your family are the surity for it. They can come and harvest you to pay it.its law. Jim out��
    Hi Jim.
    I have also think like Med... That why i ask you if you have plug it in the wall or via an inverter... cause as you may know, the ground of your house is also tap with the neutral in your main pannel... that cause if you use the main hot wire of your house outlet rectify it and only use the + of the bridge to feed the cap, the ground rod will made the loop cause the neutral of your house is also connect with the ground...
    With that said; if you do this with an inverter it is a complete other story!
    Anyway cause i am a builder i may give it a try (with the inverter) when the time permit...
    Ciao!
  • jim glinski
    nothing hidden
  • med.3012
    As far as free energy is concerned I've found it. And it was so in my face the hole time. Here I go again! When you look at the formula for a set of caps in series each one is a reciprocal of the total every were you look on the net you get that answer and it's true as far as they go .what they didn't tell you was that the capacity is spread out being that the plates are spread out .the total is equal to the original single cap so they say that there's no real advantage that is if they are all the same uf. To start with .what's not said is by spreading out the charge you increase the inductance side of the charge and reduce the conductive side .with 5 caps is a series the first plate is charged by conductance the rest by inductance aka free. The string is under strain by the first positive plate and has to regauge. It's potential to match the first plates level and there by balance every thing out . the energy to do this is pulled from the earth .you can put a amp meter in line with the ground and see it working. Then when the string settles down the caps can be fired off and evey thing started again and again and again. I've done this .with a inverter a bridge rectifier and two big caps 60 uf I could repeatedly flash off a 4 or7 watt light blub on both caps and watch the amp meter as every thing refilled over and over the thing with the string the more caps the less energy you need to do this. Each new cap splits off some of the total charge and the charging plate needs less charge to fill it. I've used around 119 volts DC Thu my inverter and let the negative lead hang unconnected in mid air !. With more caps the charge gets smaller on each one but each one has the same charge on it the voltage is reduced witch can be a good thing because that gets you to the point that you can use solid state but the total charge is still there but a lot less is needed to create it. The only ground is Thu the last cap. If you just use two caps you get 50/50 on the system you pay for one you get one free ! But if you use more caps the energy is divided up but the conductance and inductance remains and the ratio changes between them. Ben Franklin demonstrated this and referred to it as a economical way to charge Leyden jars. Could you tell me how my light bulbs are firing off with out my negative connected ? by the way with an small isolation transformer and a bridge rectifier you can do this on both the positive and negative lead using the same ground ! The transformer will be a door bell transformer used in reverse so I can get 400 volts to get close to by caps rating of 450. And a choke cap before it to reduce the power down to be safe . well there's most of it .PS don't be confused by the different voltages on the caps in the string the charge is all the same on each but the capacitance has changed due to the string series. Jim out. Please replicate .
    hello !
    thanks for your posting here, really interesting info but the earth grounding isn't enough without other techniques at least to get a huge amount of power more than 4 or 7 watts , as example of the complexity Tesla wireless power transmitter, the ground was an essential part but not only the ground as you know, most power company even in the poor countries use the earth grounding in their medium voltage transformers, if i understand your system you have a hidden closed path that you don't see, this is why your caps is still capable to be charged as a result ampere meter will show a real electric current ...
    by the way i sent you an email because i want to understand your idea more :-)
  • jim glinski
    Wayne ct
    Hi Wayne if you will go over to overunity .con and look up my pic of the lay out it answers all
    Your questions. Except on frequency the unit is just DC the only frequency is when you do cap dumping . very primitive tec. I think it's the root of much of Tesla type tec . the hi freq area is when you replace human switching with electronic via hivoltage pulsed DC the resonance with coils is for forming and sharing the conditions for multiplication of power. It's just my take on things. Jim out🍺
