The reactance of the primary has not changed, its still 2.98ohm at 50Hz.
So why did the current drop to 1/3?
Because the tank is feeding back 2.51A to the primary.
That is 7.5v in the primary so the powersupply just have to supply 5v into the 2.98ohm reactance.
Perhaps a current transformer in series with the supply and the primary could work.
this is awesome, great site, need to use google translate each paragraph, but excellent, thanks!
Not sure if you know you can just enter the web site URL in Google translate and it will translate the whole page as well as any links on that site that open new pages. Sometimes though Google translate poops out half way down a page and leaves part of a page untranslated. I guess computers get tired too LOL...
The capacitor inside LC resonant circuit coil within arranged right magnetic vectors of coil.. That is really interesting and crossed my thoughts about electrostatic induction.
the parts explaining the self-excitation using auxiliary brush and coil in iron case,
the regulation using the automatic means,
the enhanced effects of the coil with reversed direction windings,
the outer ends of L2 being pos and neg rather than neg at center tap
the comparison between L1 Don used and the armature Tesla used
Understanding of these i believe to critical, as they are most likely the origin of our discussion... and what Don openly based his experiments on
Do you still get same 2nd secondary power up effect when shorting one of secondary coils?
YES, but in order, i'll get to that...
i ran out of wire or wouldve made both L2 the same, they are very close though,
its very cool!!... the far L2 does Nothing when primary is running, and the close L2 is basically what you would expect from a standard flyback i guess. BUT much improved over the first attempt overall!!
BUT the magic really happens when both secondaries are running or shorted as you said.
there are no gaps except for the 2 L2 ferrites have a layer of electrical tape to separate them so they act as 2 instead of 1 big core with worse eddy currents.
keeping them insulated from their contacting surface was good as i can see.
its still not meant for Big current though, this is a last resort after the Metglass didnt perform with the iron as i thought it might, and i just didnt feel like taking the first bitoroid apart but it can take more input before saturating, and provide more light than last time without peaking and leveling out, with my present electronics
its very cool how far secondary does nothing until its paralleled, or separately used,
the first secondary must be used, in order to make the effect of both secondaries effecting eachother, i think that's interesting. also i insulated each layer of windings on L2's, making it easier to maintain the same number of turns per layer, and from possible srcing between windings. i probably shouldnt have L2 ends wrapped together, but whatever easy to insulate those too
and on L1, the coil is one layer, then ran back on to of the first layer to begin again another layer, as i did in last time, and after so many failed trials, im gonna examine more Why it works better with the ferrites than with iron and metglass.
maybe ferrite and metglass? idk
either way, it seems there is no coupling from L1 to far L2, until first L2 is used, in which case the close L2 becomes the primary for the far L2, and they feed one another with their own building and collapsing fields
and i wonder what would happen with thicker L2 wires, with more intense magnetic fields
video coming soon
