Originally posted by level
hi buddy of course i realize the simplicity of this, it's been a few years of working with coils, Completely get tuning for resonance via fundamentals or harmonics or overtones
i believe there is something magical about coils, but as good as i thought my output was while "tuned for resonance" was still less than now.
When i do get enhancement from coils (kapanadze) then definitely i'll use it, but i did not have it with my tuned coils.
However, it seems that if you let your load experience the ground, Not just a coil, then you get a lot more benefit.
i literally see 50% from NST and the other 50% from the Earth
And if output has lost any Punch from transferred around, then why do it?
the magic is the cap charging the neg side from the Earth.
putting 100% power from NST on other side of cap. and demand the Earth to provide the other 100%
and having a seemingly constant flow of power.
Not just charged... pop... charged.... .... pop.... like my double helix board
and the cap you use must be chosen, too big a capacitance and it wont have enough power by the time you need it, too low a voltage and you kill the cap
crude as it is, the spark allows this to keep happening, as there is no power without a spark firing the built up power thru the load
and you dont want just a continuous wave, that would charge very slow, and just limited to the NST power
it seems to need a spark as the make and break mechanism.
(but transistors / IGBT's could prob do it) as long as it can handle the flow of everything, but a spark doesnt break down too often
Oh ya i remember the bonus vid where he drew the rough pic and said "you dont have to know how to tune anything"
But i think he also drew a gap on the secondary "which limits the voltage to where you can use it"
i think i have those memorized
But actually yeah i think he meant to put a spark gap on primary or maybe solid state, but was only drawing a concept block diagram.
of course i could be wrong, but ....
...in part 19/19 of the 1996 presentation ( i think ) he said..."the device in the suitcase, the coils are done away with...im gonna do it this way for another 5 yrs or so with the coils, but i will eventually let out in different user groups"....
i think what he meant by that was that there are no Air inductors (possibly still transformer tho)
and controversial as it is, later in 2001 inventors weekend he showed what he apparently had in the case,....
.... an amcc-320 Metglass core, wound with what looks like Tesla patent 433,702 "Transformer or Induction Device"
driven by small NST and looking like a step down config windings.
anyway
my point is i think he ultimately did away with air cores when he wanted to drive serious loads, as have most others, not that it cant be done cause ive seen some good power with air cores.
but relies so heavily on tuning, and the result is risking transferring losses.
One thing i noticed, is, if you are perfectly tuned for resonance, you will see the exact same if you still hook up the primary as i have recently shown... with Earth suppliying all the NEG... still a boost... but my coils were 100%transfer at best... its the Earth that gives the brightness in either situation.
sorry to ramble, i hope to use coils again when i get a boost from them
