Originally posted by zilano
RL circuit - Wikipedia, the free encyclopedia
Parallel Circuit
The parallel RL circuit is generally of less interest than the series circuit unless fed by a current source. This is largely because the output voltage Vout is equal to the input voltage Vin — as a result, this circuit does not act as a filter for a voltage input signal.
A Low pass Filter requires a series resistor !
Low-pass filter - Wikipedia, the free encyclopedia
And even if you would use a Lowpass Filter, your "All-frequency"-signal would still INCLUDE the frequencies in the Passband below 50 Hz, like 40 Hz,30 Hz etc that would NOT give you a clean 50 Hz AC output.
It is impossible to run appliances with such a signal, so your device cannot work.
