This is Kapanadze First Circuit
![](http://www.energeticforum.com/attachments/renewable-energy/13669d1378857732-donald-smith-devices-too-good-true-tariel_sxema_2013.01.28.0c.jpg)
If this is the kapanadze circuit , this is called Tesla System of Lightning, This circuit actually works and will only work when you understand how the circuit function.
S2 is a normal switch to connect the circuit.
S1 is a make and break or spark gap, solid contact rotary switch
L3 is a Primary coil, Lowest Resistance, A very big thick few turns Low self Induction COil.
L4 is a High Self Induction Charging Choke COil, maybe coupled on the Transformer former to increased its performance, It is a very long wire coiled somewhere in the transformer coil.
RH= Load is any Coil form devices like bulb, motor, heater, relay as long as a coil and will at to the High Self Induction Coil.
When the spark gap fires, Shorting the Capacitor to the Primary at the same time building magnetic flux to the Secondary of the 12v to 230v and its now accumulating x2 energy . L4 and Load is a combination of High Self Induction Coil is also shorted and building magnetic flux now accumulated energy by the magnetic flux.
When the spark gap off, all the High Self Induction coil like the Secondary of the transformer 12v to 220v , the combination of L4 and load will discharge(COLLAPSE) the accumulated Energy from the magnetic flux build up and thus charging the capacitor.
Kapanadze only will excite / kick the system to start it. This circuit will work as I understand it from Tesla, it is another variation of Tesla Oscillator but will only light or heat or run coiled devices.
P.S. Don't mind the frequency calculator or resonance, because it is a amplifying nature resonance everything is automatic, like just hitting a switch and the missile goes off. Everything is automatic. The Resonance you have long known from the classical idea is not the resonance Tesla was talking about. Tesla's way is Controlled Amplifying Resonance because of the Make and Break energy accumulated is being amplified.
