  • luc2010
    Hi,
    i think i need to try one more experiment with cap charging and discharging and close this chapter!!
    the next step will be a coil experiences?
    rgds
  • luc2010
    Originally posted by med.3012 View Post
    Hi !
    do you have a schematic ? for sure you can use it as a choke .
    regards
    Hi MED,
    No, i dont have the schematic of the car ignition coil
    Diamond
    oil filled coil
    LB 63 12v Japan
    even dont know for its output voltage!
    many thanks
    regd
  • med.3012
    Originally posted by luc2010 View Post
    Hello,
    back to work!!
    can we use a car ignition coil in reverse mode for choke? using only the secondary coil?
    because i need a high coil inductance? for charging a capacitor!!
    any progress?
    thanks and regards
    luc2010
    Hi !
    regards
  • luc2010
    Hello,
    back to work!!
    any progress?
    thanks and regards
    luc2010
  • Dwane
    Hi ilandtan,
    Thanks for the update. I think i have the capacitor problem solved. I have given the wax away and looking at lucite. Easier to manage and not as messy. I have been getting biased results. I calculated that my temperatures were uneven, this was indeed the solution: now I am able to produce various poling outcomes.
    I started looking at the third coil as an option. I can see this is likely not what Don was doing. I am thinking that he uses the Marx generator concept to get the voltage magnification he wanted. In fact quite an elegant solution!
    I do try and understand what I am doing. It is not easy!! A lot of solutions have no written explanations, also, it is difficult to get measurements that are meaningful. They might be there, but seeing them is often difficult. To interpret, even more so. When one covers a lot of ground in a short space of time, it is easy to become overwhelmed and often miss the forest because of the tree's!
    regards
    Dwane
  • ilandtan
    Originally posted by Dwane View Post
    Hi ilandtan,
    couple of things. Here is a couple of pics of the set up posted earlier. I am using approx 6watts. However, on my electrostatic meter, I am reading over 30Kv! I do not get a reading from the collector coil that is lighting the globes.
    On the Tesla picture, I have been looking towards building a different set up, similar to the attached pic. I'll take your advice and proceed with the earth connection. Also, I am losing lots of time building my capacitor. Maybe in a week or so I might have something better to show!
    Thanks and regards
    Dwane
    Please pursue what you will, but do it with the intent to understand what is not understood.
    I mentioned the third coil in passing about energy transmission, because it was the only way I was able to pass energy on a small scale to an LED beyond the local effect of proximity radiation. The Tesla third coil used in his magnifier is a totally different topic I have not investigated thoroughly enough.
    I don't know if it is the answer to the Don Smith equation. However let me provide some guidance about the overall failure of what I see on this forum.
    We try continually to discover secret configurations, circuits, components to provide us the "more" we need to see real power. However we don't know how the system works, so we continually fail. It's like having the parts of an engine scattered about you without knowing how the pieces fit.
    How do we know we are on the right road?
    Don said oscilloscopes can't see the accurate picture, and that would make sense because it wont show you what is happening in the magnetic spectrum. He said use gaussmeters and frequency counters.
    I purchased a 20 dollar gaussmeter, per dynatron's advice, and I see things differently and scanning all Don information for his insites. Looking for that, I came across a Don quote
    Resonating – Fluxing of these None Ionic Electrons provides Useful Energy. From a Gauss Meter and a Spark Gap using a High Voltage and High Frequency Source the Magnetic Flux available ranges from two to greater than two thousand Gauss.
    Two thousand Gauss is a heap of magnetic field. If you measure your slayer like mine, it was around 3uT.
    If we are replicating Don devices, we have a way to know if we are on the right road, by measuring the moving magnetic field, like with a gaussmeter. If you equate that conceptually to 2000G magnet but being able to turn the field on or off (or reversing the polarity) at a very high rate(frequency). You start seeing how that can be used to supply REAL power.
    The goal then is to produce flux through resonant systems. We are definitely doing that in our slayer configuration, just not in the magnitude needed. By having the right tools, we can research and engineer from the results perspective.
  • Dwane
    Hi ilandtan,
    Thanks and regards
    Dwane
  • ilandtan
    Hi ilandtan,
    Do you think Don was using an extra coil to resonate to a higher voltage?
    Dwane
    My comment was regarding this:
  • Dwane
    Originally posted by ilandtan View Post
    Hey Dwane,
    I knew that would! Experiment the different ways to attain power by going straight to Earth ground on the receiver. But before you do that, place a piece of metal between the two top loads as a shield. If you ground the receiver to the battery, there is no interruption of power output. Now when you use Earth ground as part of the dipole on the receiver and you shield the toploads, you will see the power transfer drop.
    Now you know what you have setup, couldn't be how Tesla was going transmit the power through the Earth. However, if you have a third coil, you will see how it is done.
    Hi ilandtan,
    Dwane
  • GlenWV
    Originally posted by FRANKLIN View Post
    Hi
    somebody here has any document about how replicating the don smith device, where he is using the neon-transformer.
    thanks
    Greetings:
    What need ye?
    glenWV
  • ilandtan
    Hi guys,
    Have found a few hours this weekend! Have set up first stage of the energy transfer test as per Tesla. Simple stuff. But, following the rules, such as wire weight, turns etc, this worked first time I switched the power on. Reassuring to say the least! Am still waiting for my wax modules to come out of hibernation, will get some perspex tomorrow and give that a try. The teflon is a bit tricky given the high temperatures required. Photo attached.
    @Franklin, this might help!
    Hey Dwane,
  • Dwane
    1st Tesla Test
    Hi guys,
  • FRANKLIN
    Originally posted by h2ocommuter View Post
    Hi Cody,
    Everything I have compiled is in the PDF I have put together,
    except the minutia. I have gone through lots of material. But still there is so much out there.
    I bought the plasma globe "Illuma storm" from an e-bay sale, I got the speaker wire that has something like 488 strands in each lead. I wound 14 turns on a 7" PVC pipe, I got a 7,000 to 12,000 KV isolation transformer from another e-bay sale., I just missed three great sales for the Caps. these monsters are kind of illusive. I may have to build my own or I may build it with no caps. I still need to find the right Varistor and the two different kinds of spark gaps ( I think I will use spark plugs anyway. I have a circuit breaker box that is adequate but I would like to find one with a PG&E meter .
    I have been ordering meters right and left... I got and electrostatic volt meter that will measure from 1 Volt to 100,000 Volts, I am bidding on a gauss meter now, I hope I win. If you dig deep in Dons writings this value starts at the gieger counter values; .1 Gamma! OMG, I have purchased a frequency meter, and two LCR meters trying to save money, Any way I am in the hunt.
    If you would like a copy of my replication journal I will attach it. on reply.
    Zane.
    is it possible you share any document please
  • FRANKLIN
    Hi
    thanks
  • Dwane
    Reactive Power
    Hi Guys,
    Without belabouring the point, I think I understand it now.
    On the Grid, the Generators dispense Reactive Voltage up to their capacity. Where ever draw down occurs the Grid voltage is supplied via high voltage to step down transformers. These transformers are the mediating source to households or businesses and etc. It is only when draw down occurs and a load is placed across the voltage supply - switch on via an earth connection - the reactive power is converted into useable energy. Switch Off, goes back to reactive waiting to be used. Hence the system can only be as good as the maximum voltage coming from the generator. Therefore Reactive Power is always waiting to be used. Limitations apply from generated output.
    Dwane
